How old is this wash machine. kenmore 80 series 1102880390 stock 28803
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 43 Answers
Hi Melinda, not sure if this might help get you closer to an answer but I see a post on FixYa for the same machine dated 2011 so yours could possibly be in this age category as well. See pic:
how old is this wash machine.
kenmore 80 series 1 - screen shot 2017-08-11 at 7.33.01 pm-5e1rsgzfmkhy3a0azavq0fmu-3-0.png
Posted on Aug 11, 2017
jsrock516
  • 5911 Answers
SOURCE: Kenmore 80 series lid switch
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosned, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions please let me know by posting comments.
Posted on Nov 02, 2007
AlmostBob
  • 550 Answers
SOURCE: kenmore 80 series washing machine
Marrr
Ingllis washers have a bad habit of picking up socks, small items anyway in the drain protector hose, slows down water flow but ensures the items dont get sucked into the impeller.
from the underneath you shhould be able to see a clear cup sized container with a hose in the side, held in with hose clamps. check if this is filled with any clothing, undo the hose clamps and you should bew able to empth the cup with fingers
Posted on Apr 30, 2008
SOURCE: i have a kenmore 80 heavy duty it will not spin washing machine
does it agitate?check your coupler.
Posted on Nov 14, 2008
SOURCE: Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
Posted on Dec 20, 2008
SolutionGuy
  • 331 Answers
SOURCE: Need to remove the back panel off of the Kenmore series 80
Don't do that, Mike! Access is from the front...
SG
Posted on Apr 07, 2009
I have a kenmore Elite series 80 stock #29852. It will not drain out after the initial wash, after the wash it just shuts off.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 17, 2011 | Kenmore 27342 Top Load Washer
I have a Kenmore 80 series washing machine model #110 stock # 22828 and this morning it will no longer fill up with water. The water just dribbles into the tub.
remove the hoses and clean the screens if this does not solve the problem you will need to replace the water valve
Jul 11, 2009 | Washing Machines
Kenmore 80 series washer. model #110.29812890. Water wont drain out. Wont spin either. Please help me. I'm so frustrated.
This would be a lid switch i carry them in stock and can ship out today yet... whirlpoolpartssurplus.com
Jun 23, 2009 | Kenmore Washing Machines
How do you tell how old a kenmore Washer model # 110.82982100 is?
there should be a date on the same label... it will read the month and year such as 02 or something. it's randomly placed but it is the date.
Feb 22, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 80 washer top load
Sounds like the clutch/brake assembly is slipping.
Feb 17, 2009 | Kenmore 15864/15862 Top Load Washer
Need cu size of my broken washing machine.
it is a 3.0 cubic foot.
  • I would do some research before spending a lot of money on a front loader.
Aug 05, 2008 | Kenmore 24032\24036 Top Load Washer
Sears Stock# 28803 / Model# 110.28803890 / Kenmore 80 Series
this sounds like the direct drive coupling between the motor and transmission. very common problem and not very expensive. look under the machine and and between the motor and transmission you will see a round rubber coupling and 2 plastic pieces one on either side; they all connect together to mate the motor and trans without a belt.
Jun 23, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
