Question about Yamaha Boating
I have a 40hp yamaha outboard it starts great but when i put in gear it stops
    Sergeant:
  • 331 Answers
If it's a 2-stroke, have those carbs cleaned...
Then check if he runs on all 3 cylinders.
Posted on Sep 25, 2017
mcgyver468
  • 710 Answers
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
finish line
  • 207 Answers
SOURCE: replace impellor in yamaha 2 cylinder 40hp
take all bolts out on foot were the two mate drop lower unit down pull impellar cover will be plastic some what roun with a short molded inlet on top when u remove impellar be sure not to lose the key way and when u put the cap on the impellar be sure to rotate it so blades will ben\d in place make sure u dont pintch them when u bolt the cover down MAKE SURE WHEN YOU PUT THE FOOT BACK ON TAT YOU LINE UP THE IMPELLAR INLET WITH THE ONE COMMING DOWN FROM THE ENGINE LINE UP YOUR SHIFTER LINKAGE (TOWARD THE TRANSOM IS WERE IT IS LOCATED bolt it up test with a hose should be good
Posted on Jun 27, 2009
SOURCE: motor kills when put into gear
u have no spark in #2 cyl check for spark with plug if its week regap it
Posted on Jul 14, 2009
  • 677 Answers
SOURCE: Size of fuel hose
Mate.If the fuel hoes is no good,cut off about 1inch of hose and take to a hose supply shop.It will be cheaper than buying a 'real' part.Or take the whole thing.Make sure you tell them it's a fuel line to get the correct type of hose.Hope this helps
Posted on Aug 05, 2009
SOURCE: Re-assembling lower unit of 40HP Mercury 4 stroke
I found a lower gear case assembly diagram at http://www.crowleymarine.com/mercury_parts/6995/240.cfm which helped me understand how the shift mechanism works. This clued me in to the fact that I was missing the cam follower rod which I then found I had inadvertently mopped up in a shop towel when cleaning up spilled gear oil. After that discovery, assembly and operation was quick and successful.
Posted on Nov 12, 2009
I have a 1999 40 horse 2 cycle yamaha out board motor lrx what is the fuel mix ratio
Re: 40hp Yamaha oil mix?
50 :1
Yamaha recommends ringfree
have a look at you owners manual http://www.yamaha-motor.com/outboard...px?ls=outboard
May 14, 2018 | Garden
Hi, can you tell me the year model of my Yamaha 40hp outboard? Serial number 452214.
Search Results
Yamaha Outboard Serial Number Location and Model Identification ...
https://www.perfprotech.com/.../yamaha-outboards/yamaha-outboard-serial-number-l... The Yamaha Outboard Motor MODEL, PRE-FIX and SERIAL NUMBER are stamped on a plate attached to the transom clamp bracket. When ordering parts and/or accessories from our Yamaha OEM Online Parts Catalog it's important to properly identify the exact model you are dealing with.
Yamaha Year Models - Hunts Marine
https://www.huntsmarine.com.au/pages/yamaha-year-models This Yamaha outboard year model chart will only work for Asia Pacific distributed engines. If you have a Yamaha engine that has been bought in from America or E. ... For Asia Pacific engines your year model code is found on the bottom right hand corner of your serial number decal. It will be a single letter as per the ...
Decoding Yamaha Outboard Motor Model Number and Manufacture ...
www.murrayyachtsales.com/decoding-yamaha-outboard-motor-model-number-and-... Dec 30, 2015 - Decoding Yamaha Outboard Motor Model Number and Manufacture Date (MFG Date)
Yamaha Outboard Serial Number Lookup
uvgb.you4k.top/ By Darnell Zacharias. DOWNLOAD Yamaha 60HP (60 HP) Repair Manual 1984-2009 Outboards 8.8. By Michael Hornby. HOT. How To Decode A Suzuki Outboard Serial Number 8.4. By Ralap James. Mako 261 Center Console Boat For Sale at Unreserved Auction (Inv.3368) 7.1. By Aldrich Child. yamaha 40hp 2 stroke ...
Outboard Spares YAMAHA Model Year IDENTIFICATION CODES ' eBay
www.ebay.com/gds/Outboard-Spares-YAMAHA-Model-Year...CODES-/.../g.html Outboard Spares Yamaha Outboard Model Year Identification Details needed for ordering outboard spares parts On the Serial Number Plate on most Yamaha Outboards it will be in this format 6E9-L-675634 The...
Jan 15, 2018 | Yamaha Boating
How much oil to be add to 25 ltrs petrol for 40hp Yamaha outboard??
50:1
1 liter of oil to 50 liters of petrol
1/2 liter of oil to 25 liters of petrol
Oct 03, 2014 | Yamaha 40N/50N 40 and 50 HP Outboard Motor...
Lost of electricity 40hp yamaha outboard
Search through the largest boating community for the best answer.
http://forums.iboats.com/yamaha-suzuki-outboards-26/
Apr 08, 2013 | Boating
40hp mariner sluggish
compressions more than 100psi ? carb clean and fuel not older than 5mths ? timing correct ? running on all cylinders ?
Mar 06, 2012 | Light Outboard Motor Boat Bass Fishing...
Free download for repair manual for an Evinrude 1987 40HP outboard motor
My outboard motor is old and used.When I went to run it for the first time everything worked except when I went to put it in forward gear the boat went slowly but when I gave it more gas the engine just reved up but the boat wasn't going any faster.The motor is 40hp gale model.I think because it is bought used the prop is not the right one and it seems like it's slipping as I go faster.
I would appreciate any feedback on this problem.
Thax, Don
Apr 27, 2011 | Clymer Marine Maintenance and Repair...
Apr 27, 2009 | Boating
Motor kills when put into gear
Feb 25, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Mike
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
