Question about Maytag MSD2756G Side by Side Refrigerator
Freezer not freezing
I have an electric Maytag Side-by-side and it is cold but it does not freeze the items in my freezer and will not freezeice cubes, also my refrigierator is not as cold as it should be. I have already replaced the starter switch.
  • carrcolumbus May 11, 2010
    I have an electric Maytag Side-by-side and it is cold but it does not freeze the items in my freezer and will not freezeice cubes, also my refrigierator is not as cold as it should be. I have already replaced the defrost thermostat
  • 77 Answers
If there is ice on the back pannel then your defrost element has gone bad. look at the back of the freezer and see if you see ice on back wall then that will be the problem all so check speed of evap. fan if rotating to slow this will cause a problem also in freezer....
Posted on Jul 28, 2009
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
Refrigerator is not very cold. Freezer is not
Our side by side did the same, started because the cooling coils on the bottom (although cleaned regularly), still overworked due to build up of dust and especially pet hair. The heating coil in the freezer compartment which prevents ice buildup in modern (frost-free) units kicks on full time and the compressor can't compensate, thus your perishables start to thaw. Luckily we were still under warranty. hope this helps you at least start diagnosing the problem.
Nov 24, 2009 | Maytag MSD2758GEW
Fridge not cooling, freezer not cold enough, ice maker not workin
is there alot of frost in the rear panel of the freezer if not the compressor is not start or getting hot because fan that cools it has failed is the part between the side/side door extremely hot if so check the cooling fan for the compressor
Aug 19, 2009 | Maytag MZD2766GES Side by Side...
Maytag freezer don't freeze food or make ice
There could be several things causing the frig to be cold but not cold enough. First check thermostat control and air control. Both should be set in the middle setting for normal operation.Next check to see if evaporater fan is running in freezer. It should be running whenever compressor runs and circulates cold air inside frig as well as freezer. Next check if condensor fan motor is running. It blows air over condensor coils to remove heat. Last ,check condensor itself for dirty coils. If they are matted up with hair dust,etc. it will cause poor cooling. you can give thorough cleaning with vacuum cleaner. Hope this helps
Jul 28, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag Plus side by side (Model MSD2356AEA)not cooling in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hhkgjd
Jun 09, 2009 | Maytag MZD2766GES Side by Side...
Freezing in refrigerator
Inside the fresh food compartment on top left there is something called an air baffle. It runs between the freezer and fresh food compartment and its purpose is to electrically control the amount of cold air coming from the freezer. Sometimes they freeze open and will not close. So you may need to turn off the refrigerator during the time you examine it. Look for ice blocking the movement of the baffle damper. Sometimes just one time clearing the problem is all you need to fix it. Let me know what you find and if you are able to get it going again, Thanks, Sea Breeze
May 20, 2009 | KitchenAid Superba Architect KSCS25IN Side...
The bottom crisper in my refrigerator is freezing everything....w
Look all the way to the rear of the control console in the fresh food compartment. Look up into the opening with a mirror. There should be a styrofoam diffuser (61005543) visible. If this is missing or damaged (many people think it packing material and remove it) it needs to be replaced. It spreads the air out rather than let it go right down the back wall to the crisper area.
One other thing to check is a tiny slot at the right rear of the same control console. a metered flow of air comes out the slot to the barrel shaped cylinder with the cold control capillary wrapped around it. Sometimes the slot gets water in it and freezes over. The unit will run too long and the cold air will settle during the off cycle and freeze items at the bottom. More often than not, when the slot freezes over, other items in the fresh food compartment will freeze......not just the bottom items.
May 02, 2009 | Maytag MTB2456G Top Freezer Refrigerator
Maytag MZD2766GE side by side, fridge not getting cold.
Your timer for the automatic defrost is defective. Replace it. If you thawed out the back of the freezer, this could be good for 3-7 days and it will freeze up again. I had the same trouble.
Bobby Johnson
Mar 08, 2009 | Maytag MZD2766GES Side by Side...
Check the back wall of the freezer section for signs of frost build-up. If the freezer coil is frozen from a fault in the defrost system your refrigerator will be the first to show signs of not cooling.
Dec 11, 2007 | Maytag MSD2436GR Side by Side Refrigerator
Maytag MZD2766GES side-by-side Refrigerator warm
is it frozen up? do you have any air flow thru the air tunnel from the freeze to the fridge? Check your air flow with the door switch pushed in. also check to see if the damper door opens... 1) if it is iced up you have a defrost problem. most likely a defrost timer. Turn off or unplug untill all the ice has melted off the evaporator back of the freezer..plug back in and it will work fine untill the ice builds up again. if this work you do have a defrost problem.. if not let me know and we can go deeper...
Aug 18, 2007 | Maytag MZD2766GES Side by Side...
Maytag MSD2756G Side by Side Refrigerator Logo
181 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
