Question about Kitchen Ranges
Dim Panel Lites
The display of the clock, oven temperature and so on is very faint. it is almost impossible to read. Can this be brightened ?
  • Anonymous Nov 23, 2007
    Going to try to repair the components tomorrow will let you know.
    Tim the Tool Man
  • 248 Answers
Only fix is to replace display board. This may be a seperate board, but often is part of the range control board.
Posted on Nov 22, 2007
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Maytag MGS5770ADC Two problems, 1) The temp.
HI
I see you have two different problems, one for the display you would have to change your clock, and because you did not give me a complete model number I can't get you the part number you need (four different colors possible on this model). Second, when an oven ignitor becomes weak it can extend cooking times and cause the same problems you have, also if you oven sensor is defective or has oven cleaner n it can cause temperatures to be erratic. I will and can help you but need a complete model number to get you more information. Located left or right side of storage drawer when its pulled out along the frame rails.
Good luck..
Jul 22, 2011 | Maytag MGS5770 Gas Kitchen Range
The LED display on my Thermador dual-fuel range has become very very faint and very very hard to read.
Cannot Read Display or See Temperature Thermador RDDS30
Fixyourboard.com can repair this failure for you. They back their workmanship with a two year warranty as well.
Contact them if you have any questions -- info@fixyourboard.com
May 26, 2011 | Thermador Professional Series PO301...
My clock display is faded, oven works, no temp readings
the e o c ( the clock) is at fault . and the diag is correct . most parts today only cary 3o days .. hope the hepled . mm
Jul 13, 2010 | Whirlpool RBD305PD Electric Double Oven
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
No digital display oven works
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 21, 2008 | Jenn-Air JJW8527C Expressions Collection...
Display panel
Dim display indicates a "failing" electronic oven control. It will continue to get dimmer and dimmer until it fails completely. You need to replace the "clock" (sometimes called the ERC <---Electronic Oven Control)
This is a tricky repair. Be sure you have the power off (at the breaker box) before attempting this.
Tracy
Oct 28, 2008 | Jenn-Air WW27430P Stainless Steel Electric...
Front panel with the clock settings is dim.
The only way to brighten is to replace the ERC or computer
May 04, 2008 | GE JKP45 Electric Double Oven
Temperature LED
no way to brighten with out replacing entire clock/control unit.
Feb 23, 2008 | Kenmore 72012 / 72014 Kitchen Range
Dim Digital Display
Connie P, Unfortunately it is not possible to make the display brighter. The only solution is to replace the entire clock/timer. The price for the part is less then a hundred dollars and if you will give me the complete model number and a color, I can help you to find the best deal. Gendos...post back
Jan 06, 2007 | Frigidaire FEF326 Electric Kitchen Range
Kitchen Ranges Logo
262 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
