Question about Fisher Televison & Video
How to get sound from Hitachi tv through fisher ca9025
No Sound from Fisher Box TV
I think your problem is with the scart socket . It most likely to be a dry joint on the pin where the sound goes in to the tv. you have to take back cover off the tv and turn the chassis over to do the dry joints if you can do it yourself otherwise get an engineer to do it. Good luck.
Aug 24, 2014 | Fisher Televison & Video
Hitachi Rear Projection TV - C4678FS - No Sound
i am having the same problem with my hitachi.. if you find anything out plz let me kno
May 09, 2010 | Hitachi Televison & Video
Hitachi projection TV Model 43F300 has no picture or sound?
did you ever find solution to this? I have similar problem.
Mar 28, 2010 | Hitachi Televison & Video
Hitachi tv no picture or sound.
my hitachi projection tv 53uwx10b screen is black with no sound or picture when the power button is on
Dec 29, 2009 | Hitachi 53UWX10B 53" Rear Projection...
42edt41a hitachi plasma tv went dark sound ok
sounds like your y and z drive boards over heated and need replacing...
May 31, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
No sound on 50 inch hitachi tv
Have you checked other inputs with a known good program source? Mute button on remote?
Apr 27, 2009 | Hitachi Televison & Video
The Dish remote control may or may not manage all functions of your Hitachi TV. This is a common problem with Dish and Comcast remote controls.
Oct 11, 2017 | Hitachi 31KX41K * 31" TV
How do I hook up a fisher stereo to my tv so I can here the sound from my tv on my stereo speakers?
You have to have audio outputs on either your TV or VCR/DVD to input into your stereo. Look for the red and white RCA connectors. Most TV's have RCA inputs for audio and video but not always outputs. VCR/DVD players all have audio out so if you have one of these units connect a RCA cable to a input of your Fisher amp. I hope this helps
Dec 01, 2008 | Fisher Audio Players & Recorders
Ineed a manual for a Fisher VCR
This may help.
Hold down tv power enter the 2 digit code using number buttons 0-9 then release tv power button
Admiral 05, 10 13 - Emerson 17 - Fisher 03 – GE 07 – Gold Star 01 – Hitachi 02 – JVC 15 – Magnavox 08 – Matsushita 12, 18 - Mitsubishi 14 – Panasonic 12, 18 - Quasar 12, 18 – RCA 06 – Samsung 16 – Sanyo 03 – Sharp 00, 13 - Sony 11 – Technolace 05 – Toshiba 04 – Zenith 09,10
And now the impossible clock setting. Turn unit on press clock while holding down the shift button. Press fast forward or rewind to change hours, then press adjust while holding down shift button to select the minutes again use the fast forward or rewind arrows to change minutes then again the adjust and shift combo to start clock.
Good luck Kevin
Fishers help line is 1-800-421-5013
Jan 29, 2008 | Televison & Video
Televison & Video Logo
Top Fisher Televison & Video Experts
matt martin
matt martin
romy sibug
romy sibug
Are you a Fisher Televison and Video Expert? Answer questions, earn points and help others
