Question about Pool & Spa
MyNitro pool cleaner does not run. - Pool & Spa
Just wondering if my baracuda cleaner can be run with the pool cover on. In ground pool with steps.
Much better if you have the hoses that sink, not float. The action of the hoses rubbing on the cover will affect where the cleaner goes. I would suggest not cleaning while pool is covered.
Aug 04, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Phantom does not want to run on bottom of pool
If your cleaner is running in top or automatic mode, try moving it to bottom. This is a common problem with these pool cleaners and owners often forget to adjust the dive setting. If the cleaner just isn't working at all, it could be low water pressure. Check your pump and filter for overfilling or debris, check all connections to make sure that they are secure, and check the flow coming from your in line to your pool cleaner.
May 23, 2010 | Hayward Phantom Pool Cleaner Complete with...
Dolphin Interactive pool cleaner stops running
If the dolphin is falling backward when it meets the water line, there is an easy fix. The automatic pool cleaners often have this problem. The easiest solution is to remove the handle floats and attach an 8 oz weight to the bottom inlet cover.
May 23, 2010 | Smart Pool Inc Dolphin Diagnostic...
MY POOL CLEANER WILL RUN FOR A FEW MINUTES, THEN STOP. SO METIMES IF I SHAKE THE HOSE IT WILL START AGAIN. ANY ANSWERS?
Hi , most pool cleaners run by the force of the sucked up water moving gears inside the cleaner .. if yours is this way, then any blockage in the cleaner or in the hose attached would restrict the flow and keep the cleaner from moving.
Apr 30, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Pool cleaner won't work
Sounds like the filter is getting very dirty and lowering the suction needed for the cleaner to run properly. If that is the case, there are two ways to address the problem. 1. Everytime the cleaner stops, clean the filter. 2. Use a manual vac and cut the pipe that comes off the top of the pump and goes to the filter. By eliminating the filter, you should be able to clean the pool a lot faster. You'll have to empty the pump basket often.
Mar 04, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Polaris 180 pool cleaner is running slow and not picking up trash
Hate to say it but they don't make them anymore. Spend the money and buy a Polaris 280
Jul 03, 2009 | Polaris 180 In Ground Pool Cleaner In...
Pool & Spa Logo
32 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
