Question about Mitsubishi Televison & Video
I have a mitsubishi wd65c10 tv. I turned it on and small white pin holes appeared. Each time I turn on more pin holes appear. What is this and how can I fix it?
  • Mitsubishi Expert
  • 296 Answers
The problem is a defective DMD chip.
Posted on Aug 11, 2017
  • 275 Answers
SOURCE: toshiba colorstream 27A33 TV
1.Are these lines only in the upper 1/3 rd portion of the screen?And is there a clear demarcation between this area and the lower portionb, where the image is perfect? 2.Or is thin Horizontal lines evenly spaced around an centimetre apart? If it is the first case, then there si a problem with your TVs SMPS. It is not generating the required regulated 110V required for the TVs functioning. If it is case 2, then there is a simple adjustment at the back - 'SCREEN'. This adjusts the Screen Grid Voltage, and by slightly lowering it, this problem will go away.
Posted on Sep 06, 2006
  • 8617 Answers
SOURCE: i have a mitsubishi tv
Problem in the vertical deflection circuit. Possibly the vertical output IC
Posted on Feb 10, 2008
  • 17 Answers
SOURCE: small white hole on LCD screen
Sorry to be the bearer of bad news, but you have what is called a "dead" pixel. Only repair would be to replace the LCD. I would like to think you would not spend $1400 to fix this problem.
Posted on Jul 11, 2009
  • 259 Answers
SOURCE: I have a 73" mitsubishi diamond edition tv and
this is when dmd (digital mirror device) ic begins to fail. these dots will become more numerous until they fill the screen. replacement of dmd board will solve
Posted on Sep 27, 2011
SOURCE: White dots appearing on Mitsubishi 1080p DLP tv.
Actually you must replace the DLP chip that is buried deep in the works of the tv. Unfortunately this can run into a nice lump of change. Do what I did. Perhaps you've heard the old addage
Posted on Apr 25, 2012
I installed a power steering pump for a 99 mitsubishi eclipse spyder question is, i noticed a leak under the car by the drivers side running through a tubing, what could it be?
Rack and pinion is leaking on it. It has 2 small metal tubes on it that transition the fluid from one side to the other when turning that are bad about getting small pin holes in them over time.
Feb 20, 2015 | Mitsubishi Cars & Trucks
After turning tv off two small white dots appear on the screen mitsubishi 837 dlp
Hello, contact Mitsubishi, they are sending out the chip at no charge to repair the problem, but they do not include the labor. if you are handy, there is a video on how to do it, otherwise when you receive the part contact a repairman. If they know what their doing, they should be able to do it there for around $100-$135.....tks
Sep 08, 2014 | Mitsubishi 837 Series 1080p Dlp Tv
Cracked screen & white dots appearing since the crack appeared
I have a Mitsubishi TV and had the same problem. There is a mirror that moves to control each pixel. When some of them fail to move you get the white dots. Google your problem and a company will come up(sorry forgot the name).,you can buy the new part from them and they have exact utube videos to help you do the repair. Took me about an hour. Part was around $150. Very rewarding feeling when you turn the tv back on with no white dots.Still dot free after two years
Mar 16, 2014 | Mitsubishi MBS73A Base for WD73C9 WD73837...
White dot in the middle of the screen
you have a bad dlp chip hear a link for you so it will help you to unstay.
how the light eng
Dec 23, 2013 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi DLP WD-57734 and white spots just started appearing I have owned the TV for 2 years and only one person in family uses it and not video games have replaced the lamp on time
The projection engine have problems,it the cause.Two years tv shouldn't have this problems already.Call talk to mitsubishi,might get some help the cost of the repair.
Jul 03, 2010 | Mitsubishi WD-57734 57" HDTV
Small white hole on LCD screen
Jul 11, 2009 | Sharp AQUOS LC-42D85U 42 in. LCD TV
32" sylvania TV thin line
There are bad solder connections on the vertical IC. This is a small flat IC attached to a heat sink. It should have about 9-11 pins and may be marked LA7837 or something similar. Resolder the pins on this IC and that should resolve the problem.
May 07, 2008 | Sylvania SRT2232S 32" TV
Solid Line Across Screen
Suspect the Light Engine part # 939P977010
Feb 21, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
