Question about Samsung Refrigerators
Flashing 39 e on samsung frige
I think it has to do with the ice maker, which hasn't been working, however we lost power for a brief time and when it returned this code was flashing.
roadbird383
  • 40 Answers
SOURCE: Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Posted on Dec 05, 2007
SOURCE: Maytag plus MSD2756GEQ ice maker not working
I had similar problem in that the fan in the freezer that blows freezing air into freezer and over to fridge was not working. Fridge was running warm (over 40 deg and freezer up near 20) Service call around $160 with new fan.
Posted on Apr 12, 2009
  • 10865 Answers
SOURCE: Ice maker not working
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on May 30, 2009
TheMobilian
  • 8220 Answers
SOURCE: Refrigerator Ice maker stopped working after power outage
Check THIS out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 26, 2009
cardenderek
  • 783 Answers
SOURCE: I have A GE Profile frige (PFSS9PKYASS) with a
are you sure you replaced with the right filter? how old is it?
FixYa Support
Posted on Aug 29, 2011
My refrigerator ice maker panel light is flashing off and on. What could be wrong with it?
sorry about this but why do you think you need to unplug it to clean .
Jan 18, 2016 | Refrigerators
What is 1F code on kenmore elite refrigerator
The Er IF error code indicates that the main control board detects that the ice compartment cooling fan is not working. This will cause a lack of cooling in the ice compartment and will normally result in no ice production. This is something that a service technician will usually need to correct.
Apr 17, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Reset the ice maker back to making ice again
Turn the water supply off to the fridge, make sure the bailer wire (ice level bar) is in the down position. let the Ice maker run thru its cycle. When the cycle is complete the fingers that push out the cubes should all be down. Unplug the fridge for about 5 min. During this time turn the water supply back on. Plug the fridge back in and let it run thru a few cycles. This should reset the icemaker cycle. As a note: you should be able to hear the water turn on with a solid thump as the valve opens to fill the cube trays inside the icemaker.
Sep 18, 2014 | Samsung Refrigerators
No ice from the door,.... water works fine,...... there was a very lite howl from behind the frige i pulled it out and vacumed the coils but it still did it seldomely as befor now that the ice maker doesnt...
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Aug 19, 2011 | Refrigerators
Just installed the water to the frige and it will not make ice has been running for 5 months without it being hooked up to water
may have bad water valve or ice maker. may have gone out on a fault turn it off on 3 times on some model that will Clare them
Sep 30, 2010 | Samsung RF265AA Bottom Freezer French Door...
We have a Samsung RS2530BBP. The ice maker works ok... water stop coming out... What do I need to do to fix the problem?
My Samsung RS 2530BBP frige Ice maker stop tp make ice.
The water tray stays verticly after pushing the reset button and the water pours in the container instead in the tray. I purchased a new ice maker but it did the same. Any idea how to fix it
Aug 12, 2010 | Samsung RS2530BBP (25 cu ft) Side by Side...
Kenmore refrigerator 71203100 ice maker does not make ice. I get water from the water dispenser inside the refrigerator, but no water in the ice maker. The metal bar used to turn the ice maker on and off...
The water inlet switch on the back lower is always the problem. It has 2 solenoids, 1 for water and 1 for ice. They never go out at the same time. Follow the water line to the frige and there it is. Turn the water off repalace the part and plug the frige back in. check for leaks and enjoy...
Mar 29, 2010 | Kenmore Refrigerators
Freezer goes off with brief power failure + does not reset
What Samsung said is untrue....
The fridge and freezer have default settings...8 and 38 deg. If it looses power and is restored it will default to that....
This fridge is a complex device and is compute chip controlled.
There are tests that you can run if you have the ability to read and follow directions....That will allow you to guide a service person to what your problem is. They will probably not have this information so I am giving you the link to the service manual...
Good luck
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Jan 29, 2010 | Samsung RB215LASH
We have the Kenmore 106.5703.601 side by side with an ice maker. We lost power for a whole day. The power is back, but the ice maker does not dispense ice. Water is dispensed through the door fine, and...
I think if you unplug the ice maker and remove it from the freezer to let the ice melt and dry out the Ice maker may start working again once you put it back in the refrigerator. If not we will need to check the thermostat inside the ice maker. Try that first and let me know the results. We will get it working I just need you to do this step by step until I locate the problem. But until the ice maker is dried out I cannot see if the thermostat will call for water when plugged back in. Let me know, Sea Breeze
Aug 16, 2009 | Kenmore Refrigerators
Refrigerators Logo
243 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
