Question about Maytag Washing Machines
On my maytag neptune washer when i push the start/pause pad on the machine it will not start.
  • 883 Answers
SOURCE: Maytag Neptune TL Washer
if this worked fine before, then I am only guessing that the water inlet valve has malfunctioned. try filling the machine with a garden hose...any change? if still no go, then be sure to have a shop-vac handy to remove the water you just added.
Posted on May 31, 2007
  • 11 Answers
SOURCE: Maytag neptune washer: will not start
plug a light into the washer outlet to check for elec current at this point before anything else.
Posted on Dec 28, 2008
  • 100 Answers
SOURCE: I have Maytag Neptune Washer.My touch pad
replace the user interface or touchpad control that is the control panel on your unit the whit part
Posted on Aug 09, 2009
  • 2694 Answers
SOURCE: Lr shows during spin cycle and pauses washer
you need to replace the motor and the motor control board,it comes in a kit,call your parts store give them the model number and the first two on the serial.common problem with the neptune,the wire harness that plugs into the motor is strait down,moisture runs down the harness and gets into the connectors,it's around 200 bucks for the kit
Posted on Feb 21, 2010
  • 79 Answers
SOURCE: My maytag neptune fav6800vaw washer
Fetch it over here - Maytag Neptune Washer Manual
Posted on Feb 28, 2013
Door will not unlock
Press the start/pause pad to stop the machine. • It may take a few moments for the door lock mechanism to disengage.
If that doesn't work, try unplugging the machine for a few moment. door lock should disengage
Feb 05, 2011 | Maytag Neptune MAH5500B Front Load Washer
My maytag washing machine,the start/pause does not turn on the machine.
check power and for correct polarity at the machine. check for continuity across the push to start switch while it is pressed down. if these are all checking out, think about a new door latch assembly. some machines automatically cut power to themselves if that switch is not functioning due to all the water that could possibly damage your home.
Oct 07, 2009 | Maytag Neptune Washer
Maytag MAH5500B FL Washer
Washer Stops
• Plug cord into live electrical outlet.
• Check fuse or reset circuit breaker.
• Close door and push the start/pause pad to start the clothes washer. For your safety,
washer will not tumble or spin unless door is closed.
• This may be a pause or soak period in the cycle. Wait briefly and it may start.
Check screens on inlet hoses at the faucets for obstructions. Clean screens periodically.
If the sreens are colged or even a little sirty it will stop the washer!
Won't fill
• Be sure the door is tightly closed.
• Plug cord into a live electrical outlet. (Tub light should illuminate).
• Press the start/pause pad.!!!!!!!!!!!!!!!!!
• Turn both faucets on fully.
• Straighten inlet hoses.
• Disconnect hoses and clean screens. Hose filter screens may be plugged.
• Open and close the door, then push the start/pause pad.
May be a bad door sensor!!!!!!!
Huuum
Pleae remember to leave a rating
Oct 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Aug 17, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Maytab Neptune FL washer
Hello ortizai and friends
Welcome
If the washer stops here are some reasons why this may happen.
The water lines have screens that can become clogged by accumulating debris in the water,
And then the machine will automatically shut down. And if its not completely blocked it will shut down intermittently!
1. Plug cord into live electrical outlet.
2. Check fuse or reset circuit breaker.
3.Close door firmly and push the Start/Pause pad to start the washer.
For your safety, the washer will not tumble or spin unless the door is
closed.
4 This may be a pause or soak period in the cycle.
5. Check screens on inlet hoses at the faucets for obstructions.
May be on hose ends too,and will be in the water inlets of the washer!!!!!!!!!!
Let me know who gets started, since there are multiple people with this problem.
Huuum
Please remember to leave a rating
I'm trying to figure out more ideas and will forward them soon.
Jun 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune
i have maytag neptune wash,modelo mah5500bww,my problem is: no starting,flashing start/pause button,after ten minutes is off.And now is ready for start when press start/pause button
May 20, 2008 | Maytag Neptune Washer
Maytag Neptune TL
The washer lid is open. The lid must be closed to start cycle. Close the lid and press Start/Pause.
Aug 21, 2007 | Maytag Neptune FAV6800AW Top Load Washer
May 30, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
