Question about Grilling
My smoker started, but then shut off, now i can't even get it to light?
1992 Buick Regal crank sensor
You may be right, but if it is a sensor you should get a check engine light and a trouble code for the lost signal.
Could also be something like a fuel pump relay or idle air control valve.
Aug 23, 2012 | 1992 Buick Regal
Grill lights, but does not heat up
if the flame just barely comes out, even though the dial is on high, shut it down, disconnect the tank, and reconnect it...making sure the fitting goes on straight and tight. Had that problem myself.
Jul 11, 2012 | Grilling
I just purchase this grill and was testing all burners .. all of them except the one going to the smoker worked fine .. tried to start it manually but it wont start this way either ... I am assuming that...
Yes, it is a Brinkman's problem. But, Home Depot will generally exchange it for a new one.
But, first, check the gas line running to the smoker burner. Does it appear to crimped or bent in any way? If this is the case, it won't allow gas to the burner. This may have occurred during shipping or it's a manufacturer's defect.
Also, try pushing in on the burner control knob when you manually try to light the burner. Since it's a low output burner for smoking, it may operate differently than the other main grill burners.
Hope this heads you in the right direction in resolving your burner problem.
Feb 24, 2011 | Brinkmann 5 Burner with Smoker 8101750S
Front Burners very low back burners not working
Front 2 burners light properly but back burner does not light. Checked cleaned spider guards, even removed the burner making certain it was clean. Reassembled the back burner but it still does not light.
Jun 23, 2010 | Weber Genesis Gold B Grill
How to charge an auger on traeger grill
Turn the control on high and wait about three minutes. Shut contol off and restart in about 1 minute, This should have enough pellets in the auger to start before the hot rod shuts off. You can also put a hand full of pellets in the burn pot and usually bu the time these pellets are burned out the others are there. A couple of cycles usually will start them.
Apr 16, 2010 | Traeger Industries BBQ100 All-in-One Grill...
Digital readout says eaaf
The unit will not turn on if the internal temp sensor is below 40 degrees. Warm it with a hot rag or hair dryer, or bring the unit inside to warm up and it will turn on. Once the unit turns on for a minute or so, it will work fine outside.
This isn't the ideal solution, but it will work. I don't know why they don't want the smoker to turn on when it is cold out (unless they are worried that the quick change in temp will damage the heating coil).
Nov 26, 2009 | Masterbuilt 20070106 Electric Smoker
New electric smoker no instructions!
Put some water soaked hickory chips and some liquid smoke with chicken stock or pinot grigio wine or both in the pan above the heater element. Put yer rubbed and marinated meat in top above the wood mix. Plug it in. Pop a top on a cold brew of yer choice. :D The idea here is low and slow. You want the meat to be at or around 200 and the smoke to flavor the meat. This ain't no grill in 30 and eat, it is a low and slow smoker. It takes all night or day to cook stuff correctly. Low and slow my nizzle :D Party on! What time do we eat? Saturday? You betta get started. LOL
Jun 25, 2009 | Masterbuilt 20070106 Electric Smoker
Grilling Logo
114 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
