Question about Blaupunkt Car Audio & Video
How to put the 11th pre set into a blaupunkt SKU 130416485 dab cd receiver
I have a blaupunkt woodstock dab 54 and its stuck saying wait 1h HELP!
by default you have 3 chances to enter your code, after then time is get much longer for you to wait. what you can do is still keep your radio power on and leave it for 1 hour, Do not power Off. the cycle of wait will reset. then you can try enter you code again. hope its help.
Aug 02, 2014 | Blaupunkt Woodstock DAB 52 CD Player
Can you give me the radio code for blaupunkt
The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
Jul 03, 2011 | Blaupunkt Nashville DAB35 CD Player
Intermittent bleeping on tuned - in -stations
You have the traffic updates on - I'm not sure the traffic function has ever really worked on the 52 but turn it off and you should lose the annoying beep. As an interesting but annoying aside, you won't find this info on the Blaupunkt FAQ page searching under 'beep' because they describe the noise as a 'peep'... go figure!
May 11, 2011 | Blaupunkt Woodstock DAB 52 CD Player
Blaupunkt rcm 104 master reset code
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Apr 04, 2010 | Blaupunkt Hamburg MP57 CD Receiver CD...
Need code for my bluetooth
you should put five times zero i.e 00000
Dec 11, 2008 | Blaupunkt Hamburg MP57 CD Receiver CD...
Car Audio & Video Logo
49 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
