Hoover HNL7166 'Start Delay' light flashing
My Hoover washing machine stops working about 10 seconds into any cycle. The Start and Start Delay buttons then flash together 10 times, there is a pause and they then flash together 5 times, a pause and flashing 5 times, and this continues. I've checked the filter and the pipes and can't see any issue there. The Hoover website is next to useless, the phone line had me answering automated questions for 5 minutes before informing me no-one was available to take my call, and the manual gives no clue. Can anyone help?
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Posted on Aug 10, 2010
  • GW Allen Feb 03, 2017
    It flashes 7 times Ive
    checked the motor it's turning freely. Proaction washing machine
Hello, I'm having the same situation, my washing machine stops working before 5ms and the start and start delay buttons flash together, with some pauses. What was the solution to your problem? Thank you
Posted on Nov 21, 2009
Just had an engineer out to look at my machine. Different problem - machine won't start, door won't lock but all programme lights work. Ran the test cycle and machine passed. It appears that i need a new board. He did ask if any lights came on - as the machine does this to show you the fault code - that might be what your machines are doing.
Posted on Nov 24, 2009
SOURCE:
Hoover HNL 662. 'Delay start' light comes on and stops machine
my hoover nextra hnl 662 want wash or spin and the delay staart light flashes 5 times please help iv only had the machine a year and had nothing but trouble with it wouldnt recomend one of these washing machines to anyone jakki
Feb 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
Hoover HNL7166 delay light flashing 5 times every 10 secs
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 12, 2009 | Washing Machines
My washing machine is not finishing a cycle and is not pumping out the water. It will start a cycle, but then it will stop half way through, and the "delay/start" button will flash red. Please help
i had same issue turned out pipe was blocked and washing machine gave up trying to get rid of water, so would stop, cleaned filter, uncloged drainig pipe and was good to go
May 12, 2009 | Hoover Nextra HNF 3157 Front Load Washer
My hoover washing machine 1400 spin 8kg hd vision hd
Hi On my washer when I press the start button when allready in opperation all the lkights flash and it stops as this second press of the button pauses the machine and need the start button to be pressed again to restart the machine
Hope that is cleas and helps
Angela
Jun 22, 2008 | Hoover H130E Front Load Washer
LOC code flashing on washing machine
Pressing the options and select buttons simultaneously for 5-10 seconds worked. For me it happened this way: on the first attempt, with the indicator lights already "timed-out" and off, pressing and holding the options and select buttons simultaneously for 5-10 seconds caused the lights to come back on and flash the "LOC" code again. But holding the options and select buttons together for 5-10 seconds a second time caused the indicator lights to stop flashing, and allowed me to start the cycle.
Dec 01, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
4,020 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
