Question about Maytag Dryers
Can I find a picture of the correct wiring for Maytag lsg7806aae console? Technician disassembled, then left :(
    Top Expert:
  • Maytag Master
  • 45,144 Answers
Maytag might be able to supply one.
Posted on Aug 11, 2017
4 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: How to disassemble Maytag Washer MTW5740TQ0
Your console has a retaining clip under the front corner on each side. You simply insert a putty knife under the console at the corner and push straight back, while pushing the console back with your other hand. The clip will release and the console will pop up. You can use the following link for reference (step 2 b.):
http://www.fixya.com/support/r599953-replacing_drive_motor_kenmore_or
Your washer has the Maytag name, but is manufactured by Whirlpool and has Whirlpool parts, so these steps are for your washer. The link I provided explains how to access and remove the drive motor. If you are having problems with agitation and spin, you may have bad motor coupling. The next explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The steps are almost identical and the part number (if needed) is included.
You can view an excellent exploded view diagram of your washer at appliancepartspros.com. Section 4 shoes the console and retaining clips (item 3) that I'm talking about.
If your washer fills, then stops, or agitates then stops just before the rinse cycle, this problem is attributed to a lid switch malfunction.
I'm adding all these remarks, because you never stated what symptoms you were experiencing. If you have questions, please let me know. I hope you find this information helpful.
Posted on Aug 06, 2009
  • 62 Answers
SOURCE: need manuel for maytag stacked washer/dryer unit model lsg7806aae
go to this link and download the manual:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=LSE7806A&siteCd=MT_EN_US
Posted on Sep 02, 2009
  • 45 Answers
SOURCE: Maytag LSG7806AAE that is 8 years old but never
These can last up to 15-20 years if you take care of them.
Posted on Apr 28, 2010
Apr 28, 2010 | Dryers
How do I replace the lid switch on a Maytag
Well the model # you listed goes to a Whirlpool machine so here goes.. The screws that hold the control panel on are located at the rear bottom of the end caps for the console/control panel, not the screws at the top of the control panel..
Once you remove those screws the control panel should slide forward 1/2 inch or so the up, and flip right over backwards towards the wall.
Once that is flipped up you will see the lid switch located in the left front corner under that console. Remove the 5/16" ground screw from the green wire, lift the connector release and remove the wire from the switch. Then carefully depress the plastic tab to release the switch and it should more or less lift right out.. No need to disassemble the entire cabinet.
whirlpool #8318084 $15-20 buks depending on where u are..
best of luck, have fun,
ttfn
Feb 03, 2010 | Washing Machines
Dryer gas heat not staing lit
It is probably electronic gas valve, or safety valve that let the gas flow and shuts off immediately. Better take it to the repair shop will save yourself $75.00 service fee.
Dec 30, 2009 | Maytag LSE7806A Top Load Stacked...
Hello,my name is David ,I have a Maytag washer maytag lsg7806aae
can you tell if the motor is turning,if so it could be your idler pulley and youve lost belt tension,otherwise it could be your motor start capacitor if motor spins freely with power and belt off
Sep 01, 2009 | Dryers
My Maytag model lsg7806aae takes too long to dry the clothes
check for restriction in vent duct. if there is good heat but takes to long to dry then there is restricted air flow through unit.
Jun 24, 2009 | Dryers
The OD code will not clear
The Service Manual for reference. Sears Parts Direct for reference
od alarm means the Control Board has not seen a lid open condition for three complete wash cycles. I suspect the left lid lock and or lid magnet issue.
First check to see if you can clear the od error with an external magnet as shown in this picture.
Pic of left bumper and a external magnet;
If it does then you have a lid magnet out of position. You will need go thru the process to disassemble the lid and check that the lid magnet is in position. First picture on page 35 of the SM shows the lid magnet.
You could have an issue with the left lid lock with corrosion and a possible open lead on the reed relay in the left lid lock. See the broken black wire connection as shown in this Pic
In the interim you could power down the machine by removing the 120VAC power cord from you wall receptacle then re-power up. That may give you three more wash cycles before the od alarm is triggered again. If the magnetic reed relay lead is open as shown this may cause a OP alarm to the console.
Post back if you have questions. Rich
Jun 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Insufficient heat
I would start by checking the venting for obstructions. disconect the hose and try a load. dont leave the hose off for too many loads as the lint and moisture will go into the room.
Jan 27, 2009 | Maytag LSE7806A Top Load Stacked...
My Maytag Model# LSG7806AAE Seriel# 15951872UW washer won't fill with water. I advanced the switch and it goes on when you get to the rinse and spin, but still no water.
After having a repair guy quote me $450 to fix this problem, I took it on myself. I first changed the lid switch as the repair suggested. No luck. Next, I changed the washer timer. Still no luck. Next, I disconnected the water tube and filled the washer with water ( a step I wish I had done first) and turned on the machine. The machine spins, drains, etc but still didn't fill. I changed the water valve. Still no luck. Finally, I changed the 50 cent fuse in the front left corner of the washer unit. Success! The fuse was the problem. The washer now fills correctly.
Jul 24, 2008 | Maytag Washing Machines
Dryers Logo
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
