Question about Sanyo DSR-3706 Video Recorder
Sayno video recorder no signal - Sanyo DSR-3706 Video Recorder
    President:
  • 563 Answers
G'Day!
If the unit was working and now without anyone touching the connections it is reading no signal, short of doing a reset, unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the dvr that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 27, 2009
My Insignia DVD/VCR will play VHS tapes, but does not record on them when I put a blank in and it shows recording on the VCR, but when I rewind and playback, just get blank sometimes wavy nothing and snow!...
First thing to check is does the video actually get a TV signal to record? When you set the recording going is the channel viewable?
Next thing to do is clean all the video heads, this will include the erase head! If you still can't get it to record and the VCR does pick up a signal to record, then there will be an electronic fault that is causing the no record signal.
Aug 20, 2013 | Insignia Televison & Video
Video source not detected by dvd recorder
If the recorder accepts RGB see that your source puts out RGB or video. If the recorder is set to S-video the source must send an S-video signal. Match the signals.
Aug 14, 2013 | Televison & Video
Trying to connect Magnavox MWR 10D6 DVD/Recorder to Sanyo HDTV. TV is connected to Dish network through coax. cable.
Unfortunately, the Magnavox MWR10D6 recorder can not record HD signals. It's only video inputs are coax (RF) and composite video; both are limited to 480i (SD). NTSC (analog signals) are translated to video.
Your best recording option is to connect the composite video output of the Dish receiver to the video input (yellow for video, red and white for audio) of the recorder. Then set the receiver to the channel that you want to record and set the recorder to Line In.
HD recorders may exist. They are much more expensive than the SD versions.
I wish that I had better news for you. The manual for the MWR10D6 is available from Funai here: http://www.funai-corp.com/support/om/MWR10D6.pdf .
Apr 18, 2013 | Philips Magnavox MWR10D6 DVD Recorder
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Mar 19, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Im trying to connect my unit to my tv to record shows and i having trouble doing so please help i am hooking it up wrong
For OTA or CATV signals, you need to daisy chain the coax from the source (antenna for OTA) to the coax input on DVD recorder and then the coax out to the coax input of the TV. If you have a set-top cable box with an incoming CATV signal, it should be connected between the DVD recorder and the TV.
The unit can tune in and record 480i (SD) ATSC (OTA digital), NTSC (OTA analog), analog CATV and digital CATV channels.
A satellite receiver or a non-CATV cable box should get the incoming signal first and then have their composite video output (A/V) connected to the DVD recorder composite video input and then their coax (RF) output (if present) gets connected to the TV. For these, you would record from the IN1 or IN2 (press Select Input) instead of selecting a channel. Then connect the composite video out on the recorder to the TV's composite video in.
Digital signals are either enough to tune in or give no signal. So check that your antenna is correctly oriented for OTA.
Separately, you can connect the video signal when playing DVDs via composite (good signal) out and component out (better signal) out to the TV's matching input. For the component video, the sound is carried on a separate cable. Then set the TV to the input source.
In the case of wanting to watch a VHS tape while taping to a DVD, do not use the Component video source, set the TV to Input 1 (composite).
I hope this helps.
(you can get a copy of the manual here: http://tv.manualsonline.com/manuals/mfg/panasonic/dmrez47v_dmrez475v.html )
Nov 25, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
I am currently converting all of my old videos to dvd,my dvd recorder RH266 will not record some old videos, message "Record signal blocked" comes up, and record switches off. This happens even with some...
The recordings probably have a anti-piracy copy prevention signal imbedded which will block any attempt at copying.
There were several techniques used.
Mar 16, 2010 | LG RH266 Recorder
How may i hook the phillips dvdr3455h/37 to record from my fm tuner,i have it hooked up as follows audio out on philips to tape in on amp and audio in on phillips to tape out on amp,but when i press any of...
The dvd recorder uses the video signal to detect, thus it will not detect the audio as a signal. I believe there are "boxes" you link in somehow to "fool" the dvd into thinking it's recieving a video signal, but I don't know where to get them.
Jun 14, 2009 | Philips DVDR3455/37 DVD Recorder/HDD...
Waiting for input signal
It's a protected video. The VRD-MC5 will not burn a VHS or input that has been protected.
Jan 09, 2008 | Sony DVDirect VRD-MC3 DVD Recorder
Sayno Tv
You didn"t say already working in AV mode or not. Suppose if it is worked means this is the simple one just change programme (-) button in TV front panel till becomes 1 or 0. After 1 or 0 again you press down the same button you get AV mode. Even you won"t get try in menu features to change AV mode. Even you won"t get there is a problem in Micom section. Technical persons only sort out your problem by changing EEPROM ic. I hope the above information is useful to you.
Sep 02, 2007 | Sanyo DS31520 31" TV
Sanyo DSR-3706  Video Recorder Logo
44 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
