Question about Ovens
Why I can't cook anything in the pressure cooker longer than 40 minutes.
When I try to cook meat in the meat setting the timer will only let me set it on 40 minutes. The meat is still tough and I have to close it and set the time all over again. What am I doing wrong?
  • Ovens Master
  • 15,628 Answers
You did not list the make and model and you must consider altitude, type of meat, pre preparation and the function of the valve system on the unit. If the valves are not working, no pressure is building also the gasket on the unit can cause the same issue.
Posted on Aug 11, 2017
  • 4102 Answers
SOURCE: Smeg dual fuel cooker model number UK80MFX1
it sounds like you have a problem with the thermostat that tells the oven to switch off when it gets to the right temperature if the temperature exceeds the setting you choose then the oven will shut down as a safety feature you can get these replaced but because of the age i wouldnt know where to get them from if you get somenody to come and replace it for you it would be cheaper than buying new cooker then this should get your cooker working nrmally i had this problem but on a different make and model but doing this dolved the problem the only problem i did have was locating the right part number but after i got it it only took repair man 1 hour to fit it and done it for less than 50 quid hope this is some help ..................................
Posted on Nov 05, 2007
melnavz
  • 1226 Answers
SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Posted on Apr 10, 2008
amgm
  • 32 Answers
SOURCE: trying to set oven timer
Hi, switch off the mains for the cooker, wait for about 15 seconds then press the 2 buttons on the left and hold them, and then press the - or + button to set the time.
Cheers
Posted on Feb 19, 2009
SOURCE: beko dvc6531 cooker
i can send u a copy of user manual if you need one you have to hold the first two buttons in then move time with up or down please email me if you need more info andyali09@btinternet.com
Posted on Aug 30, 2009
barkencoa
  • 3463 Answers
SOURCE: Creda Solar Plus Model 48339N Clock/Timer not working
You have to remove the complete top assy as one unit. To do this you need to remove the side panels, there are screws at the rear, and some at the front of the oven, you will then be able to see the screws securing the top
The top then slides towards the rear, then you can gain access to the timer unit.
Hope this helps.
Posted on Dec 08, 2009
How do i set the time on w westinghouse pgn659s wall oven?
Instructions below.
  1. 1 Fill the insert of the Corningware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  2. 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  3. 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
thank for visit.
Oct 09, 2010 | Ovens
Single over cooker turns itself off after 40 minutes.
the timer in the oven that tells the oven to turn the heat off is malfunctioning and needs replaced.
Nov 25, 2007 | Ovens
Turn on oven cleaning, but clean indicator stops after few seconds
hello
what this need is to set the reprograms
here are solution below
You can set the timer on a Corning ware slow cooker to automatically switch to a warming setting when you estimate Foods will finish Cooking The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the Work, and come home to a fully cooked meal.
  • Fill the insert of the Corning ware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • hope this hope ?
    thanks
    Oct 03, 2010 | Ovens
    Resetting the clock
    You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
    INSTRUCTION BELOW.
  • Fill the insert of the single oven slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • Please rate this solution after use.
    Thank you and thanks for using fixya.
    Oct 03, 2010 | Maytag CWG3100A Gas Single Oven
    Pleace HELP!!! How do I set the clock on my Russell Hobbs RHM1712 microwave?
    You can set the timer on a range slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking. The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day.
    Set the timer on a range slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
    Fill the insert of the range slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
    thank and thanks for using fixya.
    Aug 20, 2010 | Ovens
    I didnt get a user manual with my creda cooker dont know how to set the timer
    try this site for your manual
    kitchen.manualsonline.com/manuals/.../creda/creda_oven_product_list.html
    hope this helps
    Apr 28, 2010 | Ovens
    Lost handbook for cooker. Cant remember which
    There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
    TO SET THE TIME OF DAY
    Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
    TO SELECT AN ALARM TONE.
    Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
    Releasing the button after the tone has sounded will automatically set that tone.
    SETTING THE MINUTE MINDER.
    Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
    You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
    After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remianing time.
    If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
    Dec 13, 2009 | Stoves 720EF Electric Double Oven
    How to use the 5 button timer
    Sep 26, 2009 | Stoves 720EF Electric Double Oven
    How do I set the clock time on Stoves Cooker efa700h. I would assume the clock is the same on most stoves models
    Aug 02, 2009 | Stoves 720EF Electric Double Oven
    Trying to set oven timer
    Cheers
    Feb 19, 2009 | Belling XOU482 Electric Double Oven
    Ovens Logo
    32 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
