Question about Generac Electrical Supplies
My 6600 Generac keeps tripping the 2 30 amp main breakers after less than a minute after resetting. What's wrong?
  • Anthony Cropper
    Anthony Cropper Aug 11, 2017
    Even running only interior lights.
  • Generac Master
  • 10,884 Answers
Too much of a load maybe?
Posted on Aug 11, 2017
Jimster
  • 240 Answers
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Posted on Feb 02, 2008
22yooper
  • 828 Answers
SOURCE: RV ROOF TOP AIR CONDITIONER TRIPS BREAKER
Possible low voltage condition would cause that kind of a problem. To small a cord without the ability to carry and maintain the voltage would cause a voltage drop. I would test the voltage supply and make sure it is within 10% of that required for your A/C to operate properly.
Posted on Jun 16, 2008
  • 389 Answers
SOURCE: keeps tripping the main breaker on the electrics
Sorry if this is stating the obvious, but this is a sign of an electrical fault. Specifically, what trips the main breaker is leakage to earth (ground). You need a qualified electrician.
Posted on Feb 18, 2009
dragonsthatk
  • 547 Answers
SOURCE: Pool pump breaker keeps tripping
should be a 60 amp breaker
Posted on Feb 19, 2009
thedayos
  • 57 Answers
SOURCE: My new maytag centennial electric keeps tripping
Hi Matt
I'm not sure that swapping out the breakers to higher rated ones will give you a solution so I'll throw in 2 cents to see if my advice holds true. Let's start by asking this. Is the appliance "rated" at 220 volts at 30 amps per leg. I assume this from your post as to what it has been rated. Next - How long is the "run" of wire from the junction box to the outlet where the appliance plugs in? This usually does not matter in most households but if the run is of significant length it may need a larger gage wire to support the current draw of the appliance. Lastly, and perhaps most importantly, are the lugs and wire connectors tight at the outlet, the plug, and the breaker box. A loose connection will ramp up the current fast. This is assuming the first two items were met. Tell me if any of this helps and we'll work it out from there.
Thanks.
Len
Posted on Feb 28, 2009
I HAVE A 2 1/2 TON PACKAGE HEAT PUMP . THE60 AMP BREAKER AT THE DISCONNECT BOX KEPT TRIPPING . I DISCONNECTED THE HEAT STRIPS AND NOW THE 60 AMP BREAKER ISNT TRIPPING . WHAT IS CAUSING MY BREAKER TO T
You need to check the current rating of your heat strips. If it is more than 60 amps then you need a bigger breaker. If 60 amps or less then your heat strips are going bad. Also make sure your fan turns smoothly without any wobble.
Jan 06, 2014 | Electrical Supplies
15 AMP breaker keeps tripping
do a amp check on the compressor and fans.That will tell you exactly what is overloading.
Apr 21, 2012 | Kenmore Freezers
Main breakers keeps blowing what is the reason i had the electrical company check there stuff up to the house said everything was ok no smaller breakers are blowing just the 200 main is it possible i did...
Add up all the amps from active breakers. Do they add up over 200? If not, then I suspect a bad main breaker. If they do, then you need a larger service box and or main breaker.
Sep 24, 2017 | Siemens 200 Amp Main Breaker 30 Spaces 40...
Breaker installed on generator. Keeps tripping under no load after approx. 1 minute of generator running
A tripping circuit breaker is an indication of an overload. You say there is no load on the breaker - how are you making this determination? Are you using an amprobe or some other meter?
A circuit breaker with NO load shouldn't ever trip. Likewise a circuit breaker carrying up to 80% of of the current it is rated for shouldn't trip either. Circuit breakers that carry more than 80% of their load will trip - if the load remains connected long enough. This is called "duty factor" or "service factor" The greater the load is in excess of 80%, the less time that the breaker will carry it before tripping.
An example of a 100 amp breaker with different loads on it (this 100 amp value was chosen for ease of doing the math):
80 amps - never trips
85 amps - trips after 48 hours
90 amps - trips after 16 hours
95 amps - trips after 8 hours
100 amps - trips after 4 hours
105 amps - trips after a few minutes
120 amps - trips after a few seconds
150 amps - trips instantly
This is only an example to show how a certain circuit breaker might trip under a load less than the rating stamped on the body or handle.
A circuit breaker that trips with no load or a load equal to or less than 80% of its rating is most likely defective. You need an amprobe or ammeter for amp readings. If the load is found to be 80% or less, there may be an issue of harmonics that is causing the tripping. You'll need to have special equipment and qualified persons to check harmonic problems. Most harmonic problems occur when the loads are not linear device (transformers). Examples of non-linear devices are "switching" (or solid state) power supplies like those in computers.
I hope this helps and good luck. Please rate my reply. Thank you.
Apr 07, 2011 | GE Tjk436f000 3pole 400a 600vac Circuit...
Heater shut down sometime in the middle of the night and now it will not turn on. I checked the breaker box and when I flipped the master switch, it came on for about a minute or two but was blowing cold...
Hi what has happened is, this is a heat pump. The main breaker keeps tripping because the compressor is shorted. I hate to give you this news, but anytime a unit keeps tripping the main breaker on a heat pump, the compressor is either locked up and drawing enough amps to trip the breaker, or it is shorted internally. This is something that you will have to call a tech out on. I am sorry to give you this news, but this is all it could be. If it came on for a minute blowing cold air, the compressor wasn't running due to it being shorted out. This is your only choice is to call someone out to check it. If this is a older unit, you may be better off replacing the outdoor unit. If not, get an estimate on a compressor change out. I wish you all the best on this, and I know this is bad news, but these things always happen at the wrong time of year. Please keep me posted.
Sincerely,
Shastalaker7
A/C, & Heating Contractor.
Dec 28, 2010 | Carrier 38CKC042 Air Conditioner
Installed a generac 20kw about a year ago, ran fine untill 2 days ago. During a utility outage, generator ran for about 30 minutes and then stopped producing power while still running. All mains were still...
With the engine off, check the exciter brushes and slip rings which supply magnetic power for the alternator winding in the stator. Also, check the motor-to-alternator mechanical coupling. Check the breakers for tripping. To service beyond this point requires a schematic of the alternator, a voltmeter, plus knowledge of what the schematic is telling you. Good luck!
Jul 25, 2010 | Generac Power Systems Generac 5525 20 Kw...
One of 2 circut resets keeps tripping on our Generac generator
If it's tripping a breaker that usually means there is to high of an amp draw on that curcuit.
Are you plugging more things into that particular curciut (or just different but higher amp draw items) than you did last year?
It's also possible that one of the items plugged into that curcuit is wearing out and drawing more amps than before.
If you have an amp meter, plug everything back up just the way it was when you were having problems. Check the main wire going to that curcuit. (right at the breaker)
If your amp draw is greater or nearly the same as the amprating of that particular circuit, then thats your problem.
To many things/to high amp draw on one circuit.
If it is not near the amp rating, and you are getting proper voltage to the breaker, then I would replace that breaker.
Dec 30, 2008 | Electrical Supplies
Electrical Supplies Logo
50 people viewed this question
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
Ottoniel
dennys23601
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
