Question about Toaster Ovens
When I plug in the cord on my toaster oven it says erl.
How can i mute the dinging noise. im an axity teenager in need of food at 2AM
Try setting the timer for 5 minutes more than you need. When the timer reaches the time you need (before it dings), unplug the oven. Be sure to pull on the plug and not the cord to prevent damage to the cord.
Mar 18, 2016 | Oster Toaster Ovens
Delonghi xr640 toasting-finished chime not working
follow this steps and fix it. God bless you
f the oven doesn't work at all, make sure the circuit breaker or fuse is on at the electrical service panel and test the electrical cord . If the oven doesn't work on its toaster and oven functions, test the main switch . As needed, check the fuse .
If the toaster function doesn't turn off unless the door is open, test the solenoid, the switch and if necessary, the thermostast.
Location of the typical toaster oven's thermal fuse.
If the toaster oven stays on when the door is opened, check the main switch . If the oven doesn't heat, test the heating elements.
Oct 27, 2013 | DeLonghi XR640 Retro 1500 Watts Toaster...
What is the electrical rating of the Convection Toaster Oven Mdl #169127/169140 as the manual states that the extension cord should be at least as great as the electrical rating of the appliance. I will be...
most appliances that have heating elements are rated between 1000 to 2000 watts, which will give you a current rating of between 5 to 10 amps, check at the back of the oven for the ratings. use
the formula P=VI, P(power(w) and V(voltage) and I is the current(amperes). the cord will have a
current rating, go for around 15 amp rating
Jun 17, 2011 | GE 168947 Toaster Oven with Convection...
Bush toaster is blowing fuses when switched on
It appears that there is a short in the toaster somewhere. Many times it is the cord. See if you can remove the cord and then test to see if the two leads of the cord are shorted with an ohmeter.
Bob Janelli
I’m happy to help further over the phone at https://www.6ya.com/expert/bob_62dfa2f81bb55288
Oct 01, 2009 | Toaster Ovens
Toaster Oven Unresponsive (Farberware Model# FT032055
I would check the cord or the plug before anything else. Plug another appliance into the outlet if it works try bending the male plugs on the cord slightly and try again. If this doesnt work call the man.
Feb 24, 2009 | Toaster Ovens
Roaster OVen Cords
The new roaster ovens have a cord that is hardwired into the base. This became necessary for safety reasons. However, if you are lucky enough to have a very old one, cords that fit can be purchased at local hardware stores. They are larger than coffee pot cords but are very similar in design. Those plug in to a receptacle recessed in the base. If the cord is hardwired into the base, you will need to provide the expert that helped you with the information he requested. Thanks again for using FixYa.com
Jan 19, 2009 | GE 168947 Toaster Oven with Convection...
Toaster oven power failure
Call Cuisinart - that product has a 3-year warranty.
May 06, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
Why does this toaster oven cord gets hot? Is it safe?
I would make sure the cord doesn't get too close to the back of the oven. Make sure it has room between the oven and wall and isn't trapped under it or direct heat.
I had my cord get squeezed between the machine and the wall and my cord melted.
Jan 03, 2008 | Oster 6230 Toaster Oven with Convection...
Toaster Ovens Logo
208 people viewed this question
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Toaster Oven Expert? Answer questions, earn points and help others
