Question about Soleus Heating & Cooling
I have a portable Soleus 8000btu and as soon as i plug it in the wall socket it's display lights up for 3 seconds then after it shuts off (never runs at all) what could be the cause of this problem?
  • Keith Aug 11, 2017
    also i checked to see if there was any water and there is nothing to drain
2 Suggested Answers
  • 459 Answers
SOURCE: I have a portable soleus air conditoner and as soon as i plug it in it lights up, doesent run, then shuts off right after
Drain the condensation water tank out.
Posted on Aug 08, 2017
My Haier HPY08XCM 8,000 BTU Portable Air wont cool. How do I troubleshoot?
  1. HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015
    ? 1:59
    www.youtube.com/watch?v=kx1_1q4ByC8
    Apr 19, 2015 - Uploaded by Denada Pinoy
    In this video I review the HAIER HPY08XCM 8000BTU Portable Air Conditioner 2015. ... No comments to display ... CommercialCool 12,000 BTU Portable Air Conditioner with Timer with Dan Hughes - Duration: 9:24. by QVC ...
Jul 21, 2015 | Haier HPY08XCM 8,000 BTU Portable Air...
My Soleus Air HM2-15R-32 displays an E4 LED when turned on. How do I reset the code.
try unplugging it from the wall for 15 seconds and then plug it back in.this normally works for me.if it doesn't work then let me knoe
Jan 23, 2013 | Office Equipment & Supplies
After one year of usage my portable A/C drains on the floor approximately 3pint / hr. Unit was raised so that the water can drain into a container without weting the carpet . This situation needs to be...
This is what the manual says:
When the internal water container is full, the back light on the LCD display flashes. The unit will shut off automatically, beep 15 times, and must be drained before it will restart.
To Drain the Unit: switch off the unit and remove the plug from the wall socket.
• DO NOT MOVE THE UNIT. Doing this can result in water
leakage, damaging your floor or carpet.
• Place the drain pan on the floor under the drain cap.
• Remove the drain cap and the rubber stopper from the
drain, and let the water run out. Partially fill the drain pan,
replace the rubber stopper, and empty the drain pan.
This procedure must be repeated until the unit is empty.
• Replace the rubber stopper and drain cap.
Put plug into the wall socket, and switch the unit on.
The warning signal should be off.
For Continuous Drainage: • Switch off the unit and remove the plug from the electrical outlet.
• Remove the Drain Cap and Rubber Stopper. Drain if necessary.
• Connect a Drain Tube (not included) (20mm / 3/4" inner dimension) on to the water outlet.
• Place the other end in a drain. Make sure the tube is free from twists and bends.
The tube must decline over its entire length.
Jun 06, 2011 | Amcor PLM12000E Portable Air Conditioner
Hi i have a problem about my lcd viewsonic va702, when starting my computer i can see the image for 1 sec then it turn black ...lcd light is ok and computer too already tried with other lcd all works fine...
this works for Dell monitors with a similar problem: shut down, turn off monitor and pc, turn off at wall socket, and remove power plugs from wall socket. wait about 30 seconds. plug back in, turn on, and all should be well? I have used this 3 times on a Dell PC with a Viewsonic monitor.
Dec 23, 2010 | ViewSonic VA702b 17" LCD Monitor
Yellow light is on and monitor is not coming on
This has worked three times on a Dell PC: shut down; turn off monitor and PC at wall socket, unplug wall sockets, wait 30 seconds, plug back in to wall socket or power board, turn on, all should be well?
Dec 22, 2010 | Dell Computers & Internet
Screen black out after a few minutes
power plug should fit tight in wall socket. if not change wall socket.If power connection is intermittant light will shut off and fan runs to cool bulb before it can light again..
Feb 22, 2010 | Mitsubishi VS-6043 60" Rear Projection...
Portable AC leaking
depending on where you live. do have high humidity. then you have excess amount of water that might make condensate. like very cold can of can of coke.
Jul 11, 2009 | Soleus PH310R03DB Portable Air Conditioner
Soleus Heat/Air/Dehumidfer Unit
I have had a soleus wall unit since 2005.
It is a wall unit in my apt...I have never had to use the heating part...but use the cooler part alot.
I can not figure out if that lil raindropis for adding moisture to a room...or is it to remove moisture from the room?
My apt always has to much humidity, so I do use that setting quite often, but can't tell any difference in the humidity gage.
Who knows anything about using one of these.
Sep 02, 2007 | Soleus KY-34 Portable Air Conditioner
Heating & Cooling Logo
52 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Coss
Dennis Boxerman
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
