Question about Casio Office Equipment & Supplies
Casio calculator display of figures is being cut off by a bar on the upper part. what's wrong
My calculator Casio fx-991ES PLUS can't display fully anything i typed on. They always are being cut off and show only like a quarter because of the bar on top, below the menu, that blocks the characters i type. what might have i pressed that did that and how to undo it if ever. or what's wrong in my calculator. how could i resolve it?
  • 8046 Answers
SOURCE: mode change
Just so that we know what we are talking about. The natural display is the display mode in which fractions appear on two lines, radicals appear as radicals, log can be calculated in any base, etc. If that is what you understand by Natural Display, we are in agreement.
To set this mode, you turn calculator ON and press [SHIFT][MODE] (setup). The option is called MathIO, and it has the number 1.
Thus [SHIFT][MODE][1:MathIO].
Hope it helps.
Posted on Oct 13, 2009
  • 15 Answers
SOURCE: casio fx-82es significant figures
it should...
it can be found by SHIFT then MODE then SCI is the one you want to choose
Posted on Jan 21, 2010
SOURCE: how can we do linear interpolation in casio fx-991ES calculator
how solve interpolation by casio fx 991 ex
Posted on Nov 28, 2010
  • 8046 Answers
SOURCE: I have a casio fx-83gt
The computational mode of your calculator is set to VERIFY. Change it to the general COMPUTATIONAL mode. Press MODE 1 (COMP).
Posted on Jun 06, 2011
SOURCE: Casio fx-991ES, how to calculate
At a blank screen, enter your IRR formula in terms of the variables using ALPHA and ')' for variable X. For example: -1000 200/((1 X)^1) 200/((1 X)^2) ... rest of subsequent years. Then, press CALC. It will prompt you to enter values of your variable (X in this example). Don't worry if there's already a value displayed - this is just the most recent value that has been stored as that letter. Simply enter your value (in terms of your IRR guess) and then press [=]. You will have to repeat this for each IRR guess until you reach almost ZERO.
Posted on Sep 19, 2011
How i can get infinity symbol in casio fx-991es plus calculator
You can't do that on Casio fx-991es plus calculator. Usually, infinity symbol available in calculators with CAS (Computer Algebra System).
Dec 02, 2017 | Casio Office Equipment & Supplies
I've got a casio fx 991plus calculator and I want to know how to use feet and inches in the calculation displays, like how is used meters and centimetres in the display
PDF]fx-570MS/991MS Additional Functions - Support - Casio
support.casio.com/pdf/004/fx570MS_991MS_E.pdf
Casiodisplay format (Disp) settings while the calculator is in the BASE ... Be sure to checkthe current calculation mode (SD, REG,. COMP ... Use [ and ] to display the expression 4 + 4. Press A ... want to perform scientific function calculations. COMP .
The Casio fx-991es, fx-570es and - Numericana
www.numericana.com/answer/casio.htm
The Casio fx-991ex succeeds the fx-991es (functionally identical to the ... Both are nonprogrammable nongraphing scientific calculators, with natural ... Side-by-side comparison of the fx-991EX and fx-991ES PLUS. ... Displays QR codes for smartphone use .... Work out a formula for many values of the input variables.
CASIO fx-991MS Calculator Tutorial: Lesson 5- Dealing with ...
Dec 03, 2015 | Casio Office Equipment & Supplies
Combinations on fx-991ES
Press [SHIFT][ division key]. It is marked with nCr.
May 03, 2014 | Casio Brand New-Fx-991es Plus - Scientific...
Is there a verify mode on the CASIO fx-991es plus calculator?
You should try to explore the calculator to find its capabilities. You can also read the manual. Everything is in it.
Press the Mode button, then the down arrow key. On the second page of the mode list you find 2:Verif
Mar 23, 2014 | Casio Brand New-Fx-991es Plus - Scientific...
Is it possible to solve eqn in this 82ms calculator
Sorry, It is not possible to solve equations on the Casio FX-82 ms. Try the Casio FX-115 ES/ FX-115 ES Plus, FX-991ES/ FX-881 ES Plus C.
Oct 29, 2013 | Casio FX82MS Scientific Calculator
I use casiofx-991ES,its numbers looking upside down.How can i fix it?
I had the same problem with my casio fx-991ES calculator, i tried initializing the calculator by keying in shift9(CLR)3(all)=(yes) but that didn't fix the display,so i opened the calculator and removed the battery for about 5days then put the battery back guess what the display started operating well! no more inverted display or numbers.if initializing the calculator does not fix the problem,take out the battery for some few days then put it back in that should fix the problem.cheers
Sep 27, 2013 | Casio Fx-991es Scientific Calculator
PRIME FACTORIZATION USING CASIO FX-991ES PLUS
If it does not have the FACT key, you must factor by hand: Divide by 2, then by 3, 5, 7 etc.
Apr 24, 2013 | Casio Brand New-Fx-991es Plus - Scientific...
How to calculate parallel circuit in casio fx-991ES plus
Write your equations first, then try to use the calculator to solve the problem. If you don't know how to do it by hand, you won't be able to ask the calculator to do it for you.
Apr 19, 2013 | Casio Brand New-Fx-991es Plus - Scientific...
Casio fx-991es plus upside down display
I would take it apart and see if they installed the display upside down. I wouldn't think the wires would be long enough to do this, but maybe that is the way it is laid out.
Good luck.
Paul
Apr 07, 2012 | Casio Brand New-Fx-991es Plus - Scientific...
I have to buy Casio FX-991W Plus. No one has it. I checked eBay and the Casio web-site. I need that one. where can I get it from?
If you cannot find it, buy an FX-991ES. It is solar-powerd and it has the natural text-book display, which is a novelty in calculators.
I know that Staples carry the FX-991ES.
Hope it helps.
Nov 27, 2008 | Casio FX-115W Plus Calculator
24 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
