Question about Whirlpool Washing Machines
LRF4001RY Whirlpool fabric freshner won't cycle on
2 Suggested Answers
  • 8 Answers
SOURCE: liquid fabric softener dispenser empties during first spin cycle
Try putting in less softener.
Posted on May 01, 2009
Whirlpool washer wtw6800 fabric softener dispenser drains out before cycle
You can remove and wash the fabric softner dispenser drawer . It can also be adjusted on top of the dispenser
Oct 04, 2017 | Whirlpool Washing Machines
Whirlpool duet sport, fabric softener is not working
you probably have a clogged tube from some old softener that dryed up inside it
Feb 25, 2015 | Whirlpool Duet Sport HT WFW8400TE Washer
How can I fix my whirlpool washing machine soap dispenser as it on longer lets in fabric conditioner
thats sound like your water pressure is not strong enough check little filter where the water comes into machine or try your pressure switch
Oct 15, 2014 | Whirlpool Washing Machines
Unit doesn't steam during steam cycle
MAKE SURE YOU PUT DISTILLED WATER IN THE RECYCLE CUP. AND THE WATER
TUB IS NOT PLUGED UP.
Feb 10, 2012 | Whirlpool Fabric Freshener LRF4001RY
Whirlpool wtw5tesvno
Hello.
Whirlpool washers are available in many colors and with different options, including various tub sizes, front or top load styles, a fabric care system, high efficiency wash features and energy, time and water sensors. The washers may be purchased in department stores, home repair stores and online. Many are Energy Star rated. However, the washing machine may malfunction occasionally and not agitate or spin. If this occurs, some troubleshooting steps may be useful in solving the problem.
1 sure the washer has electrical power and is connected to a grounded electrical supply. Replace or reset the circuit breaker or fuse if needed, particularly in event of a recent power outage. Make sure the washer lid is closed tightly before use; the washer won't work if the lid is open.
2 void selecting the following cycles: "Extra Low,, "Low," "No Spin", "Delicate," "Casual/Perm Press" or "Hand Washables." All of these cycles use little to no spinning or agitating during the cycle. Select the highest possible spin cycle for the fabrics being washed.
3 pen the washer lid and redistribute the load; unbalanced loads may cause the washer to stop or slow down. Add additional items if only one large item,
such as a rug or blanket, is in the washer.
4 Use only the recommended amount of laundry detergent, as excess sussing can reduce the overall spin speed or cause the washer to stop agitating. If the Whirlpool washer is a high-efficiency model, use only high-efficiency laundry detergent.
5 Examine the drain hose and straighten if kinked. Remove any possible obstructions and ensure the end of the hose is no more than 96 inches from the floor, as this will cause water to flow back into the washing machine.
Thanks.
Nov 13, 2011 | Whirlpool Washing Machines
The Start/Steaming and Cooling indicator lights are flashing. I have only used this machine one time. It says to call for service. I have called and we've been playing phone tag. Does anyone know...
Yes it sounds like something is blocking the infrared sensor over the exhuast fan (right side fan). Check and make sure there is nothing blocking it (its 2 sensors that work like the safety sensors for your garage door) so there has to be an unobstructed path over the exhaust fan for it to turn on
Sep 03, 2011 | Whirlpool Fabric Freshener LRF4001RY
On the normal cycle setting once the cycle completes there is wat
Normal- the machine does not know if it's in there or not. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fabric softener leaks out at beginning of wash
I have a 9200SQ Whirlpool duet.  It might be similar.  I think the bleach and fabric dispensers work on the siphon principal--once the level gets above a certain point they will then siphon out until almost nothing is left.  They should not start to siphon until extra water is directed into them during the correct cycle.   It is possible that they are starting to siphon early because 1. the washer is not level, 2. water is being added to the dispenser during the wrong cycle 3.  You put too much liquid into the dispenser and it started the siphon.
Note:  You should not peek in the dispenser during the washer cycles because it might interrupt the "siphon"action and leave residual bleach or fabric softener in the dispensers.
Oct 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet fabric softner problem
It obviously is backed up or splashed in from the wash. And if it is just water why worry about it.
Aug 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal De
