Question about Coffee Makers & Espresso Machines
Drip tray sensor stay on - Coffee Makers & Espresso Machines
Saeco energica is half way through descaling cycle but is getting stuck how do I reset
Thoroughly clean the drip tray before putting it back may help. If there is still coffee inside which is wet the sensor may see this as water which is still in the drip tray.
Feb 15, 2015 | Saeco Coffee Makers & Espresso Machines
I was descaling my exprelia coffee machine.i was asked to empty the coffee grounds unit and the drip tray. I did that and the message keeps appearing. I even turned the machine on and off. Help.
  1. Thoroughly clean the small overflow area in the drip tray. Once the drip tray gets full water flows over a small rim into this small separate part thus triggering the sensor that tells that the drip tray should be emptied. Its waals may get a bit fatty/dirty, and so remains wet and keeps triggering the sensor.
May 23, 2014 | Saeco Exprelia Automatic Espresso Machine
Empty drip tray message
On the bottom of the machine attached to the drip tray is a sensor that "sees" liquid. If there is no liquid thgere, clean the sensor, if there is, empty the tray!
Jan 01, 2013 | Gaggia 1003380 Accademia Espresso Machine
Gaggia accademia displays empty grounds drawer and drip tray. This message will not go away despite emptying the trays?
It could be that the connectors on the drip tray need scrubbing with a wire brush or replacing.
Bean to cup Commercial Coffee Machines have this issue but it's a simple fix
Nov 19, 2012 | Coffee Makers & Espresso Machines
How do I remove the plastic drip tray from behind my Wesitnghouse Aurora Fridge Freezer.
we had a really bad smell coming from the back of our westinghouse aurora. and yes found it to be emanating from drip tray at the back. To remove this we had to undo 4 clips at the base of black motor thingy, that the plastic drip box sits on. Then we were able to lift whole thing a bit ,(10mm up and 50mm out, approx) so we could tilt everything forward and sweeze and wiggle tray out. then cleaned with bleach. also we unblocked hole inside fridge that allows water to drip into drip tray at back.
Jun 01, 2011 | Westinghouse Refrigerators
The tray full light stays on even though the tray is empty.this prevent the foodsaver from operating.I have tried unplugging,recleaning the tray but nothing works
I had the save problem with my 3400 series.
The first time i was able to let it dry and it worked alright (48 hours).
The second time even this did not work.
If you remove the screws on the bottom of the unit. There are about 10 and pull it down, you will see the sealer assembly and a small circuit board in the middle.
Trace the wires from the drip tray, there are three of them, red white and brown, to the small white plastic JST connector on the small circuit board. Pull said connector gently to disconnect it.
The unit will function perfectly now, although it will no longer have a drip tray sensor of any sort it will function every time all the time.
All in all this took me about 10 minutes.
Thanks!
Sep 09, 2010 | Vacuums
Talea Touch - Drip Tray not raising/lowering smoothly
It can be the sensor or the engine that have to be replaced:-(
Best regards
/Mirran
Sep 08, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco Espresso machine - Empty drip tray (all the time)
aye that is true if you click the coffe making button directly after you have had it out you will be able to make a cup, as the machine has a 2 second response time.
Ok here is what i think:
As it registers the driptray I dont think its the sensor to it.
More i would think that its the CPU card that is not responding to that its clean.
I am sry but I have to ask this:
When it says emptie the driptray are you actually taking out the container that is located under the brewing unit, and not the "drip tray" were you put the coffe mugs?
Also when i think i have a sensor problem I allways take out everything. Brewing unit, dripwater container, dregbox, and the watercontainer. and have it out for atleast 2 minutes ( clean it under the mean time) and put it back again.
As I dont have the machine infront of me i cant be certain:)
Jul 11, 2008 | Saeco Talea Ring Plus Espresso Maker with...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
