Question about Tablets & eReaders
Print icon disappeared from options on iPad pro
My App Store icon has disappeared from my iPad and my apps do not show up in iTunes. My son can't play Boom Beach without updating it. Please, someone help me put the App Store Icon back on my iPad
If the App Store icon seems to be missing from your Apple iPhone or iPad, give these steps a try to find it.
Fix 1 - Double Check Everywhere
Be sure the icon is not in a folder. Check every Home screen and every folder. Also use search to see if you can find it. From the Home screen, swipe all the way to the left screen, then search for "App Store" to see if it appears.
Fix 2 - Check Restrictions
  1. Open "Settings" from the Home screen.
  2. Tap "General".
  3. Select "Restrictions".
  4. Make sure "App Store" is set to "On" (green).
Fix 3 - Reset Home Screen
It is possible that the icon is on a different home screen or in a folder. Look on other screens and within folders. If you still can't find it, try resetting the home screen by selecting "Settings" > "General "> "Reset" > "Reset Home Screen Layout". This should return your icons to default settings and restore the App Store icon.
Note: If your iPad was provided to you by the organization you work for or a school, it is possible there is software on the device that locks access to the App Store. Ask your IT department for access if you feel this might be the case.
Nov 11, 2016 | Apple iPad Tablets & eReaders
Ipad 2 was stuck on Apple logo. Managed to finally get it turned off. Logo appears again when turned on but frozen. Can't reboot. Help!
Depress and Hold your home button and power at same time . This will or should take a few seconds but Keep holding until you see the apple icon . When you see it let off both at same time . After a minute or more it will disappear . After it disappears wait a couple 3,4,5, seconds and you should be able to press the home button and your home page should display .
Sep 21, 2016 | Apple iPad 2 Wifi 16GB
My credit union icon disappeared from ipad screen after i opened it today i got an error 503, but can open through safari
note the details then uninstall it and reinstall it
check your security settings see if the allow 3rh party apps in turned on
Mar 03, 2015 | Apple iPad Tablets & eReaders
The icon on my iPad used to flip the netflix picture onto my tv has disappeared from my iPad consequently I can only watch the movie on my iPad rather than my tv.
Touch the bottom of the screen: the navigation menu will appear with the full screen at the far right down of the iPad and next to the left the little square box with a triangle of airplay to send to your apple Tv. you can watch directly from your apple TV also.
Nov 10, 2014 | Apple iPad Tablets & eReaders
I-Pad Words with friends HD Deleted itself and won't reload.
Even though the app icon disappeared the app is still on your phone and that's why the app store won't reload it. Go into setting and then applications and delete what is left of the program, then the app store should let you reload it.
Feb 02, 2014 | Apple iPad 2
On the ipad I need to get apps out of folders so I can delete them.
1) Tap the folder that contains the icon you wish to remove.
2) Tap and hold any icon for about 2 seconds until they wiggle.
3) then you can delete the apps one by one
4) if the folder is empty, it will disappear by itself
How To Create Rename Edit And Delete Folders On iPhone iPad and iPod... iOS Add Remove Icon in Folder
Jan 01, 2014 | Tablets & eReaders
How do i get an air print app
When you go to an application that will print such as mail and safari if you go to the bottom of page there is an icon that is allows you to email (it is shaped like a square with an arrow coming out of it) press this and you will be given the option to print. Press print and then select a printer and once one is found press print. Please note that not all printers have airprint see http://www.hp.com/united-states/campaigns/airprint/about.html Hope this helps.
Dec 30, 2011 | Apple iPad 64 GB 3G Tablet PC
How i can print in I pad2 with wireless printer
you can only print from an ipad using the airprint app if you have one of these printers read more about it here http://www.apple.com/ipad/features/airprint.html
    May 02, 2011 | Apple iPad 64 GB 3G Tablet PC
    Tablets & eReaders Logo
    Top Tablets & eReaders Experts
    Are you a Tablet and eReader Expert? Answer questions, earn points and help others
