Machine turned on and no water coming out - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 43,983 Answers
The supply lines may not be turned on or the fill valve has failed.
Posted on Aug 11, 2017
Washing no water coming in machine?
Hi
Check the hose
Follow the hose that comes out of the back of the machine
At the end of the hose is there a small lever that u can either push up or turn down(blue for cold water washing machines?
Dec 28, 2015 | Washing Machines
Hello. I installed a new never used Kenmore washer today front load. As soon as we turned the water on at the back of the machine the water stated to enter the unit, Even when there was no power to the...
Not come across anything like it before, however, check your manual and see what it says about the position of the valve at the back of machine, if you've not already done so....otherwise goodluck.
Mar 05, 2015 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Machine runs but doesn't allow water to come into machine
Don't know the history of your machine, sounds like possibly the hot water supply valve under your sink is turned off. To check this go under your kitchen sink and inspect water supply valves, (right side cold water) left side hot water valve feeds the machine. Vertical water line is for sink above, there should be a second water line coming off this valve that has its own on/off knob. Make sure this knob is turned on, (counterclockwise)if not sure turn it to the right (clockwise)till stops, then to the left till it stops. This allows hot water to enter dish machine. If valve is on and line is ok, there might be a kink in the line behind the dish machine or a restriction (clog) in the water line. May need to unplug machine and unsecure it to pull it out for inspection. Good luck,best regards.
Feb 10, 2011 | Maytag Dishwasher
When I turn it on no water comes out but the spin cycle work?
make sure water is turned on
check for kinked hoses
if water comes out of the hoses when they are not connected to the machine then you have water if it does not enter the machine check water valve connections at the screen inlet and check electrical connections to the water valve if all is good replace water valve
Oct 08, 2009 | Whirlpool Washing Machines
No water come in machine when i turn on machine
try using only cold or just hot and see whats it doing then
Jun 11, 2009 | Frigidaire ATF6000ES Front Load Washer
No water coming into machine
you might have a clog, or maybe you didnt turn the water on. turn off the water and disconnect the hose get a bucket and turn the water on a little bit if watter comes out try inspecting the water hose in the washing machine and see if something is clogging it
May 08, 2009 | Indesit W 123 Front Load Washer
Error code h20
hi sounds like a faulty fill valve easy fix
Sep 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
No water coming out
Well on a Aroma I allways test to see if its just not air in the machine.
Turn on the machine.
press the coffe button.
Then press the steamer button ( dont turn off the coffe button.)
Do it come out hot water from the steam nossle then after a while?
Then turn of the steam button, if the filter is not blocked there should now come water from the coffe outlet.
Jul 21, 2008 | Saeco Aroma Espresso Machine
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
