Question about Vizio Televison & Video
I replaced the Main Board, Power Supply Unit, LED Driver and T-Con board on Vizio TV and now it cycles through red, white, blue, green colors when plugged in. What is the problem and what is the fix?
TV is an E55-E1 Vizio
    Sergeant:
    Habit-Forming:
  • Vizio Expert
  • 198 Answers
It is a defective LED panel, or a defective T-CON board, although you get a "NEW T-CON", it may be a defective one.
Posted on Aug 11, 2017
  • 195 Answers
SOURCE: olevia 437-s11
Most likely the CCFL inverter has been the problem all along....
Posted on Oct 10, 2009
  • 160 Answers
SOURCE: MAG 3200 Lcd TV I
Hello.
Normally T-Con board have nothing to do with powering up of TV. It's only affecting image when TV is on. So we can discard T-Con as a suspect for now.
Remove "new" main board and install the old one. If TV powering up and back light comes on - you've purchased defective Main Board and you should return it for exchange or refund. It happens all the time, boards that they sell most of the time are refurbished and sometime nothing was done and they send defective board to the other customer by error.
In case that TV is not powering up even with the old main board - look for something that you have done during replacement (like forgotten or overlooked connection, broken/bended pins etc.).
Russ.
Posted on Aug 28, 2010
SOURCE: I got a Sony Bravia
http://www.smpcshop.com/KDL-40WL135-KDL-46WL135-p-8895.html
Above is a link for a service manual.
Hi, well I applaud you for starting in the right place, The power supply, as, if, that isn't right nothing else can be. But you simply cannot do anything without a Service Manual. In this it has everything one needs to repair the set. OK if it is shutting down, after that amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins.
Gee it seems that you have replaced just about the entire "Guts" of the set, in the industry we call this the "Shot gun" method, however it seldom works in reality. One really needs to isolate the Cause, of the "Fault" and repair that and also any damage done by that. As if one doesn't remove the "Cause" it will simply fault again when the "New" bit is connected up. One needs to get the unit going section by section, testing and proving the prior section before connecting up to the next, which also must be tested to make sure that what you are going to connect will NOT damage what you are connecting it to.
Also unfortunately, these LED's Blinks, are NOT an error code in actual fact.
What you need to do is use the service manual, and follow through the troubleshooting steps, to isolate and hopefully repair your problem.
Basically it is all about voltages and if they are correct, a Higher voltage than stated usually means a component is Open circuit or a very high resistance, whereas a Lower than stated voltage usually indicates a Short Circuit, or low value resistance component, is "Faulty". These are all in the SM, as are the waveforms that must be checked, it is indeed very difficult to repair electronics these days without specialised equipment and even though I have over 30 years experience i find it difficult, so good luck.
Posted on Feb 24, 2011
  • 5 Answers
SOURCE: The colors are going out in Vizio E320VL. Can I fix this by replacing the main board or is there another solution?
Sounds like a faulty Timing Control board, I had the same problem except yellows showed up green.
Posted on Apr 06, 2013
  • 61 Answers
SOURCE: Why did it work before installation, now flashes numerous different colors?
Before installing replacement parts???
I can assume that the t-con board or the video board had terminal connectors or ribbon connectors. What is often overlooked is a misaligned connector or worse, a broken or bent pin. Try examining these connection points. You may have to use a magnifying glass. A defective screen usually goes black or produces broken images and/or color points.
I hope this helps.
Posted on May 30, 2015
Testimonial: "No I meant I had the tv lying on the ground and it was working, but when I hung it on the wall the picture went and the sound started crackling. I don't know why the moderation team changed my title."
LG 55LW5600 problem Symptoms: no audio, no video, no backlight.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 12, 2017 | LG Televison & Video
Hitachi le55a6r9a sound but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board . In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
http://electro-medical.blogspot.com/
Jan 23, 2017 | Hitachi Televison & Video
I replaced the Main Board, Power Supply Board, LED Driver Board, And T-Con Board on my Vizio P502UI-B1E 50" TV. It is still stuck in a Reboot Cycle. What else can I try?
After the main board replacement, in most cases, a firmware update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Oct 28, 2016 | Vizio Televison & Video
No back-light,No picture, but has sounds. How can I fix it?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 03, 2015 | Vizio E500i-B1 50-Inch 1080p Smart LED...
My screen is flickering on and off on Vizio LCD TV? I was wondering if it was the main board or the T-Con board.
Flickering can be either with the fault to its back-light inverter or with its main power supply regulator board.
Sep 25, 2015 | Vizio E320i-A0 32 Class LED Smart TV
I have a 55 Vizio 3D smart tv. This picture color fade in and out to the point that I cannot watch tv. I this a problem with the main board?
Hello Patricia,
  • There is a loose soldering connection in the Main Board. That happens because the components on the are generating a lot of heat therefore melting solder connections.
  • Stop beating on the TV's back, that only makes the problem worse.
  • Take it to a shop.Or if you are a tech, try locating the loose connection(s) and solder it back.
  • Also check your Warranty Period, It may cost you 0$. Call Vizio if you still have Warranty on the TV.
Here is a link to Vzio Supoport.
Good Luck,
JP
VIZIO Product Support and Services VIZIO
Jun 25, 2015 | Vizio M3D550KD 55 inch Class Razor LED...
I hope this helps.
May 30, 2015 | Protron PLTV-4250 42 in. LCD Television
HDMI/ DVI inputs failed approx. one month after connection of Denon home theater receiver with HDMI pass-through feature "on." Gear successfully re-connected via component video...
hi welcome to fixya
i want to clarify first the problem sir so as of now the problem with your tv won't power on then you are using again the old main board is that right ? when you use the new replacement main board the tv is functioning will the only problem is that the HDMI / DVI inputs doesn't work. and now you encountered power supply problem like won't start up or something that cut the supply in which the stand by indicator is turn off so as my idea it has a problem with the old board. but before you come up with the board making sure all the connectors coming from the power supply is properly connected to the main board as will as flexible and lvds cable for the T-con board is properly inserted.just let me know if is that what you are asking for so i can give you additional solution thanks for consulting the fixya.
Aug 30, 2011 | Televison & Video
Televison & Video Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
