Question about Bosch Irons
Sensixx'x DA70 iron - all lights flashing and did heat up. Now not heating at all so cannot clean it. It clicks as though hot but still cold.
All the lights started flashing on my Bosch Sensixx 'x DA70 iron and it would heat up, then lose heat. When I tried to do the cleaning process the iron did not heat up so although it did click as though it had reached the heat, but is still stone cold.
    Top Expert:
  • Bosch Master
  • 34,725 Answers
Heating element failure
Posted on Aug 11, 2017
heatman101
  • 43501 Answers
SOURCE: D2030, Digital Iron - display lights up, but the
Here is a tip that will help you to troubleshoot our iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
SOURCE: i have an bosch sensixx b5 iron and the calc clean
Here you have how to solve this issue. It has been obtained from the device's manual.
2. calc'n clean The "calc'n clean" function helps to remove scale particles from the steam dispenser. The iron includes a system to warn when the dispenser needs periodically cleaning. When the "calc 'n clean" symbol lights up on the navigation display the dispenser needs cleaning. Fill the water tank. Plug in the iron and select the temperature setting . After the necessary warm-up period, unplug the iron and hold it over a sink. Position the steam regulator to the "calc'n clean" position and keep it in this position. Gently shake the iron. Boiling water and steam will come out, removing any scale or deposits that might be there. When the iron stops dripping, position the regulator to the position. For improved descaling, heat up the iron again fully and press the steam button several times in quick succession. Then wait until the remaining water has evaporated from the soleplate of the iron. Once it has been cleaned, the cleaning warning must be cancelled on the navigation display. To do this, simply press and hold the on/set navigation key for more than 5 seconds, with the iron plugged in. If you do not do this, the cleaning icon will remain lit. 3. anti-calc The "anti-calc" cartridge has been designed to reduce the build-up of scale produced during steam ironing, helping to extend the useful life of your iron. Nevertheless the "anti-calc" cartridge cannot remove all of the scale that is produced naturally over time.
Posted on Feb 13, 2011
SOURCE: bosh sensixx B25L iron spraying brown water
I have a bosch sensixx b25l and it has started spraying brown water all over the clothes how do I descale it please
Posted on Apr 20, 2011
ercupa190
  • 12223 Answers
SOURCE: Bosch Sensixx B25L
see the instruction from your manual:
Check the owner's manual for your iron to learn the manufacturer's suggestions for cleaning, what water to use, and storage tips.
Soft-water systems add minerals that can harm an electric steam iron and your clothes so don't fill the iron with softened water. Instead, use filtered or distilled water.
2) if the iron does not heat a( test the power cord for open or defective b) and thermostat for adjust c) test the thermal fuse d) test the heating element for open.
God bless you
Posted on Aug 01, 2012
ercupa190
  • 12223 Answers
SOURCE: My Bosch sensixx B5 automatic iron fell from the iron board, the handle opened - I tried to put it together but it's stuck to auto (it doesn't give other heat choices) and the steam button doe
download the manual instr. go to www.fitness.manualsonline.com
and proceed according for help.
God bless you
Posted on Sep 25, 2012
Hi Ihave a Bosch B25L steam generator iron and it has stopped steaming completely. Any ideas?
Yousaf/Tony, Either the switch is defective or the heat element has gone bad, probably not cost effective to repair.
May 25, 2014 | Bosch sensixx TDA 8333 Iron
Too hot to handle spits water from sides Bosch sensixx B10L
I just fixed mine - it had exactly the same problem.
First, though, check it's not within the Bosch TWO year guarantee; if it is, they'll either fix or replace it.
If it's not under guarantee then the problem is probably the rubber tubing that connects the external steam tube to the hotplate. You'll need to dismantle the iron. Mine had split right next to the spring clip that holds it on. I shortened it, clipped it back on and all is now well.
Dec 22, 2012 | Bosch sensixx TDA 8333 Iron
Bosch Sensixx B25L
God bless you
Jul 31, 2012 | Bosch Irons
HI I have a Bosch Sensixx B25L iron. Steam isn't coming out of holes, seems to be escaping from edge of iron. Handle very hot (Too hot to hold on to), burns your hand when steam button is pressed
Jul 28, 2012 | Bosch sensixx TDA 8333 Iron
Bosch sensixx b25l manual
Though tpmy iron is heating up it won't take the water in and so doesn't steam It has been cleaned and no scale is in the bottom. It worked fine yesterday.
Jan 11, 2012 | Irons
Bosch sensixx 2400w
The cleaning process is to fill up, heat to max, then hold steam lever across to "calc and clean" position whilst shaking gently over a sink.
Manual is available to download from Bosch.co.uk.
Aug 27, 2008 | Bosch TDA8340 Iron
Red light flashing
Blinking red light is a standby phase, its not going to get hot like this. Shake it or just start ironing, the red light will go solid and the plate will heat up. The red light will go off when the plate is hot enough. It will go on again (solid) after a few minutes to keep the plate at the right temperature. If you leave it standing around for a while it will begin blinking again (standby).
These irons are known for malfunctioning though, mine stays in standby and the plate never heats up! Hopefully yours is fine.
Feb 07, 2008 | Braun SI6225 Iron
Irons Logo
107 people viewed this question
Top Bosch Irons Experts
Colin Stickland
Colin Stickland
cwradio73
Gil Shultz
Are you a Bosch Iron Expert? Answer questions, earn points and help others
