Question about The Audio Players & Recorders
The tuner on my TX-SR501 is not working. Finds stations but no sound. All other components are working.
SOURCE: onkyo tx 902
I have a TX-902 owners manual.
It states:
Classified Memory Function. The memory can be divided for different users or programs of stations.
How to classify stations. With this model, six classes (Class A to F) are available and stations can be memorized in any class. A total of 30 stations can be memorized in any class. A total of 30 stations can be memorized.
1. Tune in the desired station.
2. Press the MEMORY button. The MEMORY indicator will flash for 8 seconds.
3. Press the desired Classified Memory button (one of buttons A to F). The station is memorized in the selected class with the memory number which is the smallest of the unoccupied numbers in the class.
By repeating the operations above, up to 30 stations can be memorized. Any more will produce "FULL" notice.
How to cancel memorized stations:
Retrieve the class number you want to cancel and then press the MUTE/MODE button while holding down the MEMORY button. Another station can be memorized with the memory number which has been cancelled.
Hope this helps.
Posted on Jan 08, 2008
  • 319 Answers
SOURCE: Tuner Omits No Sound - Onkyo TX-SR605 7.1 Channels Receiver
Make sure your receiver is hooked up to proper AM and FM antennae. Try switching to AM, scan stations. If you hear AM static and/or weak signals the problem could be antennas are not hooked up. FM has AFT which blocks out weak or noisey stations and you wont hear anything without ant.
Posted on May 07, 2008
johnny5846
  • 379 Answers
SOURCE: 03 chev silverado radio on but no sound
studying the radio schematics , i'm seeing a radio amp fuse under the hood ,in the main fuse box under hood , 30 amp , check that for starters , if the amp was out you would only lose sound , would like to get a fix ya vote , comment back because i have other thoughts on your schematics , and do you know if its the base model or premium sound , with or without cd ? , thanks .
Posted on Jan 11, 2009
My van radio runs on 2 different fuses- both in the fuse box under the dash. One runs the lights the other the sound. Hope this helps.
  • 4234 Answers
SOURCE: receiver does not power on. standby not on either
The standby light should be on. If it is not, then check the main fuse. WIth the unit unplugged, remmove hte top cover and check the fuse by the line cord. If that is ok, then you will need to check the primary winding on the standby transformer. That transformer has a thermal fuse internally located and that sometimes gets blown due to a power surge. If you do not have the equipment to test this, get a detailed estimate from a local servicer. The standby transformer usually costs arounf $25 or so.
Dan
Posted on Apr 26, 2009
I have an Onkyo TX-SR501 reciever/home theater amp. The sound works fine in home theater mode, but no sound when FM mode selected, but fine in AM mode. Have checked Antenna.
Hi Anil, please make sure the the receiver is locked into the station. It should read FM Stereo when locked in. Thank you, Onkyo USA
Nov 23, 2016 | Onkyo TX-SR501 Receiver
How to connect av receiver to dvd player and hdtv
You can go to the manual at the link below and follow the directions
Links
Aug 17, 2008 | Onkyo TX-SR501 Receiver
My stand by light flashes on my onkyo tx-sr501
Check output transistors for short, change emitter resistors
Mar 30, 2014 | Onkyo TX-SR501 Receiver
I don't have the manual for this receiver and I would like to hook up my hd tv to it. How do I acquire the user's manual? Thanks, jmp
Use a search engine for "Onkyo TX-SR501 manual"??
Hint: retrevo has it.
You might also hunt for the TV manual as IT is a player in the scenario, too.
Jul 24, 2011 | Onkyo TX-SR501 Receiver
May 06, 2008 | Onkyo TX-SR605 Receiver
Blank display on a Onkyo TX-SR501
try to connect the receiver to a tv via the monitor out from the receiver to the tv. you may be able to see the OSD (on screen display of your settings) change the function on that to turn on the front display. alternatively look on your remote to see if you can turn up the light of the front display.
if these don't work possible that the light of the display has blown.
good luck
smeags.
Dec 31, 2007 | Onkyo TX-SR501 Receiver
REMOTE CONTROL
yes either use the presets or the scan button.
Dec 28, 2007 | Onkyo TX-SR501 Receiver
Optical sound
I think what I might do is use an optical splitter: http://www.amazon.com/Digital-Bi-Directional-Optical-Toslink-Splitter/dp/B0002MQGR2, does anyone have any experience with this?
Dec 05, 2007 | Onkyo TX-SR501 Receiver
Top The Audio Players & Recorders Experts
ctlimey
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
