Question about Global Computers & Internet
My zmax got stuck on some global menu and safe mode
3 Suggested Answers
SOURCE: My Phone Is Stuck on safe Mode And My Menu Button
Interesting situation. Same thing started happening on my G1 today while I was in the 'WordUp' game. Menu button has become erratic (pops up randomly, not when clicked). Tried rebooting several times (with menu button depressed). Does not seem to help. Widgets don't load and my non Google apps don't show in the menu, but the shortcuts on my homescreen work fine. Still tinkering with it. Will post if I can fix this. Any ideas are welcome.
Posted on Jun 21, 2010
SOURCE: Samsung Exclaim Stuck in Safe Mode
NEED TO FULLY FLASSH MY SAMSUNG EXCLAIAM SPH M550
Posted on Oct 04, 2010
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
How do you get out of safe mode?
Safe mode is normally manually activated by pressing F8 at startup. However if it is stuck, you can try disabling it from the system configuration menu:
If using Windows XP:
1. Start the machine and boot to the Windows desktop.
2. Click Start > Run
3. In the dialog box, type msconfig and press "Enter". This will bring up the configuration window.
4. Click on the "Boot" tab and in the lower left corner under "Boot Options", untick "Safe Mode".
5. Restart the computer.
If using Windows Vista/7:
1. Follow the same instructions as above, however when you click Start, just type msconfig in the search box at the bottom of the Start Menu and press "Enter".
Jul 19, 2014 | Computers & Internet
Removing safe mode
to get out of safe mode just Restart.
Do it from the Start Menu.
Of course - you may also shut down. But only from the Start Menu.
Apr 24, 2013 | E-Machines Computers & Internet
Toshiba c660d laptop stuck in safe mode? help!
When the Windows splash screen pops up, start hitting F8 until the menu comes up and select Start Windows Normally
Oct 21, 2012 | Toshiba Computers & Internet
How to get to safe modem?
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use yourarrow keys to move to "Safe Mode" and press your Enter key.
Trouble Getting into Windows 2000 or Windows XP Safe mode- If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen
Jan 14, 2012 | Compaq Armada M700 Notebook
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
How do I turn off safe mode on Mozilla
Want to turn off Safe mode option on your Mozilla Firefox? Then follow this simple steps:
  1. Open Mozilla Firefox
  2. At the top of it (Firefox window), click on the Firefox button (in you have Windows Xp, click on File menu) and then click Exit.
  3. Start Firefox as you normally would.
  4. If Firefox keeps starting in Safe Mode see Firefox is stuck in Safe Mode.
If your Mozilla Browser is stuck on safe mode better to the steps here: Click here
May 16, 2011 | RCA VR702HF VCR
I have safe mode on my phone and i cant turn it off cant use apps i want how do i turn it off? i have a mytouch 4g i factory reseted and rebooted it doesnt work help
Please check your menu key and see if it is stuck. For your phone to boot into safe mode, the menu key needs to be held at power on, so if after turning it off and doing a factory reset you are still in safe mode, then your menu key stuck. I have heard of the g1 having issues with the menu key getting stuck and a replacement is needed. How old is your phone? Are you still under warranty with tmobile? Let me know if you have any other questions.
Mar 01, 2011 | Cell Phones
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
Feb 28, 2010 | Samsung Exclaim M550 Cell Phone
Computers & Internet Logo
32 people viewed this question
Top Global Computers & Internet Experts
David Payne
David Payne
Are you a Global Computer and Internet Expert? Answer questions, earn points and help others
