Question about Health & Beauty
I'VE LOST THE PART THAT GOES IN THE EAR CANAL. WHERE CAN I GET A REPLACEMENT ?
  • 3,037 Answers
Can you please post the make and model number of the shaver in question.
Thanks
Benjamin
Posted on Jul 27, 2009
Symptoms inner ear infection
Pain. Red inside ear canal.
Apr 14, 2014 | Health & Beauty
A images of ears
You can use any search engine, type in internal ear canal and just click on images.
Apr 12, 2014 | Health & Beauty
Ear feels plugged
There are several reasons this could be happening, but probably the most common reason if you have not and are not having any pain with this ear, is Cerumen impaction or earwax plugging your ear canal. Try an over the counter ear wax removal product. Follow the directions on the box. OR see your family doctor. The Medical Assistants can usually rinse the wax out. Sometimes when the wax has been there for a very long time, your ear canal may be irritated and bleed a bit. If so the doctor may want to place you on a temporary medication for this.
Mar 17, 2014 | Health & Beauty
What is ear wax and do I need to get rid of it?
Ear wax always gets a really bad press but it's actually there to help the protect the ear. It's produced in the ear canal and then slowly makes its way to the opening. It should come out naturally by itself or with gentle daily washing. When you use ear buds you just push the wax deeper into the ear and ultimately that increases the risk of infection.
Feb 20, 2013 | Health & Beauty
If there is a battery in the earpiece; is it safe? There is some controversy about the safety of holding a cell phone to one's ear for extended periods; that's why I wanted an ear piece.
Yes it is perfectly safe. The easiest way to identify whether a bluetooth set is malfunctioning or unsafe is - HEAT. Normally batteries which are about to die or devices malfunctioning will heat up quickly when you charge it.
So unless you dont feel abnormal heat.. they are perfectly safe. Try to remove the BT earpiece when not needed. Your ear canal needs natural air flow. Blocking it with a prolonged use of a BT device could heat up the ear canal. That's where the problem starts! :-)
Mar 05, 2011 | Southern Telecom Emerson Bluetooth Headset...
I need a instrution manual for a ear themoniter model no ET1200
Hi.
  • 1 Consider that most digital thermometers take a temperature in less than 30 seconds, quickening the temperature-taking process for squirmy children.
  • 2 Read the thermometer's instructions carefully. Never throw the instructions away. Keep them near your digital thermometer.
  • 3 Wipe the thermometer probe with a soapy washcloth or a tissue dabbed in isopropyl alcohol or put on a clean probe, depending on your brand of thermometer.
  • 4 Turn the thermometer on.
  • 5 Use a gentle rocking motion as you insert the thermometer into the ear canal or rectum. Never push or cram the probe into the body. Forcing it causes pain, especially if there is swelling in the ear canal or rectum.
  • 6 Listen for the beep.
  • 7 Remove the thermometer.
  • 8 Read the thermometer. If you see "ERR," you did not get good contact with the ear canal or rectum, and will need to take the temperature again.
  • 9 Use the chart insert that comes with your thermometer to see what your normal reading should be.
  • 10 Clean your thermometer probe with a soapy washcloth and/or isopropyl alcohol before storing.
  • Aug 26, 2010 | Health & Beauty
    I have bought a pair of Shure SE210 headphones for my iphone but the sound is lacking all the low frequencies for most of the music or videos i try to play. The headphones work perfectly on any other...
    No, there are no known issues. Typically a lack of bass response is due to a poor seal with the ear canal. The headphones use sealed ear canal is a resonant bass chamber. Thus, if there is not a good seal, the bass will be significantly lower.
    Jul 07, 2010 | Shure SE210 Consumer Headphones
    Soft ear pad for jabra bt8040
    http://www.msgdigital.com/productdetail.asp?productid=46551
    Feb 18, 2009 | Jabra Bluetooth Headset with Adjustable...
    Hearing Aid Question
    Behind-the-Ear (BTE) - Sits behind your ear and is connected to an ear mold placed inside your ear via tubing. BTE devices are fastened on the ear with an ear hook and the ear molds are custom made to fit the user's ear. In the Ear (ITE) - These are placed in the ear of the wearer. In the Canal (ITC) and Completely in the Canal (CIC) - With ITCs and CICs, the whole hearing aid is placed inside the canal. ITCs are often larger than CIC devices. CICs are extremely tiny in size and are almost invisible. Body-worn hearing aids - These aids use an external box worn by the user. The user wears an ear piece which is attached to the box by a wire. There are also disposable hearing aids available which have a built-in battery and, after the allotted hour or time usage, the user simply replaces the entire aid.
    Aug 27, 2008 | Maxi Aids The e-pill Cadex 12 Alarm...
    Health & Beauty Logo
    13 people viewed this question
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
