Question about DeLonghi Coffee Makers & Espresso Machines
Trying to make froth milk with my Delonghi Perfecta, instead I get steam only, then intermittently a dribble of milk. I have tried checking the clean button, seems to work fine on and off. Any ideas?
Had the machine 7 years and serviced regularly, new seals etc fitted, checked the usual things like, varied the milk froth regulator, makes no difference, the milk is SS and about 5deg C
  • 515 Answers
SOURCE: Steam not frothing milk
Have you decalcify the machine, the boiler does not heat up if there is calcium in it.
Posted on Jul 11, 2008
SOURCE: milk not frothing
Remove the black plastic outer sleeve of the Frothing Wand (some models have a metal outer sleeve). If done correctly, the “sleeve” has been removed, but the inner wand with red or black washer, is still connected to the machine.
2) The part of the sleeve assembly that you have removed is comprised of 2 pieces, the frothing sleeve and the center piece. The center piece can be seen if you look into the top of the wand.
3) Using a pencil (eraser end), or similar shaped object, push down on the center piece until an audible “click” is heard. The “click” means that the centerpiece is back into the proper position. When in the proper position, the center piece visibly sticks out the bottom of the sleeve about ¼-inch. It looks like a bird beak.
4) Now put the sleeve back on the machine and your machine should be ready to froth again.
As for the milk island, translaltion from the italian solution using google and drying all the parts works
Posted on Apr 30, 2009
SOURCE: Delonghi Magnifica Coffee Maker the milk is not
You did not state anything about descaling, but every now and then, I also add water and descaler to the milk container and use the "Frothing" program to run through the water and descaling-solution (double-click the Cappuchino button).
I have also noticed that the first cup (and sometimes even the second) will produce less milk, and not as well frothed milk as later cups. My theory is that the machine is warmer when producing later cups.
If possible, you could try to run two-three frothings of plain water through before switching to milk. I realize this is inconvenient, but it could be worth testing this to see if it helps. We luckily have two milk containers and keep one filled with water just for the purpose of heating up (or whatever we do :) the frothing system before serving the first cappuchino.
Posted on Oct 08, 2009
SOURCE: the steam wand is bubbling the milk, not frothing
THere is a little black tube inside - make sure its pushed out enough - about 1/16 an inch from the bottom. And you may have to clean it out. Happens to us too and after I do the above it works
Posted on Feb 14, 2010
Testimonial: "Thank you very much for the advice. I adjusted the black tube and the frothing is back!"
  • 7 Answers
SOURCE: Delonghi Rialto 4500. The milk doesn't go trough,
I fixed this problem on my Magnifica by gently scraping the scale away from the inside of the coupling (clearing the hole of scale and debris)
Posted on Aug 07, 2010
Why is Delonghi Perfecta not producing steam to froth milk.Nothing at all happens when cappacino button is pushed
At wits' end DeLonghi Magnifica steam function - Coffee Forum
Jun 1, 2012 - While I quite like the coffee it produces, the steam function seems to be ... it with the magic DeLonghi descaling solution, so I'm certain this is not ...
DeLonghi not producing steam Questions & Answers - Fixya > Forum > Tags > not producing steam
Ask your DeLonghi not producing steam questions. Get free help, advice ... Ad. Question about Esclusivo Magnifica ESAM3300 Espresso Machine. 3 Answers ...
Delonghi 3500s coffee machine not producing hot water or ...
Dec 06, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Delonghi perfecta milk not hot enough
Ummn - something in your Q. seems not right. The milk is not heated directly - its only heated by the steam as it passes by (and picks up) by the milk using a venturi effect - same as a spray bottle attached to a garden hose. You say you have froth - but you can only get that if you have steam... (it does not just blow air thru to create bubbles). So froth = steam & steam = heat... so milk must be hot.
Suggest you check manual for the 'heat' settings for your expresso as this may have been changed. While this is adjustable, the milk is not.
Also always heat your cups before using them - the silver cup 'holder' at the top does a reasonable job but boiling water does far better.
Cheers Mike
May 31, 2014 | DeLonghi ESAM6600 Espresso Machine
Delonghi EC702
Even semi skimmed milk with froth if hot enough. Check the steam temperature, you may need to blow steam through the milk for longer.
Mar 06, 2014 | Coffee Makers & Espresso Machines
Delonghi Perfecta won't froth milk or allow hot water to come out from waterspout
Aug 20, 2012 | DeLonghi Perfecta ESAM5500 Fully Automatic...
I have just bought a delonghi ec220cd coffee maker - a replacement for the delonghi ec270 which started to leak badly. However, the milk doesn't seem to want to froth - just wet and may as well just pour...
Try removing the plastic steaming sleeve and just use the stainless pipe. Keep the pipe just below the surface to make the ffroth, then go lower to heat the milk to a max of 165F.
Apr 27, 2011 | Coffee Makers & Espresso Machines
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
There is no milk coming out of the frothing part of the Delonghi Coffee Maker, it just makes a noise and steam comes out.
If no milk comes out of frother, check the o-ring on the upper "plug" where the milk jar connects to the machine. There are two connectors; only the bottom one corresponds to the steam output while the upper one is a plug. Mine had a worn out o-ring on the plug, and this keeps the machine from frothing milk.
May 17, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Steam and froth malfunction
The milk can not be room temperature.  It needs to be cool, does not have to be fridge temperature but can not be warmer than room temperature
Feb 18, 2008 | Jura Capresso Impressa Z5 Espresso/Coffee...
Coffee Makers & Espresso Machines Logo
35 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
