Question about Watches
Can the batteries be changed in Britain?
Im giving a Cardinal Quartz Analog watch to my niece in England as a gift..can she get the batteries changed there in UK?
  • 74 Answers
Of course you can just pop into any jewellers or watch shop they will fit it for a small fee
Posted on Jul 27, 2009
How do I set the time on my pasnew watch
Dealextreme - PASNEW Sport Waterproof Quartz Analog ...
? 6:32
https://www.youtube.com/watch?v=7D6i4d-1NYQ
Oct 25, 2011 - Uploaded by TheTemplegeek
... PU watchband - Dual time display: analog and digital - Features timer, ... PASNEW Sport Waterproof Quartz ...
How to set watch model WR30M - YouTube
? 3:02
https://www.youtube.com/watch?v=VGRAb0aF2lQ
Apr 29, 2015 - Uploaded by TheUltimate
11:24. How to Set a Timex Ironman Triathlon Watch - Duration: 1:15. by Inside Endurance Sports 2,441 views ...
how to set time in digital watch - YouTube
Dec 15, 2015 | Watches
What battery size takes the Invicta Cuadro 14700
The battery described for this watch is 'non-standard'. I would take it into a jeweller.
Invicta Men 14698 Cuadro Analog Display Swiss Quartz Two Tone Watch
Oct 29, 2015 | Invicta Watches
Quartz analog chrono sailing watch gn 4s
check if it is two separate batteries which is the case in older models
May 01, 2014 | Citizen Watches
My DZ 7241 watch analog watch does not turn on?
please ckeck the crown of your analog time if it is pressed down, if it is pressed it is possible that even if it is a brand new watch, the battery has no power at all.. it is maybe that your newly purchased watch is been in its selling showcase fo a long time, so that the watch movement consume all the power of the analog's battery.. you have to replace the battery of your analog., Note: your watch has three batteries. I hope this will help..
Feb 05, 2013 | Diesel DZ7241 Mens Watch Stainless Steel...
Wrangler Hero Watch analog hands dont work after battery replacement
Remove the PCB and replace the AG4 battery in the analog quartz movement. The stem can be removed by pressing the small lever through the hole visable after the CR2016 battery has been removed. I think it uses a Y121 movement.
Jan 31, 2013 | Watches
Setting analog part of analog/digital cardinal watch
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs.
Oct 23, 2012 | JCPenney Casio Casual Sport Analog/Digital...
I haven't worn my fossil watch (FS 4337 model) for some time & decide to wear it & shook it, adjust it, & it dosn't work. Usually when I don't wear it for about 2 weeks, I shake it...
If you have a Fossil FS4337 Chronograph, shaking the watch shouldn't be doing anything other than exercising your muscles; the movement is a battery-driven quartz movement whose movement is controlled only by whether the stem has been pulled out (stopping the movement and saving power) or whether the battery still has enough power to activate the stepping motors that move the watch hands. Based on the symptoms that you've described, I would suggest that it's probably time to change your watch battery.
Often, when a watch battery is running low but isn't completely dead, pulling the stem into time-setting mode will stop the movement and permit the battery to "rest," giving it (briefly) a bit more reserve amperage to put out when you push the stem back in. That's how you can sometimes get a quartz watch to run for a few minutes after the battery appears to be dead. That may also be why your watch has started running again after you've set the time and date.
Fossil analog quartz watches tend to use silver oxide (usually #377 or #379) batteries instead of longer-lasting lithium batteries. In ordinary use, I would expect a silver oxide battery to provide between 1 and 2 years of service before it needs to be replaced. I can't remember if Fossil chronographs (which also use quartz movements) use a silver oxide or lithium battery. Lithium batteries often provide an additional year or two of service in analog watches, compared to silver oxide cells; digital watches using them supposedly may last as long as 10 years with a lithium battery, assuming you don't use the backlight or audible alarm functions. Note, however, that these batteries are different sizes and different voltages, so you can't substitute one for the other.
Finally, none of this advice applies if you have a Fossil watch with a true mechanical movement in it. In that case, gently shaking the watch may spin the winding rotor enough to start the watch back up again. However, an even faster way of winding those watches is to use the winding / time set crown to wind the mainspring directly instead of relying on the geared-down action of the winding rotor. Automatic watches can bind up if they are not used for a period of time; the lubricating oil used in some of the pivots can harden--or at least provide enough resistance that the movement may require more initial force to start running than to continue running. That behavior usually indicates that it's time to have the mechanical movement cleaned and re-lubricated.
May 31, 2011 | Fossil Brushed Brown Dial Chronograph...
I have a Breitling watches 1884,it was presented to me as birthday gift,but i dont know its manufacturer code number,and its price.Description of it is a 4 cardinal North ,south ,west ,east,it has both...
There will be a model and serial number on the case back.The numbers are small 1884 is the founding date of breitling and is on all backs.The watch is no doubt valuable,breitling watches retail from £1500.00.Most high streets will have a stockist and they will be happy to provide the latest price.If you need any repairs return it to a stockist when under guarantee or if out of guarantee see www.rolexrepairs.co.uk for expert repairs and servicing.
Aug 17, 2010 | Breitling Hercules 246/GRY/PROF
My Quartz sports watch works, loses time, had three months, .
Sounds like battery is failing. Time to replace it! :-) Sears stores usually have a watch repair counter...or find a reputable watch repair business. (Even if the watch is new...its still possible the battery could be failing because you have no way of knowing when it was originally installed! They typically last about 2-3 years depending on age and condition of watch!)
Jan 09, 2010 | Timex 27191 Wristwatch
Watches Logo
91 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
