Question about Samsung Televison & Video
Hi, i have a problem with my tv, there is only sound and a black screen. if i try and look at my TV with a flashlight i can see that there are images. what is this problem and how can i solve it??
My tv type is a SAMSUNG HDTVmonitor T27D590
    Top Expert:
  • Samsung Master
  • 74,887 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Aug 11, 2017
  • 244 Answers
SOURCE: W4201C no picture only sound
Try to use dvd player to play video to determine where the problems goes wrong either from the video signal of the cable provider or from the TV itself.
Please let me know any update.
Posted on Nov 23, 2007
tvtek
  • 1284 Answers
SOURCE: Samsung lcd 23 inch tv- no picture only sound
Try a reset frist by unplugging for 2 minutes then restart the TV. If you only paid $300 for the TV you will most likely pay more than that for repairs and parts to fix it otherwise.
Posted on Feb 04, 2008
SOURCE: sound works but no picture. black screen
I've had the same problem. Usually, if I turn the TV off and then back on again, it's fine.
Posted on Mar 05, 2009
SOURCE: Green noise on all black images on my SAMSUNG LN LCD TV screen
I had a similar problem with my LG plasma. I used the Image Sticking Minimization
(Pixel Orbitor, White Wash, and Inversion) feature which is designed to prevent image burn in and ghosting. This ISM feature may be available on the Samsung or any other brand under a different name. I activated the "white wash" option for about 30 mins, the screen turns white and somehow the pixels get reset. The green noise disappeared after that.
I hope this helps. Phezbuster
Posted on Jul 05, 2009
  • 1779 Answers
SOURCE: 47inch toshiba lcd tv (HL167) black picture, but
Best to replace both at the same time . Yes they are easy if you can find the parts.
Posted on Dec 15, 2009
I have a JVC flat screen tv When I power it on the JVC screen opens for a second and then the screen is black. I do have sound.
Hi. Shine a torn into the screen while the TV is on especially with sou and.
if you see the picture the you probably have a backlight issue
let me know after the flashlight test
Feb 03, 2017 | JVC Televison & Video
How can I fix black screen on Philips 42" LCD TV?
chances are it is cracked solder joint on internal board,
check link below, press the helpful button
http://www.repairfaq.org/samnew/tvfaq/tvtmmqcs.htm
Jan 24, 2016 | Philips 42PFL7422D 42 in. LCD TV
My tc14p2se.. no screen but u can hear the sound..what should i check and replace any parts.plz help
Hi sound and no picture usually leads to your backlight inverters or your backlights thenmselves. Most likely the backlight. When you say no picture I assume you have a black screen with no lights.
You can get parts for this TV at www.interliquidparts.com
Feb 29, 2012 | Televison & Video
My television was recently repaired and the guy said that I needed to reset the tv. The power comes on but the screen is still black. How do I reset the TV
grab a flash light .with the tv on and while making sure you have a signal hearing the sound.Shine flashlight at tv screen look closley.if you can see the video on screen with flashlight ..Then you have internal problem with lcd backlight inverter section or power to inverter..
Sep 22, 2011 | Proscan 32LB30H LCD TV
TV was playing, then the screen turned black.
If the screen is black and you have sound then lightly press and shine a strong flashlight against the screen. If you see an image around the edge of the flashlight, an image is being 'displayed'. The problem is probably in the Inverter/CCFT or the power going to the Inverter.
Feb 01, 2009 | Insignia 37" LCD Flat-Panel HDTV
Open Questions:
Televison & Video Logo
32 people viewed this question
Henry  Thomas
Henry Thomas
