Uninstall messenger - Computers & Internet
My messenger just stop from working i uninstall it and instal the new one but i just can get it to work help please
Uninstall Yahoo Messenger! using this program >click HERE .
Before starting to uninstall Yahoo messenger be sure that it is not running. So check your taskbar at the bottom of your screen and near to your system clock, right click on its icon and select "Exit". Then select the program and start the "Uninstall" command. Uninstall process with Revo Uninstaller Pro starts the uninstalling wizard, which shows you what is happening on every step of the uninstalling procedure. During the uninstall Revo Uninstaller Pro tries to run the built-in uninstaller of the uninstalled program, if it works properly let it to do its job, but if it is not working properly here you will see an error message that you will have to skip ( ignore ). Then select an uninstall mode and press "Scan" button to continue further to the next step of the wizard. After the scanning completes you will see the leftover Registry items, files and folders, review, verify and delete them.
After you uninstall Yahoo Messenger ..install the latest version from Yahoo Site->http://xp.yimg.com/gj/msgr/11/suitega2/msgr11us.exe
Jul 26, 2011 | Yahoo Messenger
Yahoo messenger is not working...whenever i sign in,,its not sighing in and yahoo messenger trouble shooter is coming..how to overcome this?
Uninstall yahoo messenger and reinstall to uninstall software do the following. Windows XP: Start/Control Panel/Add and Remove programs/Uninstall Yahoo messenger. Windows Vista/7 Start/Control Panel/Under Programs/ Uninstall a program Reinstall the software from direct website www.yahoomessenger.com
Feb 15, 2011 | Computers & Internet
How to uninstall windows messenger in windows 7
It can be done through the Control Panel and the Add/Remove Programs function. You will NOT, however, see "Windows Live Messenger" on the programs list. What you will see is an item called "Windows Live Essentials".
Click on the Change/Remove button for Windows Live Essentials, then select Uninstall, and then in the next window check "Messenger." Then continue with the uninstall process.
Hope that's helpful.
Jan 16, 2011 | Microsoft Windows Live Messanger
I cannot open yahoo messenger application from my desktop?
Uninstall your yahoo messenger, click start menu, click settings and control panel. Double click add/remove programs and uninstall yahoo messenger. After uninstalling download yahoo messenger from this link. Click download latest version to download the yahoo messenger and install after downloading. Then try to open your yahoo messenger to test if its working! Have a nice day!
Jan 10, 2011 | Yahoo Messenger
When i load my messenger and click to talk to someone or someone ims me it automatically goes into Messenger not responding and shuts down? HELP
Uninstall you yahoo messenger using a uninstaller program like revo uninstaller. Then try to install a fresh yahoo messenger into your computer. Try also to clean, optimize and repair your registry using ccleaner
May 12, 2010 | Yahoo Messenger
Messenger is loaded but i have no icon to click on.
You need the following OS to support Messenger 10 beta
Windows 2000/XP/2003/Vista/XP64/Vista64
If that is not a problem read on.
The problem may be due to a mal-function of the uninstall software.
Close all programs when uninstalling / downloading and uploading.
Uninstall from the C drive
Start > Computer >> Local drive (C) >> Program Files >> Yahoo >> Messenger >> UNWISE
Unwise is the command to start the uninstall process - click 'Auto' if prompted
The Yahoo uninstall software can be problematic you may have old software remaining on the C drive
If you have Vista the whole Messenger folder should have been removed during the uninstall.
Check
- The Messenger folder should have been deleted and not seen. If the Messenger folder is still visible - delete it.
If you have a pre-Vista OS, the Messenger folder remains, and inside, only one sub-folder should be seen. This is the 'Profile' folder and contains all the message history. All other software should have been deleted.
Manually delete any other folders and files before moving on
Download 'ccleaner' and run it through a couple of times.
http://www.filehippo.com/download_ccleaner/
Re-start your computer and download Yahoo Messenger from here.
http://www.filehippo.com/download_yahoo_messenger/
Oct 17, 2009 | Yahoo Messenger
Please help instant messenger
Easiest way to resolve a problem with messenger is to uninstall it then reinstall the program.
To uninstall go to Start - Control Panel - Programs. Find Yahoo messenger in the list and uninstall it.
For the latest version of Yahoo messenger go to this link http://messenger.yahoo.com/download
Download and reinstall the program following the onscreen instructions.
Jun 19, 2009 | Yahoo Messenger
If i double click the icon yahoo messenger will not come on or if i uninstall it will not do it
I suggest you download Ashampoo-UnInstaller from http://www.download.com/Ashampoo-UnInstaller/3000-2096_4-10032301.html
and try to uninstall yahoo by this software and then re-install your yahoo messenger, I hope it fix.
But if this software couldn't help you, I suggest you to delete yahoo messenger manually (goto C:\Program files) and delete Yahoo messenger folder manually and try to re-install your yahoo messenger.
Good luck
Feb 25, 2009 | Yahoo Messenger
I need experienced help to uninstall yahoo messenger will not unt
try installing it and then uninstall it !
if it doesn;t work than manually remove it (should be in Program Files\Yahoo\Messenger... i think ...)
Jan 07, 2009 | Yahoo Messenger
Not all the programs will be listed on your program list. To uninstall yahoo messenger:
Start > Control Panel
Switch to classic view in control panel
Select "Add remove programs" for XP or "Programs and Features" for Vista
Wait for the list to be populated, then scroll down and locate Yahoo Messenger, select it and click "Uninstall"
Oct 31, 2008 | Yahoo Messenger
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
