Question about Daewoo Washing Machines
I have Daewoo DWD-WD1132. My washer machine door doesn't open after completing the wash. The light for "Door Locked" is off.
  • 1294 Answers
SOURCE: washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Posted on Apr 02, 2009
SOURCE: Daewoo washer - LE error message
replace the lock switch
Posted on Dec 27, 2009
  • 99 Answers
SOURCE: Wash load almost complete, buzzer went off, door
To open the door first unplug the machine then take off the front panel under the door (three screws at the bottom) reach in by the door lock and there will be a plastic tab hanging down, that is the manual release for the door. Pull it down and the door should open right up. I'm judging that the machine is flashing a code when it shuts down, often times its F11 or FdL in either case the problem is most often a bad CCU circuit board (whirlpool had quality control problems with this circuit board) There's what's called cold solder joints on the board at the points where the spade connectors and relays (5 of them) are supposed to be firmly soldered to the board. These bad connections cause the Duet washer to have all kinds of issues. To repair it you need to take out the CCU circuit board It's in a plastic case at the inside, top, back of the machine. Remove the case as a whole, it's easier that way. Then remove the circuit board and touch-up those points I mentioned. If you not good with solder techniques you can remove the board (keep it in the case) and take it, and this response, to a good appliance repair shop and they should be able to help you out. Good luck.
Posted on Jan 28, 2011
  • 6277 Answers
SOURCE: Problem DWD-WD1132 front washing loader stopped
Sorry- we can only deal through the forum unless you take the option to pay for someone to talk to you ;-0(
In any case I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 08, 2011
Testimonial: "Thank you for your comments and help I opened a drain below on the left side of the machine. Water was drained out the machine Then it works normal. "
tlsollazzo
  • 12 Answers
SOURCE: WASHER DOOR STUCK
Not all that uncommon on some front loaders. Yes, it is trying to lock and unlock. You can try two different things that might work. 1) Unplug the unit and let it set for 5 minutes and see if it then unlocks itself. Some units have a bi-metal timing that can take from 2-4 min. to release after the spin stops. 2) Wake up unit by pressing start or any button that starts the lock clicking. Have your hands on the door with some gentle pressure because if it unlocks you can pull the door open. Sometimes these things get mixed up and lock, unlock, and lock again. Once you get it open it usually clears up and does not happen very often.
Posted on May 19, 2012
Why does my Maytag Neptune washer door stays locked after cycle is complete.
sounds like the locker servo is having an issue there and may need replacement contact Maytag for a replacement part
Aug 22, 2017 | Washing Machines
I have a daewoo washing machine dwd-g20dl showing error code LE
LE Washing machine door opening error
The washing machine or washer dryer door has been detected as open or unlocked.
·Close the door!
·Check the door lock switch
·Check the door latch
·Check PCB
Jul 09, 2014 | Daewoo Washing Machines
Troubleshooting
Best bet would be to unplug the machine, leave it for 30 seconds, then try plugging it back in.
Oct 19, 2013 | Daewoo DWD M1031
DAEWOO,WASHING MACHINE.CDW-WD13WCS/RCS. Door will
This video will show you how to open your DAEWOO washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 02, 2013 | Daewoo DW500M Top Load Washer
WASHER DOOR STUCK
May 17, 2012 | Daewoo DWD-WD3011WW 4.0 cu. ft. Capacity...
I have a daewoo 7kg direct drive washing machine DWD-14ODS i put a load in it got a couple ov minutes into the cycle then started bleeping and is displaying LE on the screen there is some water in the...
'LE' stands for Lock Error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
John C
Jul 09, 2011 | Daewoo Washing Machines
Door lock light is on door is not locked and
Make sure you are allowing the washer to completely finish its cycle before opening the door. It is normal for the door to lock at the end of a cycle. The locking mechanism keeps owners from opening the door before all of the water has been drained. If the door on the washer is locked, select the "Drain" or "Spin" options on the front-load washer. This will completely drain the water from the system and unlock the door, allowing you to open it.
Thank you !!
Jun 19, 2010 | Frigidaire GLTF1040A Front Load Washer
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Nov 16, 2009 | Daewoo Washing Machines
No Locked Light
does the washer actually go into high speed spin? if not the wax motor in the door lock may be no good. that would prevent the door from locking and the indicator on the display would not light.
Aug 03, 2007 | Maytag Neptune Washer
Washing Machines Logo
32 people viewed this question
Top Daewoo Washing Machines Experts
Owen Barnes
dweatherby
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
