Question about Samsung Televison & Video
Samsung LED tv buttons dont work? - Samsung Televison & Video
    Top Expert:
  • Samsung Master
  • 75,017 Answers
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Aug 11, 2017
3 Suggested Answers
  • 5 Answers
SOURCE: On my Samsung LED TV Series 6 I can't use my remote to
You should be able to receive a replacment remote under your limited parts warranty. If not, there are several resources on the web.
Posted on Mar 10, 2010
  • 51 Answers
SOURCE: my samsung 55" 3d led 8000 series tv dont seems to
You need a 3D source.
Posted on Nov 28, 2010
Samsung LED TV, Model# UN55B6000VFXZA turns on to black screen then displays large blocks of colored vertical lines?
check every flat cable main boerd to t-con t-con to display if dont help display is a problem
Feb 24, 2017 | Samsung Televison & Video
How to reset samsung led tv to factory settings?
Step 1 Press the "Menu" button on the Samsung LED TV or the remote control. Step 2
Press the up or down arrow buttons and highlight "Support." Press the "Enter" button to open the Support Menu.
Related Reading: How to Reset a Samsung DVD Recorder Step 3
Select "Self Diagnosis" and press the "Enter" button. Select the "Reset" option and press "Enter." Step 4
Enter your TV's security PIN. The default PIN is 0000; however, if you had previously changed it, enter the new PIN. Step 5
Select "Yes" to confirm your selection when the "All settings will return to factory defaults except network settings" dialog message appears on the screen. The TV powers off automatically and restores the default factory settings.
How to Reset Samsung LED TV to Factory Defaults
Nov 29, 2015 | Samsung Televison & Video
I have a samsung dvd player that connects to my samsung flat screen tv. Every now and then someone uses the tv and i don't know how they work it but the info button then doesn't work. if i disconnect
Contact the Samsung service centre. It sounds to be a strange fault with Samsung brand TVs.
Inform them the problem you faces with the TV. They will surely provide a solution.
Nov 25, 2014 | Samsung Televison & Video
My samsung 3D led multisystem smart TV remote control does not work anymore
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Please rate if Helpful.
Good Luck !!
  1. TV off
Within 3 feet of TV
and RESET buttons:
Apr 15, 2014 | Samsung TV Remote Control
My samsung led-tv remote controll dont work corectly!
Check it by cleaning up. To clean it, you have to open the remote control. If you wish to get some details about how to clean a remtoe control, check the site linked here. Pull up older posts.
Dec 17, 2013 | GE Televison & Video
replace the lamp only takes few min make sure you get right one for model of tv the LAMP MODEL number will be on OLD LAMP the tv will work and sound will come back hope this helps
Oct 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung Remote Control not working
any samsung remote will work any samsung television. Samsung use the same code for all television's as do Sony
Samsung remotes are quite expensive you could always buy a Sky digibox remote and tune that in to work you tv that would be a cheaper option.
how to tune in the sky remote to work your samsung tv
RED + SELECT ( blinks twice)
Job done
Hope this helps you out.
Little Dish Fitter
Sep 02, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
