Question about Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater
I GET NO HOT WATER
I HAVE A 40 GAL. RICHMOND WATER HEATER AND I GET NO HOT WATER
  • 4 more comments
  • will clark Aug 01, 2009
    its electric and made by richmond
    I GET NO HOT WATER ITS ELECTRIC AND MADE BY RICHMOND 50 GAL WATER HEATER
  • snap101
    snap101 May 11, 2010
    is it gas or electric?
  • jhhoppe May 11, 2010
    Is it electric or gas.
  • 154 Answers
Needs drop tube or full replacement
Posted on Aug 01, 2009
Richmond 40 gal water heater from 2003 gurgles loudly when refilling, is that normal
I'm not sure what you mean by "gurgles when refilling." If you mean that it is making noise when heating the water, that is usually a sign that sediment has built up in the bottom of the tank. This results in the surface of the tank bottom to overheat and the sound you hear is the water flashing to steam. This usually results in tank failure as the glass lining will crack an the tank will rust out. If it's not too late you could drain and flush the tank to try to remove the sediment but if has hardened to a solid mass it won't come out.
Sep 14, 2016 | Rheem Richmond 40 Gal Nat Gas 6 Year Power...
My hot water just stopped running from hot side but cold still runs all sinks so what happen
the is a tube inside the heater that sometimes fails . and all you get is cold water call a local plumber and have them check the DIP tube
Jun 17, 2015 | Rheem Richmond 40 Gal Nat Gas 6 Year Power...
I have a 640dors reliance capacity40 water won't stay hot long(electric)
remove the two covers one high and one low and set the temp higher. This time of year with colder water comming in the house the water heater has to work harder to raise the temp of the incomming water. In the summer the incommong water is much warmer. 40 gal is a small water heater and you will only get about 15 gal of hot water with the ice cold water entering the water heater as you use the hot water. You can get a bigger water heater. even better is to go tankless and a have never ending hot water and save money at the same time.
Jan 10, 2013 | Reliance & 40 Gal Electric Mobile Home...
I need to adjust water temperature, and dont have a manual. i have a 81v40d C model , 40 gal electric.
Here is a tip that I wrote to help people understand how to adjust the temperature on their electric hot water heater.
Electric Hot Water Heater Temperature Adjustment
heatman101
Oct 16, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Richmond power vent water heater won't stay lit. I've reset the unit several times and the unit will run for about 10-15 minuets then shuts down (into lock down). Then I have to shut it off unplug it and...
I have a 40 gal richmond water heater with power vent and had a similar roblem. I call to talk to a tech and he suggested the vacuum switch. I ordered on line. It was $43 plus shipping and I installed it and it did the job. I happy.
Mar 29, 2010 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Low amount of hot water
You say a very new water heater. You won't get 40 gallons of hot water from a 40 gallon water heater because the continuing influx of cold water will cool your hot water down. However, it appears that your bottom water heater element needs replacing. If the top element is bad, you'll get no hot water. If your bottom element is bad, you'll get "some" hot water. Try replacing the bottom element. DON'T FORGET to turn off the electricity AND water first (closeby towels are also handy)!
Mar 09, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater Logo
552 people viewed this question
Top Audiovox Water Heaters Experts
paulcarew
jdthefixer
Richard Lindsey ...
Are you an Audiovox Water Heater Expert? Answer questions, earn points and help others
