Question about Galaxy Cell Phones
My galaxy J1mini wouldn't boot up, so I factory reset it and still now its rebooting but its gone berko. You have to tap the screen in repeativly to get it to respond ..in words..its no good Can anyone help? Please
  • 45 Answers
SOURCE: HTC Touch screen not responding!
This is a common problem with many touch screen phones. There are about three reasons this can happen that I know of:
1. Hardware issue. Needs to go in for repair. Hopefully under warranty still.
2. Needs to be re-flashed with the OEM ROM. This is not likely, since you've already Hard Reset, but worth a try.
3. The EASIEST and FIRST thing to check is to run a 'business card' around the edge of the screen between the case and screen. Dirt or other objects can easily get wedged into that area and hold the screen pressed down. This would prevent a press from any other area of the screen. Also, a screen protector that has shifted might cause this. Hopefully this is it, as it's a simple fix!
Posted on Aug 28, 2008
fixphonenow
  • 66 Answers
SOURCE: white screen for xv6700
You need a new display. contact your local cell phone repair tech or you can contact www.fixphonenow.com we can do this repair for $75.
Posted on Nov 22, 2008
zohail
  • 1223 Answers
SOURCE: My screen is lockedI did a hard reset and screen wont respond
ur touch panel is faulty u have to go to service centre , there are 3 things coupled together Lcd screen then touch panel and then front housing for protection of both , u might dropped it , if ur screen is working partially i mean if it responds to taps at some region of screen then it may be a dust inside the housing u have to clean it from inside if u can , otherwise if it completely not responding then it is faulty touch panel , it will cost u around 50 , 60 $
Posted on Feb 20, 2009
VargheseAcer
  • 142 Answers
SOURCE: Trying to do a full factory recovery on an M Series gateway note
If you want to do the factory recovery, 3 ways to do the system recovery
First way
1 login to windows
2.click Start
3. click All programs
4. click Gateway
5. click gateway recovery manager
6. click restore
7. select systems recovery to factory defaults
Computer will restart itself and start doing the system recovery itself, All you need to do is follow the screen
Posted on Sep 17, 2009
joelr2005
  • 464 Answers
SOURCE: my screen has gone dim on my ibm thinkpad r50e,
if the screen is dim and the images still display it means that the it's probably the CCFL tube or the inverter (located in lcd panel) it will need to be replaced.
Posted on Mar 06, 2010
Testimonial: "thanks for help, have ordered new inverter to see if that works. thanks again :)"
More than 5 times swip screen
Let's start with the most common Hard Reset methods and go from there:
Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
6. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS...
While the phones power is off, press and hold the Volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step).
A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key.
Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up.
Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK.
After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK.
Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen.
7. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS.
Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit.
The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press the Volume up key to boot in this mode.
Wait for the "triangle!/Android" screen to pop up. Once it does press both the Volume up and Volume down keys simultaneously. A Recovery Menu should pop up.
Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection.
After it's done make sure "reboot system now" is highlighted and then tap the Power button.
In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through.
8. Here is a hard reset for a Sharp Android Smartphone.
While the device is off, hold the Sym button (it's located on the keyboard) and the Power button simultaneously.
Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection.
Scroll down to Yes - delete all user data and then press the Power key to confirm.
Once it is done select reboot system now and press the Power key to confirm and reboot your handset.
Mar 23, 2014 | Samsung GT-S6102 Galaxy Y DUOS - Unlocked...
Safe mode is on how do I turn it off
Mar 22, 2014 | Samsung Galaxy S 4G Cell Phone
I entered 1 number off from my number lock passlock i would like to reset the phone
Mar 17, 2014 | Samsung Galaxy Rush Boost Mobile
I can not lock my phone any more
Mar 17, 2014 | Samsung Galaxy GT-S5570
Samsung prevail hangs up after two hours
Mar 17, 2014 | Samsung Galaxy Prevail
I need my samsung galaxy s4 work in other country, i need free unlock code.
Mar 15, 2014 | Samsung GALAXY S4
Boot up stuck on samsung
try this
^_^
Mar 13, 2014 | Samsung Galaxy Prevail
Samsung galaxy s2 screen not locking
try this
Mar 07, 2014 | Samsung Galaxy S GTI9000 Smartphone
The flight mode setting in my samsung galaxy gt19003 i could not remove it.. this is un able me to make calls and messaging even my wifi net work are unable to access.
try to restore it
this one note all files will be deleted
Mar 01, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
Unlock
restore
^_^
Feb 26, 2014 | Samsung Galaxy Ace Gt-s5830i - Black...
Cell Phones Logo
24 people viewed this question
Top Galaxy Cell Phones Experts
Old-Guy-also
Level 1 Expert
Lawrence Oravetz
Are you a Galaxy Cell Phone Expert? Answer questions, earn points and help others
