Question about GPS
Tom Tom only 2 weeks old switched off after last used won't switch on again
SOURCE: Tom tom go 720
I have exactly the same problem. Everything worked fine until I did a software upgrade. I have tried the reset suggestion but it has not fixed the problem. I have been told that a possible solution is to install the version of the OS that was there prior to the upgrade but I cannot find this anywhere
Posted on Jan 13, 2008
SOURCE: Tom Tom sat nav takes ages to get a GPS signal now.
Just purchased a tomtom XL IQ and am having problems with connecting to a GPS signal it keeps saying trying to find a valid GPS signal, can this be fixed or should I replace it for not working properly?
Posted on Jul 27, 2009
co7196
  • 3433 Answers
SOURCE: ON/Off switch not working
What does the on/off switch control? 30 min is a long time to mess with a switch. Ok, I see the picture on the left. If you dare attempt to replace the switch you can more than likely find one at radio shack. Make sure you unplug the unit before openining it up..
Posted on Sep 28, 2009
  • 1111 Answers
SOURCE: Won,t switch on,fully charged,where can i find the
the rest for your go 700 is on the bottom where the mount connects,,see picture below.
Posted on Jan 20, 2010
SOURCE: tom tom 1 4n00.012
Hello, I have a GPS device model Tom tom 1 4n00.012
I have the LCD it is broken and needs can help Nmyr How can I get an LCD and also how much it cost with the wind thanks posts. My email address: yosef1019@yahoo.com
Posted on Jul 24, 2010
4wheel drive won't work
First check the fuse located in fuse box under hood. The most common problem is in the push-button switch located in the dash. I am a 67 year old female and fixed my boyfriend's 4WD in under 1/2 hour last week-end. You can order a new switch on eBay for under $40.00. Adjust steering wheel to lowest position and pull shift lever all the way down. Remove dash bezel from around gauges and switch (it just pops loose). This takes a little time getting it off from around steering column, etc. Just be gentle and patient. Snap out old switch, unsnap wiring, replace with new switch, snap in, replace dash bezel and you're done! There is a video on uTube showing steps. His 4X4 works perfect now and I get to tease him Double benefit. This was on a 1999 Chevy Silverado 1500. Let me know how it goes. Good Luck! -Marilyn
Sep 27, 2012 | 1999 Chevrolet Silverado 1500
Tom Tom sat nav language
There should be a language change option in one of the Tom Tom menu`s
Feb 15, 2009 | Tomtom One XL GPS Receiver
Tom tom 1 will not switch on
Charge it through the computer using your USB cable for a good 2 hours and try switching it on again. It happened to me and it seemed to work fine after that.
Dec 13, 2008 | Tomtom GO 910 GPS Receiver
Not switching on
Complain to Tom Tom ,you may have a lemon,look for law suit soon
Feb 21, 2008 | Tomtom GO 910 GPS Receiver
GE Washer
have they checked the door lid switch?..it could be intermittent also because if the switch is not close, it would not drain and spin anymore. try to bypass the switch temporarily by shorting it out then use it . becarefull because you can now open the door while it is spinning ad it is very dangerous.
Feb 17, 2008 | GE WPRB9110WH Top Load Washer
Sharp TV switches to "input 2"
There's an option on the menu to tuen 'demo mode' on and off. If it's set to on, that's your problem. It will be switching input sources every 2 minutes or so. Switch this off and it'll be ok again.
Feb 13, 2008 | Dual XDVD8181 Car Video Player
GPS Won't Turn On
www.batteryship.com
look up tomtom 510 - or whatever model you have
Order the battery..........comes with manual and tools to fix it
only 20.95
it works
cheaper than sending it in!!!!!!
These are genuine replacement parts!!
Laura
Jan 30, 2008 | Tomtom GO 510 GPS Receiver
GPS Won't Turn On
If its a battery problem the unit still works while charging!
If not it sounds like the OS or SD card has become corrupt.
you'll have to wipe both clean & start again...
tomtom will talk you through this either via an email or on the phone.
http://www.tomtom.com/support/support.php?ID=2
Dec 11, 2007 | Tomtom ONE GPS Receiver
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
