Question about Sewing Machines
Looking for a manual for Bernette 720 sewing machine
  • Sewing Machines Master
  • 11,140 Answers
Posted on Aug 11, 2017
RickE1
  • 202 Answers
SOURCE: Bernette 65 Sewing machine
As a Bernina tech I may be a bit biased on this but I can say this... If you decide on this machine be sure you get it from a dealership with an on-site technician. Any can be an Authorized dealer but not many have a Certified technician. Not to say that you will need one but if it does get an issue in can be taken care of promptly. Also Bernina dealerships are required to have a class for you on their machines. I have worked for a Bernina dealership for the past 5 years and have not had a Bernette come in for a repair. Of the reviews I've read the complaints are of the tension which seems most likely a user default such as not keeping it clean after use, using cheap thread, not understanding how to adjust it for different fabrics, the right type of needle, etc.
I like the 1 step buttonholer and the threader. I wish the lighting was better.
If your going to spend less than 200.00 on a new machine you could do much worse. If you decide to not do the Bernette consider the Janome line next. (with an on-site tech)
Good luck.
Posted on Aug 19, 2008
  • 19 Answers
SOURCE: Bernina Bernette 65 sewing machine
Presumably neither of you has or knows how to adjust your bobbin tension so, I'm going to presume it's your hook. Make sure you are threading the machine coorectly then you'll need to remove your needle plate by removing the two screws, pull out your hook (this is the part your bobbin sits in) but make sure you note which way it sits inside your machine. Have a look at the plastic hook for any sharp edges or burs, you may need to replace your hook or try and gently sand (400grit) the plastic if possible. The key part of the hook is the small blunted point as this is what catched the loop of thread behind the needle. Please make sure that when you put your hook back in, that it is on the left side of that little guard sticking out on the lower right of your machine.
Posted on Dec 10, 2008
safenude
  • 124 Answers
SOURCE: Loose stitch
Welcome to FixYa. I am the sewing machine expert that chose your issue to solve.
When everything seems to be working fine and an occasional stitch is loose.....now get ready.......here it is.......the needle!
It seems impossible, but the needle is the most neglected part of the machine. The one you are using could be slightly bent or have a slight burr that you won't see with the naked eye. Also, needles, especially in an embroidery machine (which work their buns off), are only good for about 8 hours of cumulative use. I would say that an embroidery needle should be retired after 3 or 4. They get dull like a razor blade which can cause enough drag to create a timing issue that's barely perceptible.
Welcome to FixYa! I am the sewing machine expert that chose to help you with your issue.
There are really only two things that can cause bottom (note: remember that problems with the bottom thread, almost always comes from the top and not the bobbin. Bobbins rarely need tension adjustments). These two things are:
  1. An area was missed when the machine was threaded (most machines have an arrow at each area on the thread path where the thread MUST run or the stitch on the bottom will be sloppy. Threading can be tricky and even the most experienced miss once in a while.
  2. The tension adjustment mechanism in the thread path. If the thread is not properly through this area, the thread on the bottom will be sloppy or if, threaded properly, and the tension is set too loose, the stitch will be sloppy. If the tension is set too tight, the bottom thread will be tight and pucker the fabric.
It is counter-intuitive that problems with the top tension cause problems with the bottom stitch but it sure will.
So try it and see if that helps.
Thanks for using FixYa.com
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further.
Posted on Jan 31, 2009
bargainbox
  • 1388 Answers
SOURCE: Please walk me thru winding the bobbin on a
Try this page for Threading and Bobbin Winding Diagrams for loads of machines.....even if your model is not specified, there's a good chance you will be able to work it out from similar machines. http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Posted on Sep 04, 2009
SOURCE: Looking for a free download of Singer Sewing Machine 6235
if you still haven't found one, reply to this thread. I have one as a PDF that I just bought for $5 that I'd be willing to share (this goes for anyone who finds this post, too)
Posted on Feb 26, 2010
Where can I get power cord, foot pedal, and manual?
About 17,700 results (0.94 seconds) Search Results
    Bernette Sewing Machines - BERNINA Support: Machine ...
    www.bernina.com/...Manuals/bernette-manuals/Bernette-Sewing-Machin...
    Bernette Sewing Machines Within this section are the Bernette series of sewing machine manuals that are no longer ... bernette 50 / 60 / 70 / 75 Manual (7.4 MB).Missing: power
    [PDF]Manual - Bernina
    www.bernina.com/de/.../BERNINA.../bernette.../Manuals/deco340_EN_...
    Congratulations on your decision to buy the bernette Deco 340. By owning .... Insert the power supply plug into the wall outlet and turn the power switch on. 1.
    BERNINA Support: Machine and Accessories Finders, and ...
    www.bernina.com/en-US/Support-US
    Out of Print Manuals. Out of ... BERNINA FAQ - Find answers to frequently asked questions. ... Please note: this service can only address SOFTWARE questions.
    www.bernina.com/.../BERNINA.../BERNINA.../Manuals/0333017104_2...
    You've decided on BERNINA, a reliable choice that will delight you for years to come. For over 100 .... Power cable. · .... control the sewing speed by pressing the foot
Feb 03, 2016 | Bernina Bernette 75
How do I turn off THE BOBBIN winder on a Bernette 65 sewing machine?
The bobbin spindle needs to be moved to the left in the slot to disengage the winding mechanism. (It may be easier to do this with the bobbin on the spindle. The bobbin and spindle should be moved to the right after putting the bobbin on for winding.)
The directions and pictures for winding the bobbin are on page 30-31 of the manual. The manual is available from Bernina on their support page for the out-of-print Bernette machine manuals: .http://www.bernina.com/en-US/Support-US/Out-of-Print-Manuals/bernette-manuals/Bernette-Sewing-Machines . The direct link to the Bernette 65 manual is here: http://www.bernina.com/getdoc/6d2754b8-af09-4edb-a6a6-7a4c57965b8d/bernette-55-65-80e-90e .
I hope this helps.
Oct 13, 2015 | Bernina BERNETTE 65 Mechanical Sewing...
BERNETTE 720 SEWING MACHINE MANUAL
Try requesting a manual directly from Bernette.
Jan 09, 2015 | Sewing Machines
I have a bernette 720 with no instruction manual, where do I re fill bobbin?
You can obtain the manual on line free at: http://homeappliance.manualsonline.com/manuals/mfg/bernina/730.html?p=1
It may be useful in the future for other things once you get stitching. Enjoy.
Oct 12, 2014 | Sewing Machines
How to insert bobbin in a bernette 680 sewing machine?
Try going to this link and download the manual for either the Bernette 410 or 715 and look at the directions for threading and inserting the bobbin:
Bernina may not have a manual for your particular model, but these models may be close enough that you can still use the directions for your machine.
Jul 07, 2014 | Bernina BERNETTE 65 Mechanical Sewing...
Tension on a Bernette 720
Is the presser bar release lever jammed or left raised?
Jan 08, 2014 | Bernina Bernette 75
Bernette 720
try a sewing machine shop in your area, if they don't have them, they can order them for you.
Nov 25, 2013 | Bernina Sewing Machines
Feeddogs on a bernette 720 sewing machine do not advance the fabric
Open up the door for the bobbin case and look inside to the right you will find a silver lever make sure that is pressed in this will allow for you feed dog to rise about the plate(it will give you sewinfg mode)
Apr 19, 2010 | Bernina Bernette 75
Sewing Machines Logo
52 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
