Question about Miscellaneous
Feeding machine Bernette720
Why has my machine stopped feeding?
did the feed dogs drop down .
Mar 12, 2015 | Singer 1507
My wimsew sewing machine is not feeding the material properley changing from large to small stiches
sounds like the feed dogs need to be checked if the machine is not feeding the fabric thru
also sounds like the sewing machine needs some type of adjustment since it's going from large to small stitches.
Aug 18, 2013 | WSM Wimsew 20U Mechanical Sewing Machine
Pressure foot or feeding foot?
Increase the pressure on the presser foot.
Jul 18, 2012 | Juki DDL8300N Sewing Machine
Won't sew, the fabric stays in one spot
is the problem the fabric is not moving forward but staying in one spot? which would mean the feeddogs need to be checked to see what position there in --up for sewing---down for darning
or the thread is not feeding into the machine?
Feb 10, 2012 | Janome DC3050 Computerized Sewing Machine
Why the paper get stuck while copying, and the machine make a loud noise
it may be feeding from the wrong tray. i was trying to copy short paper and it was feeding from the long paper section. this caused it to stick ever time. make sure the machine is feeding from the right tray.
Jan 23, 2010 | Sharp AL-1655CS Copier
Water didnt shut off at medium load. overfilled
Sonds like faulty pressure swith/ or hole in air pipe feeding switch/or chamber blocked feeding air hose..Good luck
Sep 30, 2009 | Washing Machines
Feeding teeth on machine
There is either a "darning" option knob on machine, lower right hand, or a metal rod on top right that you use to lower the feeddogs.
Apr 20, 2009 | Singer Sewing Machines
Miscellaneous Logo
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
Dan Grod
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
