My sky comes on but cant get any channels menu comes up pick a channel and nothing happens
  • 476 Answers
SOURCE: probem getting sky to work with a new TV
An HD TV connects in the same way as a standard TV.
Connect a scart lead from the TV scart of the Sky box to the TV.
When you switch on the Sky box it should automatically switch the TV to the correct external input.
Posted on May 20, 2008
  • 24 Answers
SOURCE: Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Posted on Aug 20, 2008
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
  • 89 Answers
SOURCE: Tv won't change channel
did you hook the tv up to the converter box or did you not add channels?
Posted on Aug 05, 2009
SOURCE: UNABLE TO VIEW ITV CHANNEL 4 OR SKY SPORTS NEWS ON MATSUI TV
try tuning tv in another room, if it works it is then your cable or socket, try the cable next. If it wont tune its a faulty set.
Posted on Nov 16, 2009
I HAVE NO IDEA HOW TO TUNE IN MY T V HAVE ALWAYS USED MY SKY REMOTE BUT AS BOX IS BROKEN I AM NOT GOING TO USE SKY ANY MORE PLEASE HELP AS CANT WATCH ANY TV AT THE MOMENT
first off you need an antenna attached to the home and TV the you do a channel search through the main setup menu. the antenna ,unless it is a 360 degree type needs to point in the direction of your local stations .otherwise you may not find all that are there . GOOD LUCK
Sep 15, 2015 | LG Televison & Video
TV link not working with my LG 50PH660V 50-inch Widescreen 1080p Full HD 3D Smart Plasma TV with Freeview HD/600Hz. I connected coax cable to my Sky Box, switching on the RF on, but I can not get it w
Hi Jim, your nearly there, all you need to do is go into the tv menu and move from DTV to the old type channel numbers and then find the bit where you can manually tune the tv to channel 68.
Have a sky menu picture running and you will see it come in.
Feb 03, 2015 | LG Televison & Video
Proline LVD TV and DVD player problem. Hi, I can't get a picture using the RF option. I'm not sure what input I should select for this but I've tried them all and no joy in seeing the sky picture from the...
Hi Greg, i think your missing something simple.
Pick a channel number you want the Sky on, then in the tv set up
manually tune that channel to 68, or if it's showing lots of numbers for the frequency then just search towards the end and it should pick up. On the Sky box leave a menu showing so it's easier to spot when it gets to picking it up.
Nov 10, 2014 | Televison & Video
How do I tune a tv to sky channel
Turn on sky box, select a menu so you have a steady output.
Easy way is a scart lead (no tuning required) choose "av1" or whatever your plugged in to.
If just using ariel lead, pick a channel on tv for example no 6 and tune that to frequency 68.
If your tv does'nt use these numbers then scan until it comes through
Jul 31, 2014 | Samsung T27B550 68.6 cm 27" 1080p LED-LCD...
Some times it;s some channel's, then a nother time it's other cha
Delete problem channels then
Menu-Installation-Manual Scan-Down Frequency=000000-
Network Scan=Enable (use R/L arrow on remote)
Wait a moment press OK the channels should be at the end of your list.
Your Fav.list will NOT be lost
Jun 20, 2009 | StarTech.com StarView SV211K 2-port KVM...
Starview 4 thebox super usb
hope this is of help to you if not let me know .
press menu.
press 1570.
look down list to make sure EMU is set to ON . press ok.
code screen service provider tab should be 5A01.
00. go to the bottom of screen and change the codes saving each code entered.
go to the 00 tab and press right to 01. go to the code tab and change codes saving each code as entered.
0.C0 F6 61 87 91 F9 67 57
1.F0 83 35 E5 28 40 49 B2
Dec 11, 2008 | StarTech.com StarView SV211K 2-port KVM...
Starview the box 2 lost channels
Press menu
type 1570
scroll to nagravision menu and press ok
scroll down to start of line 00
enter codes
press ok to save
scroll back to line 00 under provider code and press right arrow to change to 01
scroll to code line and enter codes
press ok to save
press exit a few times to get back to viewing screen
if you entered the correct codes then your channels should be working.
Hope this helps
Dec 01, 2008 | StarTech.com StarView SV211K 2-port KVM...
Aug 20, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
