SOURCE: My nokia n72 keeps on saying memory full.....
hie!
if ur cell is displaying the memory full warning, it means ur phone memory is full, try to reduce some software frm the phone memory, and always install the softwares on ur memory card whenever it ask to install the path, while installing a software.
if the problem is still there, of memory full after emptying ur phone memory, then soft format ur cell, by pressing *#7370# and then the security code(12345 by default)
bt before that backup all ur important datasuch as contacts and mesages of the phone memory, as then soft format reset all the settings and flash all the phone memory.
bunty
SOURCE: My renoir says memory full.
I had this problem with two Renoirs and finally managed to fix it yesterday after months and months!
I went into browser settings and hit reset settings. I took ages and I thought it had frozen but when it finally finished I had 69% free in common memory!
That worked on both my phones so might be worth a try.
Good luck
SOURCE: nokia 5800 memory full even not
Dear...There seems virus attacked on ur phone.Just scan ur phone memory and card through a good PC ANTIVIRUS by using MASS STORAGE MODE.Find and delete any .exe file from ur phone and card.
SOURCE: Camera keeps saying internal memory is full, even after putting a
Your internal memory is separate from your memory card. Think of it as two folders, the internal memory cannot be removed, and the memory card is one you can take with you. You can put new memory cards in it all day, the internal memory will still have pictures in it. You may wish to consider copying all internal memory to the memory card. To do this, make sure your camera has a memory card in it. View pictures on your internal memory, then from the menu option select 'copy all images to external memory.' In doing this, all of your photos will be moved, you can then clean out your internal memory by deleting everything/formatting it. :)
