Question about Locks & Locksmithing
How to open digital safe box alphamax without key Mistaken to key in number in closing the safe. .its automatic reset, key lost. .is there any default number to open the safe.
  • 10,291 Answers
Nope.. You'll have to drill the lock mechanism which will destroy the safe.
Posted on Sep 14, 2017
mickspaceNET
  • 115 Answers
SOURCE: Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Posted on Feb 06, 2009
SOURCE: unable to open digital safe
I have a similar problem as I have acquired (last night) a similar Woolies safe, locked, batteries dead & keys do not work. I am told you may be able to reset the code if you can depress the red button on the back of the door from the back of the safe through one of the bolt holes, easier said than done! Needs a stiff piece of wire or thin steel... good luck I will try this technique soon. These instructions were found by surfing the Net...
Posted on Apr 09, 2009
  • 4090 Answers
SOURCE: Batteries are dead and I've lost the keys. Its an
Only through a licensed locksmith. Provide the key numbers and possibly even take the safe to him/her as proof of ownership. Locksmiths have to record all attemots to open safe's or maling f keysto the police.
Please provide a rating for my help++++Thanks for using FIXYA
Posted on Jun 15, 2010
Testimonial: "Cheers! Relieved I can at least have it opened without damaging the thing."
SOURCE: Detroit electronic digital safe lost code and keys
Help, just boughta Detroit digital safe, code number to open my instructions are locked inside.
Posted on Aug 20, 2010
SOURCE: I LOST THE MANUAL, HOW TO RESET THE NEW NUMBER?
I LOST THE MANUAL FOR THE 'HARDLINE' DIGITAL ELECTRONIC SAFE. HOW TO RESET A NEW NUMBER?
Posted on Sep 08, 2010
How to open digital safe box (alphamax) without key
No there is no default code, if there was all alphamax safes would be useless, your only option is a locksmith.
Aug 11, 2017 | The Home Security
Where can I get replacement keys for GX B0709 digital safe
There might be a code on the key lock. Manufacturers can sometimes furnish replacement keys by the code or serial number of the safe. A locksmith could also pick the lock and make a key. Keys are really essential if the electronic lock fails. If the safe needs to be opened without keys, a pro can do this with minimal damage.
Aug 06, 2014 | Safe International Digital Electronic Safe...
Cannot open my secret safe by justice
Reference: Paisley Electronic Push Code Safe
Item # 5661462
Purchased at Justice. May be one of the following design/colors: 1. Pink and black 2. neon green 3. tye-dye (all in zebra pattern, I believe)
To gain access to safe without code proceed with the following simple instructions:
Use a screw driver to access batteries on the bottom of the safe. Remove all three AA batteries.
WAIT AT LEAST TEN SECONDS before reinserting betteries to functional position. Replace screw. Key in default passcode "0000#" Safe will now be unlocked and upon opening you can reset passcode. Hold down the "*" and when voice prompted to "key in passcode" enter new 4 digit code followed by the # sign... HOLD "*" until completed code with "#" You will hear the voice command, "enter passcode" after each digit entered. [Press & hold "*" (1234) press "#" release "*"] Close safe and new passcode should be set and work properly. If not, enter default "0000#" and try to reset once again.
Feb 03, 2014 | Toys
Kingavon electronic safe 28
  1. The original factory code is 1-5-9 A (or B) to open the safe. There is usually an override key for your safe in case you have lost your code.
  2. Once the unit is open, you can reset the combination by pressing the red button, the yellow light will come on. Input a new code 3-8 numbers and then either the A or B button to finish the code.
  3. Test your new code several times before locking.
  4. If you don't have an over ride key, the first three digits of the serial number should be the key code.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 24, 2010 | Safe International Digital Electronic Safe...
ACCIDENTLY LOST COMBINATION FOR DIGITAL SAFE , HAVE TO USE KEY
Take off front plate key will open, reset with default 159a should help
Sep 28, 2009 | Safe International Digital Electronic Safe...
I have lost my pin and backup keys + battery dead!
i got the same problem i lost my key and cant open now
any idea what to do
May 28, 2009 | Safe International Digital Electronic Safe...
Locks & Locksmithing Logo
571 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
