Question about GE Ovens
GE wall oven model JKP65WOP3WG- looking for the oven door replacement part. thanks
  • 100 Answers
SOURCE: Ge wall oven blinking door locked for days
The switch inside the door lock mechanism is stuck down making the unit think it is still locked.  the switched is located next to the hook that locks your door.
Posted on Oct 31, 2007
  • 2651 Answers
SOURCE: Replacing a 30 inch wall oven -
a number of solutions for your problem a little smaller better then a little larger, iv seen depending on surrounding cabinetry, either wood fill strips, lexan(plastic) strip added as a filler. depending on what the installation guide recommends for opening , that is all that would be required what you fill if with will be a purely asthetic choice
Posted on Nov 13, 2008
  • 3 Answers
SOURCE: my wall GE oven turns off and flashes F2
check heat sensor
Posted on Nov 17, 2008
  • 405 Answers
SOURCE: Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Posted on Dec 27, 2008
  • 56 Answers
SOURCE: The handle for our GE Spacemaker (jvm230wv) needs to be replaced.
From one of our sponsers...
Posted on Mar 30, 2009
The inside glass (between the inner and outer glass of the door) of the upper oven door of my GE JT952-30 shattered during a baking cycle. I need the replacement part number and a possible source.
Hello would need the entire model number as you can see by this link there are 32 models of that oven
you can either message me back and I will then pick which is your unit then you would go under door schematic and it would bring up the diagram for your unit which when you clicked on door it would being you to this blown up view of the door this is an example and if you scrolled down to like on this schematic has the outer door glass shown as number 140 in the diagram and then underneath that it would give the part number such as it does for this one being
PART NUMBER: WB57T10259 if you have any further questions or would like me to look your model up further please message me back with the complete model number Thanks Rick
Jun 28, 2011 | GE Profile JT952 Electric Double Oven
I'm in the same situation. I've done a little research and found that the oven door can be changed out rather easily. If you have your Model # and Serial #, located on the inside bottom left corner, you can call GE (1-877-959-8688) and ask if there is a replacement door in the color you would like available for your model. I haven't contacted GE yet, but plan to do so tomorrow to find out if there is a stainless replacement door for my model (and how much it will cost). Hope this helps...good luck!
Nov 10, 2010 | GE Profile JTP18 Electric Single Oven
I have a 1950's GE pink/beige wall mtd w/ matching cooktop...I can't find the model # label on the wall mtd oven ? where is it located ?
Mine is a slightly newer model (1960's pink) and out of the wall at the moment so we looked last night. The nameplate is located just below the opening to the oven, in the center, open the door and look down, riveted on. Maybe yours is there too?
Sep 22, 2010 | GE Ovens
Error Code -F1- and Broken glass door
Welcome to f- 1 is the electronic key pad a key is stuck and usually you will need to replace the key pad site to obtain parts is but before you do disconnect power to unit for 15 min then re connect power to see if unit reset its self. And at Parts you can order the glass you need, Regards, Lee Davidian
Apr 19, 2010 | GE Profile JTP56 Electric Double Oven
I need to replace the glass door front on my GE Profile 27" double wall oven JK955. Other than the outside glass being broken the rest of the door is fine. Can I purchase replacement glass?
Yes, but i believe it comes with the door handle already attached. Full model number, upper or lower and color is needed for looking up the part number. Expect to pay $210-280
Mar 03, 2010 | Ovens
I have a 10 year old GE profile dbl wall oven that I love BUT with a new Stainless fridge, cooktop and dishwasher the wall of white oven is a glaring mis-match. The oven doors both have exterior white...
Go to and check out their instant stainless material which is perfect for refacing your existing appliances and getting the stainless look you want without the stainless pricetag.
Contact these guys with any questions you may have.
Oct 18, 2009 | GE Profile JTP56 Electric Double Oven
Door on GE JTP18 oven does not close tightly.
Not sure if this link will work, but give this a try
There is a recall on the oven door for a few models
Safety Recall GE Wall Oven Models Included in the Recall
Brand Model Numbers Must Begin With Serial Numbers Must Begin With GE® and GE Profile™ JCT915, JT912, JT915, JT952, JT955, JT965, JT980*, JTP20, JTP25, JTP28, JTP48, JTP50, JTP86 TD, VD, ZD, AF, DF, FF, GF, HF, LF, MF, RF, SF, TF, VF, ZF GE Monogram® ZET3058, ZET938, ZET958 TD, VD, ZD, AF, DF, FF, GF, HF, LF, MF, RF, SF, TF, VF, ZF Kenmore
(All model numbers start with 911) 4771, 4775, 4781, 4904, 4905, 4923*
* Lower Oven Only 2T, 2V, 2Z, 3A, 3D, 3F, 3G, 3H, 3L, 3M, 3R, 3S, 3T, 3V, 3Z
and that link shows the door and hinge. Recall info at
May 31, 2009 | GE JTP20 Electric Single Oven
Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
Hi, You can replace the glass piece. You will need the whole model # when you call for the part.
Good luck. Please let me know if I can assist you further.
May 30, 2009 | GE JTP86 Electric Double Oven
Ovens Logo
54 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
