What does ch 1 mean Air con has turned itself off?
3 Suggested Answers
SOURCE: Air conditioner is turning on
Hello Naeva
Plesae visit the link provided below :
Posted on May 01, 2011
  • 10045 Answers
SOURCE: My Conia air con turns on by itself . How can I stop this ??
Make sure the timer mode is not selected.
Posted on Jan 13, 2015
My wall air con kelvinator just installed turned off after 2 hrs and H1 came up on display
H1 is defrost mode. This means that the outdoor coil has gotten too cold and needs to warm itself up in order to continue heating. Heating will resume in a short period. Nothing wrong with machine, this is normal when outdoor air temps are extremely cold.
Jun 21, 2017 | Heating & Cooling
What does "work Puff Stitch, Ch 1" mean?
Usually it is best to perform each step as stated in the pattern. Close the Puff stitch (follow the instructions for closing the Puff stitch), then Chain 1.
Perhaps this will help:
How to Crochet Puff Stitch dummies
Crochet Puff Stitch Slow Motion Crochet
Puff Stitch crochet
Dec 05, 2016 | Sewing Machines
I just moved into a new home and the air cons are kelvinator r51k bgce and it won't turn on when i use the remote and the batteries are working?
pull up the front cover the grill looking piece , not the air out louvers , there maybe a little button , push that in if air con starts up , then you remote sensor may be faulty or the remote itself .
Mar 28, 2014 | Heating & Cooling
What's your problem?Won't stop changing channels
there is every possibility that the channel (ch - and ch +) button on the TV is stuck. This can make the TV channels change by itself. This also applies to the remote control (if any).
Turn off the TV, use your thumb to flip through the channel (ch - and ch +) button on the TV. This will free the stuck button. Also, check the channel (ch - and ch +) buttons on the remove and make sure it is also not stuck in.
If the above doesn't solve the problem, then it means fault is from the control board inside the TV. It maybe defective or needs servicing.
The board controls the buttons on the TV and it can be found on the position of the channel (ch - and ch +) inside the TV.
Note that TV stores a lot of current. So if you want to disassemble the TV to check the board allow the current to discharge by remove the TV plug from the wall and wait for about 1 hour before attempting to disassemble the TV.
Let me know if you need more assistance...
Sep 27, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
We have LG air con system (hot and cold) coming up with error code CH33. What does this mean?
CH 33 -Excessive rise of standard compressor discharge temperature. If over 105°C check refrigerant charge. Over charged, release little gas still to normal PSI. If condenser full of debris, clean it.
Dec 18, 2010 | LG LS-L1210CL Mini Split Air Conditioner
My air con is quite new, it just fixed n used about 5-6 months. Today i just turn on the air con then about 5 second it turn off by itself. My air con is LG brand. How can i do now, is it a big problem or...
dear sir/madam
please check when you make on your air con it,s getting turn off from it,s circuit breaker then it,s an electrical short circuit problem if it,s turn off by it,s remote controller then it can be micro control program error.
if you know how to read to a electrical meter then try to check your electrical main source it,s passing electricity to air con and try to find out the problem
if not then try to contact to maintenance personnel. it,s up to you what you want to select option.
hope answer the question
thank you
please vote!
Sep 23, 2010 | LG Heating & Cooling
Air con indoor unit is flashing 6 times out door is off
Please specify the make and model of your unit.
If this is a LG inverter model.
The six flashes of the indoor unit light indicates a CH 06 alarm.
This alarm state indicates that the indoor unit pipe temperature sensor has measured a temperature out of range or the unit is protecting itself from this low temp state. Indoor unit coil temperature to low. Should it have reached a temperature of -5°C for longer that 30sec it will switch the machine off.
It could indicate that the unit refrigerant charge is too low or the sensor has gone out of calibration.
It should measure 5kΩ @ 25°C
Mar 16, 2010 | LG Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
