Question about Hardware & Accessories
Timer circuit operates but at out put lamp not start
2 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: OPERATION LAMP AND TIMER LAMP
Indoor fan motor mechanism locked.Check for power to F.M. if not, replace PCB. If bearing in F.M. replace it. Thanks.
Posted on Feb 12, 2011
No fuse is labeled for interior lights. Which one is it?
My thought would be room lamp, 15 amp. Interior fuse box.
Dec 16, 2017 | Mercury Cars & Trucks
Inverter manuals
Model No Required below Model No AH-X18MEV Self diagnosis mode given
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
• If the power cord is unplugged or the circuit breaker is turned off, the self-diagnosis memory is lost.
AUX
Operation lamp(red)
Timer lamp(orange)
Super jet lamp(green)
Oct 12, 2013 | Sharp Heating & Cooling
It shuts off and blinks 11
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
Remark
3. CHART
<INDOOR UNIT> ?:1-second ON / 1-second OFF
Problem
symptom
Outdoor
unit indication
(LED1)
Indoor unit Malfunction
No.
Content of diagnosis Check point Action
Lamp Main Sub Main Sub
Normal
condition
Normal
blinking
? ? ? ? ? Timer (Orange) 0 0 Normal
Operation (Red)
Super Jet (Green)
Indoor and
outdoor
units do not
operate.
1-time ? ? ? ? ? Timer (Orange) 1 0 Outdoor unit
thermistor
short-circuit
Heat exchanger
thermistor short
circuit error
(1) Measure the resistance
of the outdoor
unit
thermistors.
(1) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
Super Jet (Green)
? ? ? ? ? Timer (Orange) 1 Outdoor temperature
thermistor
short circuit error
(2) Check the lead wire
of the outdoor unit
thermistor for torn
sheath and shortcircuit.
(2) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 2 Suction thermistor
short circuit
error
(3) No abnormality
found in above
inspections (1) and
(2).
(3) Replace the outdoor
unit control
PWB assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 3 2-way valve
thermistor short
circuit error
? Operation (Red)
? ? Super Jet (Green)
LED1
AU-X24MV, AU-X24MEV
AU-X18MV, AU-X18MEV
LED1
May 27, 2012 | Sharp Heating & Cooling
How to use the TM 111D
1) To use the timer:
Make sure outlet has power.
Check outlet with circuit analyzer to make sure polarity issues do not affect timer operation.
Plug timer into outlet for 1 hour until battery is charged.
Some timers have internal battery that do not need to be charged.
After battery is charged, unplug timer to set programs.
Set program(s).
Turn lamp ON and make sure bulb is good.
Leave lamp turned ON
Plug lamp into timer.
Then plug timer into outlet.
2) To program the timer, open following links for possible instruction manuals:
http://waterheatertimer.org/pdf/How-to-program-Timex-TE111.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#Timex
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 02, 2011 | Timex EASY TO SET TIMER BY TIMEX
Put a new bulb in that i got from e-bay, tv switches on perfect but after a little while it turns itself off then red and green light start to flashing. i don't know what the problem is ????
Hello, I try to help. But your questions not spesific.
Below are conditions lamp indicators that appear blinking and solutions (for samsung) :
1. If Timer and Lamp blinking --> Auto timer on/off was been set, picture will appear ~ 25 second.
2. If Timer and Standby/Temp blinking --> A cooling fan inside the set is not operating properly.
3. If Lamp and Standby/Temp blinking --> The lamp cover on the rear of the set is not installed properly.
I hope that solve your problem.
Thanks
Mar 14, 2011 | Televison & Video
Which is the on position?
You posted under Woods 59382
Open following link to identify timer for sure and download manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#1702
To check switch setting and segment settings, plug timer into outlet, turn lamp on, plug lamp into timer, then manually rotate timer dial clockwise to check operation.
Change the switch, and rotate dial again to see when lamp turns on-off.
After segments and switch are set how you want, then rotate dial until current time lines up with arrowhead located on inner dial.
Analog timers like 59382 have small motor that rotates clock dial just like old fashioned clock.
As dial rotates, segments on dial move lever that opens and closes circuit to lamp.
The switch, or override button, lets you choose if you want timer program to operate, or if you want lamp ON all the time.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Feb 16, 2011 | Woods 59382 15Amp 3Prong Outdoor Heavy...
Installed several GE smart digital timers around the house: for lights over garage, front door, court yard. They are model 15086. The units work in timer mode as desired. I would think...
15086 timer:
Pressing door will override timer setting and manually turn switch ON-OFF.
Press door or open timer door, and press any of 4 buttons located in corners.
You know information posted so far:
However, you are moving the small switch from Timer to OFF.
And when switch is OFF, the override does not work because circuit is OFF.
You want a timer that can switch programming OFF, and not switch circuit OFF, so that device toggles between timer and ordinary switch.
Looking at timers on the market today, I cannot think of any in-wall programmable or box timer that does what you want. Each has manual override that reverses timer function, but when you set timer to OFF, the circuit is OFF.
http://waterheatertimer.org/Programmable.html#Aube
Plug-in-type timers have override button that turns programming off, and then you can operate table lamp normally with the lamp switch. But in that case, the lamp has separate switch that operates outside of timer functions.
GE 15070 24-hour mechanical timer could do what you want:
http://waterheatertimer.org/images/GE-15070-mechanical-timer.jpg
In this specific case, when you wanted to operate timer like a light switch, you would move all the pins inward, and then use the on-off switch. The problem with this idea is the pins are tiny, and you need very good eyes or a light-source and small tool to continually adjust pins.
See GE timers and manuals:
http://waterheatertimer.org/GE-timers-and-manuals.html#15086
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 07, 2011 | UPM Programmable Wall Switch Timer
I have a First Alert model 610 timer. It is an older model and I need the instructions for it.
I called First Alert @ (800) 323-9005 and they faxed me the instructions for Model LS510 which is the same and got it working. They will mail it too but not email. Choose Fixed or Random mode. Choose how many hours it will stay on after dusk. Turn your lamp off and unplug the lamp. Plug lamp into timer. Put function in Fixed or Random position. Put hours on switch to number of hours you want it remain on after dusk. Plug timer into the wall outlet. Turn the lamp's switch on and Timer's LED light should be on and the lamp should be off. Turn the lamp's switch off then on again TWICE. The second time you turn the lamp's switch on the bulb in the lamp will flach on then off quickly. This indicates that the Timer is controlling the lamp's operation. Leave the lamp switch in the ON position. The timer is now set for automatic. I hope this helps.
Jan 06, 2011 | Vacuums
My wall timer controls an outside lamp with an outlet...when I plug in a timer for my outside lights,the switch turns off after blinking a few times....this does not happen when I plug in the out side...
If you have a battery operated timer like Intermatic ST01C, it may not operate another timer.
The ST01C will not operate circuits farther away than 100 feet, or operate when wires are located underground. Sounds peculiar doesn't it.
I assume these parameters are because of how the battery interacts with electronics inside the timer.
On the other hand, maybe your battery is getting weak.
http://waterheatertimer.org/Intermatic-st01c.pdf
The manual shows incandescent, fluorescent, motors and DC loads.
But manual doesn't specifically include or exclude other electronic devices that might put electronic feedback on the line.
I'll run a test on the ST01C next couple days, and post result on this thread.
Dec 13, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Lost glow plug function
Had same thing happen on my New Holland 1630. Took the buss bar off the glow plugs and pulled them out and tested with test leads on the battery. They glowed. Put a volt/ohm meter on the buss bar and turned the key to glow position, no 12 volts present. Checked for blown fuse, nothing blown. Looked at relays. There was a glow plug lamp timer next to the start relay. Wiggled wires going to timer while asking for glow with key. Saw the glow lamp flicker. Took timer out and opened it up. Found a broken solder joint on circuit board resulting in a loose capacitor. Soldered the crack and put back on tractor. That was it! Glow plugs work now.
Dec 04, 2010 | One Step Ahead New Holland Tractor Set
Hardware & Accessories Logo
114 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
