Question about The Computers & Internet
Where do I find the wps pin for my olevia 232s12
3 Suggested Answers
SOURCE: need stand base for olevia 32
Do you happen to know if it's possible to mount the 232s12 on a wall? Do you by any chance still have the manual?
thanks,
jacob
Posted on Mar 09, 2010
gopakumarg43
  • 75471 Answers
SOURCE: olevia 232s12
Contact the nearest authorized service center for Olevia to buy a new original remote control.
Posted on Aug 26, 2012
No sound Olevia 232s12 im seeking the location of the sound processor
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Sep 30, 2015 | Olevia Televison & Video
Where is the WPS pin located on the computer?
The pin is set up in the router under WPS.
Apr 23, 2015 | HP Office Equipment & Supplies
Where is the wps button on a N 1 Belkin route?
Using Wi-Fi Protected Setup
WPS uses WPA2 (described below) for encryption. It does not
provide additional security, but rather, standardizes the method for
securing your wireless network. You may use either the Push Button
Configuration (PBC) method or PIN method to allow a device access to your wireless network. Conceptually, the two methods work as follows:
PBC: Push and hold the WPS button located on the back of your
Router for three seconds. Then initiate the WPS procedure on the client device within two minutes. Refer to your client's documentation on this procedure. Pushing the PBC button will automatically enable WPS. The client has now been securely added to your wireless network.
PIN: The client device has a PIN number (either four or eight digits)
that is associated with WPS. Enable WPS through the GUI shown
below. Enter the client's PIN into the Router's internal registrar
(accessed through this GUI). The client will be automatically enrolled
into your wireless network within two minutes.
Oct 04, 2014 | Belkin (F5D8231-4) Wireless Router...
What is wps pin
Wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices.
WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
  • Push button. The WPS button is either a button on the product or a an option on the wizard or utility screen.
Aug 15, 2014 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Wps pin wireless optical mouse
if i have mouse with usb dongle then no need to wps pin or if not then try 0000 or 1234 its default
Oct 31, 2013 | Microsoft Computers & Internet
Can't find the PIN of this product
Good morning. There is no PIN to find on the router. You get the PIN from the Wireless client and enter into the router setup screen.
The wireless router supports two types of WPS, the WPS via Push Button and WPS via PIN code. If you want to use the Push Button, you have to push a specific button on the wireless client or in the utility of the wireless client to start the WPS mode, and switch the wireless router to WPS mode. You can simply push the WPS button of the wireless router, or click the 'Start to Process' button in the web configuration interface. If you want to use the PIN code, you have to know the PIN code of the wireless client and switch it to WPS mode, then fill-in the PIN code of the wireless client through the web configuration interface of the wireless router.
Here is the link for the Owners Manual for your router..
http://www.encore-usa.com/us/sites/default/files/product_documents/ENHWI-N3_UM.pdf
Hope this helps..
Nov 03, 2012 | Encore ENHWIN3 Wireless Router
Olevia 232s12
Aug 25, 2012 | Olevia 227-S11 27 in. LCD TV
Lower cable channels are blurry and higher cable channels are really blurry. Olevia 232S12. Switched tvs and found cable supplied good picture on different tv. Cable tech checked their system and found no...
It is an indication of faulty Tuner, IF transformer.
Send it to repair shop because it is quite technical.
Resoldering on the tuner section will be done first because any cold solder on that section the same problem will be the result.
Tuner is quite expensive so you better ask the shop to estimate the service fee plus the cost of parts. Now you have an idea how much money you are going to spend.
Thanks for using fixya.
Jan 17, 2011 | Televison & Video
Computers & Internet Logo
29 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
