Lsu121hsv communication issue, what are the possible repairs for this?
What should i look for when getting engine codes u0121,u0101,u0155,u0073,u0100. plus all lights on clusters on. some times car only goes 5mph till i shut off and restart.
All these " U " codes are communication issues amongst modules. These modules communicate on bus wiring from one to another. You have a communication issue with one or more modules. You will most likely have to have the vehicle proffessionaly scanned with a vehicle scan tool to be able to identify the source of this communication issue. You may have a bad module/wiring/power/ground issue to be repaired
Nov 29, 2015 | Cars & Trucks
Have an lg dfs unit not working cooling lamp flashes 7 times heat lamp 6 times what is the problem?
DEFINING COMMON ERROR CODES Aug 29, 2012 - Refer to Service Manuals posted on to troubleshoot individual error codes. Error. Code. Description. No. of Times Indoor Unit ...
Mar 02, 2015 | LG LSN121HSV LSU121HSV 1 Art Cool Ductless...
Washer keeps cycling after wash is complete
Hello friend, thank you for the post!
I understand that your Frigidaire washer, ATF6000ES, continues to cycle after your wash is complete. Sounds like it could possibly be an issue with your control panel or sensor either one may not be communicating that the wash cycles have been completed. Since it maybe either one of these underlying issues, I would recommend having a technician come out to the home to diagnose and repair your washer. I hope this is helpful. -Matt
Aug 02, 2014 | Frigidaire ATF6000ES Front Load Washer
How to get rid from continuous hissing sound of MOTOROLA T4500 ?
Many times the hissing can be caused by a bad or poorly charged battery, or by activating an interference eliminator code in all your radios. First, we would suggest changing the battery, or exchanging it with a known good radio's battery to see if the problem clears up. Environmental RF can also cause issues, so you might check to see if the same problem exists in a different location.
If these suggestions do not solve the problem, then you possibly have an internal issue which would deem the radio non-repairable. Parts and schematics were never offered for this line of radios.
Best regards.
Oct 15, 2013 | Xact Communication Xact Wristlinx X2X...
Put washer on normal cycle and takes over 2 hours to complete cycle. What is the problem
Hello Chad - Thank you for your question! Often when the washer cycle takes too long to complete, it is because it could possibly be experiencing a communication issue with the control board, faulty timer or a potential wiring failure. Try reprogramming the washer by either disconnecting the power to the unit or by unplugging it. If issue persists, I recommend scheduling service so a technician can diagnose and repair your washer.
May 07, 2013 | Frigidaire Washing Machines
Frigadare dryer wont stay running
Hello emergsvc - From what you are describing it could be a number of issues that dryer could be experiencing. The unit could possibly have a wiring failure, communication error from the control board, faulty door lock assembly or power supply. I strongly suggest contacting a professional to accurately diagnosis the unit and to properly assist with the repairs.
Feb 13, 2013 | Frigidaire GLEQ2152ES Electric Dryer
Vertical lines in the scree of my 50
Several possible reasons include:
A bad board somewhere in the set.
A communication or Handshake issue--the boards communicate info to the main board and if not proper certain areas of the screen will have lines etc.
A power supply issue is rare for this but possible.
Last but not least the issue could be a defective PDP---Plasma Display Panel (entire front screen unit) which if is the problem is fatal from a cost point of view.
Not likely any of these are going to be either a do it yourself repair or be repaired in the home.
May 03, 2012 | Samsung PN50C450B1DXZA 50-inch Class...
LCD set if white either communication issue from main to panel or a board that drives that side of screen (inverter possible but not real likely)
If you can get a schematic scope the digital board to the output and look for issues there--if white not likely the display panel but you never know....
Apr 22, 2012 | Samsung LN32A330 32 in. LCD TV
Outlook Express is quite complicated software, which has some usual troubles just like other programs. For example like issue I had some times. But probably one of the most variable determinations would become the next tool - dbx repair tool.
Jun 28, 2010 | Microsoft Outlook Express
Washing Machines Logo
Top Washing Machines Experts
