Question about Jensen Car Audio & Video
Need to know what wires go where on a Jensen A800 model amp
SOURCE: Please help.... I need a wiring diagram or pinout for my Jensen xa1120 amp, thanks
xa 1120 amp pin out 123
456
1 left neg
2 ground to radio
3 left positive
4 right neg
5 blank-not used
6 right positive
Posted on Oct 10, 2008
reynosaelect
  • 165 Answers
SOURCE: need to know which wire is which on jensen cd3720cs
GO TO WWW.JENSEN.COM AND DOWNLOAD THE OWNERS MANUAL.
Posted on Mar 19, 2009
  • 7 Answers
SOURCE: need to know how to wire the speaker mono?
Bridge should be made positive left channel + negitive into - right channel but make sure the amp can take the speaker impedance load or you will trip the amp or cook it if you over load it.
PW NW You may also need a choke for correct frequencey response
Posted on May 30, 2009
  • 57 Answers
SOURCE: Jensen CD-510K hooking a 200
rca cables for audio and a remote wire. just plug the rca cables into the plugs in the back of the deck and the remote wire (i suggest buying a thicker (speaker wire size) gauge wire since it allows you to get more power out of the amp) to the blue remote wire coming from the deck. you will also need an 8 gauge power wire (12 inches to 12 feet depending on where the battery and amp are) and an 8 gauge ground wire (no longer than 24 inches).
Posted on Aug 18, 2010
  • 147 Answers
SOURCE: Wireing diagram for Jensen a800 amp
This amplifier is installed just like any other car audio amp. A great tutorial can be found here:
http://www.caraudiohelp.com/how_to_install_a_car_amp/how_to_install_a_car_amp.htm
Posted on Mar 12, 2011
What amp should I use?
Yes they information available on them they are still around. You will need a class-D 300 watt RMS amp to run them at perfect power if i remember right they are 150 watt RMS,, 450 watt max per sub.// just never mind the max it means nothing. They are a 4 ohm sub i believe so you would want to get a 1 ohm stable amp. two 4 ohm subs can be run at 1 ohm wired in series. they are actually made by audio vox corp.to wire them is easy ill give a link to do so easy to use. and handy. let me look for some info on your sub...? Yes there is info out there here is another link. Need additional help give a shout.
Rockford Fosgate Woofer WiringWizard JENSEN XS1010 Specs
Mar 07, 2016 | Jensen XS-1010 Car Subwoofer
Mar 07, 2011 | Jensen Car Audio & Video
How to hook up a Jensen a800
This amp can be installed just like most any other car audio amp. A great tutorial can be found here:
Mar 06, 2011 | Jensen Car Audio & Video
Jensen CD-510K hooking a 200 watt amp to it.Need to know what wires need to use to hook it up
Aug 18, 2010 | Jensen Car Audio & Video
Dont know how to wire a subwoofer
The Jensen XS1010 is a 4-ohm sub and should work properly off of the outputs of most any single channel monoblock sub amp or off a bridged 2-channel. You did not say what brand or type of amp you intend to use, but in any case, there's only 2 wires to connect to the sub, one positive (+) , the other negative (-). Simply match them up with the positive and negative on the amp speaker output and you are ready to bump.
Here's the link to Jensen's website:
http://mobile.jensen.com/jensen/
I'd recommend downloading the XS1010 manual. They recommend an enclosure with at least .75 CuFt internal volume.
If this helps, please rate it as "FixYa". Thanks!
Mar 28, 2009 | Jensen XS-1010 Car Subwoofer
DON'T KNOW WHAT WIRING KIT TO USE FOR 400WATT 4 CHANNEL AMP
well i will let you know now that 400 watts running into two subs like that will never match. You will want to run only one sub or get a bigger amp. But for that amp a standard 6 gauge power wire will be sufficient to run it. The ground wire about 4 gauge is good.
Feb 23, 2009 | Jensen VM9510 Car DVD Player
Jensen XA2150 Hi Input help
According to crutchfield, this connector should have come with the amp. Was this an open box? I would suggest getting a replacement molex connector from jensen. I see what you are talking about in the manual, and if you don't have the supplied connector, you have a big chance of frying your amp. The manual expects you to have this connector, and is not specific about the actual pins. For all you know, you could be wiring it the opposite way. Either that of call jensen, and ask how the pins are layed out. If you are confident you do have it wired properly, you could try both pins, and see which is the ground, but this is risky of course. There is also the chance there is no actual metal connector in one hole. You can also test for impedance if you have a multimeter, and you definitely should if you are taking shot in the dark with your amp.
Nov 19, 2008 | Jensen XA2150 Car Audio Amplifier
Jensen uv8 wiring issues
The wires you posted need not go anywhere not unless you have a device that will attached to them.
antenna power - connects to the motor of a telescopic external car antenna. When you power on the unit, it will automatically raise the antenna;
amp power - connects to an add-on/external amplifier. This switches/triggers the amp to gon when the Jensen is powered up;
reverse - attaches to the reverse light of your vehicle. This will tell your unit that you are reversing and will activate a rear view camera.
As earlier stated, if you do not have any use of these devices then there is no need to connect the above described wires to anything. Connecting them to the ground would have a bad effect on the internal circuitry of the Jensen since they are meant to supply power and therefore are connected to the B+supply when the Jensen is powered except for the reverse which would sense a 12V from the vehicle's transmission. Connecting them to the constant B+12 would have no ill effect except that your Jensen would always be on.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
good luck and kind regards.
Nov 20, 2007 | Jensen VM9510 Car DVD Player
Jensen 300 amp unknown
go to the harman kardon site and download the owners manual and u can order any thing you need including a new wiring harness
Apr 05, 2007 | Jensen LXA300 Car Audio Amplifier
Car Audio & Video Logo
59 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
