Question about Frigidaire Refrigerators
I just bought a new Frigidaire fridge with freezer on top one week or the freezer is cold but the fridge is not staying cold or repair man came and told me that was because I had the freezer set to the max
    New Friend:
There are ducts coming down from freezer to the fridge lower part ,check to see if they are blocked by groceries in
lowr part.(fridge )
Posted on Aug 11, 2017
  • 75 Answers
SOURCE: Frigidaire Freezer Runs Warm in Cold Weather
hi there the problem you have is that the temp in the garage is to low, the fridge part of your fridge freezer has priority and will only activate the compressor when req'd ie. in cold weather the fridge may not need to switch on the compressor for days at a time this is when the freezer will defrost.
All you can try doing is having some very low heating in your garage in the cold weather
hope this is of help.
Posted on Dec 11, 2007
  • 57 Answers
3 things to check. If you didn't adjust the damer from the freezer to the refrigerator, like closed it off. Is the freezer fan running? The fan blows air from the freezer to the refrigerator section. Some fans shut off when the door is open so you may have to push in the door switch to check this out.
Look for ice on the back wall, of the freezer section, If present then the defrost cycle is not working. The evap. coil is icing up and there is no air blowing into the refrigerator. Set the thermostat back to the normal setting it just causes a longer run time on the freezer section.
Posted on Oct 20, 2008
  • 1239 Answers
SOURCE: Fridge stopped working, freezer still works
If the compressor doesn't run, it is likely that the defrost timer is malfunctioning. This part is located near the compressor. To test the defrost timer:
Step 1:
Unplug the refrigerator.
Step 2:
Disconnect the wires from the timer and timer motor. Remove the timer from its brackets by backing out two retaining screws.
Step 3:
Test the defrost timer with a VOM set to the RX1 scale. Clip one probe of the VOM to each defrost timer -- not motor -- wire, and turn the timer control screw shaft until it clicks. If the defrost timer is functioning, the meter will read zero. If the needle jumps, the defrost timer is faulty. Replace it with a new one of the same type.
Step 4:
Connect the new defrost timer the same way the old one was connected.
To check the defrost timer motor, clip one probe of the VOM to each motor wire, setting the scale to RX100. If the meter reads between about 500 and 3,000 ohms, the motor is functioning properly. If the meter reads higher than 3,000 ohms, the timer motor is faulty. Replace it with a new one of the same type. Connect the new motor the same way the old one was connected.
Posted on Dec 07, 2008
  • 744 Answers
SOURCE: Freezer is too cold, fridge isn't cold enough.
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: defrost stat heaters evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using fixya! Mike p.s. please don't forget to rate this free solution.
Posted on Sep 11, 2009
  • 93 Answers
SOURCE: my refrigerator won't stay cool but my freezer works fine
You have something wrong with the vent going from the freezer to the fridge. You probably have a defrost problem and ice is blocking the vent that goes from the freezer and comes out in the roof of the rerigerator compartment. Replace your defrost timer and bimetal.
Frigidaire frs26h5asb5
Hi Gary,
If your evaporator is not completely frosting over (top to bottom) this normally means the unit doesn't have a proper charge or the compressor can't pump all the freon as it needs to. I would check the charge, this should read "0", if less not enough, if higher than the compressor is failing. I hope this helps.
Aug 17, 2014 | Frigidaire Refrigerators
3 1/2 year old fridge not staying cold in freezer or lower part. Food spoiled. Repair man said fridge was dying. Filled it full of feron. Said we had a leak and it could not be saved. It's only 31/2...
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.Now since the service man has said there is a leak the problem can also be in the compressor or the sealed system.So it is best to take an estimate for a guranteed repair , if not it is best to scrap and buy a new one. Please check this link for tips to work.
Thank you for using Fixya.
Aug 25, 2011 | Frigidaire Refrigerators
Frigidaire top/bottom fridge is on, but not cold in either the fridge or freezer.
We bought a small used Frigidaire refrigerator-freezer on top--Freezer is cold but items in frige are not...what could cause this
Feb 09, 2010 | Frigidaire Refrigerators
New freezer not cooling - temp @ 25 degrees and food is defrosted
It is probably the control board and since it's new it's still under warranty so a certified Frigidaire repair man will fix it without charge. There should be a telephone number with the paperwork you received when you bought it.
Aug 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
On top freezer works fine, fridge compartment below is not cold.
turn the dual temperature switch to warmer for the fridge to cool down.
Apr 04, 2009 | Refrigerators
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer not staying cold
the temp control thinks its cold enough to stay off so you need to have the temp in home warmer so it will cycle / atleast 60 / larry
Dec 12, 2008 | Frigidaire FRT21H8 Top Freezer...
Freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new...
Hi miss_i2000
I'm Harvey the Master Plumber
Your question is: freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new frost free fridge freezer bought 1.5 weeks ago
This is no problem for you. You are under warranty and as long as you have not tryed to repair it yourself you are completely covered. Look for the manufacturer's warranty phone number on the paper work that came with it or call the sales man, he will be happy to track that down for you because he wants repeat business.
If you bought it used the only answer is to return it. You could get a local pro to repair it at yuor own expense but I wouldn't recomend that for a frige only 1.5 weeks old!
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Miele Refrigerators
Refrigerator and freezer not cold
it could be your cold control stuck turn it on and tap it a few times
Dec 11, 2007 | Frigidaire FRT15G4B Top Freezer...
Freezer too cold, fridge to warm
so what is the problem or question? talk to th company u bought the refrigerator from and deman and refund or replacement
Sep 08, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
