How to tune it to a. Fm station or aamstation
  • 3422 Answers
SOURCE: Can't tune to any radio station
HI,
I'll let you know if there is a factory reset button button for this model.
Posted on Jun 12, 2008
welcomejee
  • 10594 Answers
SOURCE: I have a Sherwood RX-2030R,
Check Sherwood RX-2030R specification of AM tuning frequencies limits in user manual.
Please confirm was it tune before below 1320 and above 1710 AM meter band?
Posted on Nov 06, 2008
FLASH O Ride
SOURCE: Help
Possible solution for some of the problems listed: Turn the clock upside down so that the label is readable in the upper left area. On the right side you will find a compartment which may have two "AA" batteries installed. These back up the setting when the clock is unplugged.
To reset the clock, you will have to BOTH remove the batteries AND unplug the AC power cord. Also, make sure the batteries are not dead.
Finally, although I cannot confirm this, there is an opening directly under the label (still looking at the bottom of the clock) which appears to be a "Reset" switch. A pointed object such as a ballpoint pen or toothpick will be needed to press this recessed button. Hope this helps. Mine is working just fine.
Posted on Mar 15, 2009
  • 20 Answers
SOURCE: stock radio won't tune into an FM radio station.
check you attenna connection otherwise it has lost it's ability to seek and stop
Posted on Aug 11, 2009
SOURCE: Ford 6006e cd player won't
code 6006e
Posted on Jul 16, 2010
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
Tip
USING THE WEATHER BAND STATION 1. FOR WEATHER STATIONS, CLICK THE WEAIHER...
1. FOR WEATHER STATIONS, CLICK THE WEAIHER BAND/AM/FM (13) TO “WB”.
2. TUNE FOR THE WEATHER STATIONS BY THE TUNING (14).
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
How Ido tune it l have no manual.Can you please help.many thanks
Radio With Manual Tuning - Alibaba
www.alibaba.com > Automobiles & Motorcycles > radio > radio with
Radio With Manual Tuning, Buy Various High Quality Radio With Manual TuningProducts from Global Radio With Manual Tuning Suppliers and Radio With ...
Help Guide ' Tuning in an FM radio station manually ... - Sony
https://www.sony.co.uk/.../emanual/.../TP0000016777....
Sony CorporationThe headphone cord of headphones is an FM antenna, therefore, connect headphones to the (headphone) jack when listening to the FM radio.
Tuner (radio) - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/Tuner_(radio)
WikipediaA tuner is a subsystem that receives radio frequency (RF) transmissions like radio ...Older models would realize manual tuning by means of mechanically ...
[PDF]Tuning into a Radio Station - Onkyo
Dec 16, 2015 | Audio Players & Recorders
Tune stations on the radio
Use this link to see how to set up and listen to AM/FM stations.
How to listen to FM and AM broadcasts
Dec 18, 2014 | Sony 7.2 Channel 4K Black A/V Receiver -...
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
How do I preset the tuner for radio stations. I've never had a problem doing this with any other stereo. But what I think should work isn't!
Not very specific. Do you have the manual?
The following is from a VSX-03TXH manual. It ain't pretty but it may help.
I'm posting it in multiple parts due to space contraints.
37
Chapter 6:
Using the tuner
Listening to the radio
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
Dec 23, 2010 | Pioneer VSX-07TX Receiver
My Grundig Satellit 700 Radio is not working on FM Band but is working well on AM and Shortwave Band. After pressing ON/OFF button and FM/RDS-AF button when we try to operate the FM Band of this radio...
As a side note, most AM/FM radios use a separate antenna for each band, thus why you can pick up AM but not FM. Check your mast antenna connections to make sure they are solid and not missing or loose.
Dec 10, 2010 | Grundig Audio Players & Recorders
How to manual tune the radio to a station and not use the scan
i have the exact same problem. i bought a fm transmitter, so i need to tune to a unused fm station in my region wich i cant do because the audi concert tunes up automatic and skips the unused stations ... HELP !
Nov 23, 2008 | 1997 Audi A4
No fm reception
We had trouble switching from AM to FM. We finally solved the problem by pushing the reset button on the back of the unit (any sharp pointed object can be used to engage the reset button). Do this followed by setting the mode to FM and try tuning in your FM stations. Try the procedure several times and it may finally kick in, as was the case with us getting our AM stations
Dec 30, 2007 | GPX HM3817DT Shelf System
27 people viewed this question
 Grubhead
Grubhead
